Yeah, I was wanted to know that as well, I pulled it apart and resoldered everything but didn’t change anything. I will swap out the FET and see if that changes anything in a little bit, that is the only other thing it can be besides the LED’s themselves that I can think of.
That said This is not uncommon when building big lights, some just make more or less then others for no apparent reason. This is why I don’t guarantee any number, just like CPU’s and the silicon lottery, some LED’s are simply better then others, for many of the same reasons.
And it looks like the final light for today is done, Newlumens Blue XHP70.2. He wanted the P2 5700k in this light with 100% ramp and like his xhp35 the tint is very better then the stock CW, almost acceptable to my NW picky eyes. If I had to have a CW light, these would be the ones I would get. I can not stand the stock LED’s.
Final lumens show it doing ~22k lumens, not bad at all.
Being able to try all these different combos and seeing all these colors in person is neat. I really like these colors.
Ok, swapped the FET, checked everything over, put it all back together and tried it again with cells fresh off the charger and it is now doing about 23k peak stabilizing around 22k. So that is more like it.
On paper it would, it should be about ~21% brighter then the D2 5700k HI LED’s he used. Although many times paper numbers and real world numbers don’t line up perfectly.
Simply order the light from Terry like you normally would but tell him you want to ship it to me and give him your BLF user name to send with the light.
Then contact me via PM to work out exactly what you want done to the light. Terry will send the light to me and I will mod it and then send it to you.
Just place your order with me. When I begin shipping on the 18th all but just a very few will got to TA even if it is just for the driver install so I will ship it to him with the others.
As far as what modifications you would like just send TA a PM and he will take from there.
I have not tried it on the 5700k myself yet but I know that the 4000k looks pretty good with a shaved dome. None of that puke green tint of days past. It does get warmer and a bit more yellow.
I am going to guess that the 5700k will fair pretty good as well just no first have experience with it. All my lights are NW.
oops... He is right I just noticed that you asked about the MT07S
If you want to order the MT07S that is simple just place the order and I normally would just ship that to you... You can talk with TA and ask him what if any modifications he may be able to do to it.
hiKARlnoob is right if you are looking for the 20k plus lumen light that would be the MT09R 70.2. Unless something has changed and I was never told about it I can pretty much promise you that you are not going to get anywhere close to 20k lumen from the MT07S.
It is a great light even totally stock. It is one of the first Haikelite models I ever purchased and it is still one of my favorites.
That is a lesson all of us have learned at some point the hard way. Still I think it may be worth a try.. As soon as things settle a little and I am sure I have any orders for the 70.2 stock I have is either gone or stopped selling for some reason I will get with you on that.
I know what the driver can do even with stock emitters so I do believe it would be worth the money to at least try. Even if it came out the same output as Newlumens 35 high I would still not be disappointed.
yeah, I prefer NW as well. However, 4000k is lowest I go, any warmer CT is too yellow for me. That is why I asked for shave dome 5700k; I kinda hope it will set somewhere around 5000~5200k, at cold side of NW.
Very happy with that result! Good to know mine is not an outlier on the lower end.
I’ve been wondering what is the point of choosing the XHP35 HD over the XHP35 HI? It seems if you want it to be floodier, then just go for the XHP70.2 or if you want somewhere midway, wouldn’t it make more sense to pay just a little bit more for the dedomed 70.2, which will probably give the same amount of throw as the XHP35 HD but with triple the lumen output?
In my case I figure I will start off with the HD and see what it is like. Then if I decide I would prefer a HI I will simply slice the domes off. Technically this should give a bit better output then a normal HI anyways.
Plus I have never regretted going with an HD yet, the extra lumens they offer seems to balance out the reduced intensity and the end result is only around ~10% less throw in the first lights I did back to back tests with IIRC,
