Have you tried regulating it, by that i mean simply leaving dial up(or down) to correct the time. Not sure which way on seiko, or even if it matters or auto’s generally work the same. Winding button down to loose a few seconds etc kind of thing. Just thoughts, but –5 seconds a month seems pretty damn awesome!!!
I have nearly bit a few times here in the UK in the last 12 months!
This time(no pun intended) i have decided to try out a g shock. Its been years……………decades!Maybe even late 80’s, you know calculator watch era lol. Hopefully i will add a few pics next week, fancy getting maybe 2 or 3 of them to swap about.
Not easy to get! had to be fast as back light only lasts a second!
So far i like it, I wanted was a digital watch to bring back some 80’s memories. Also a change from hands and to digital display as until now i had none!. Next is a mudmaster, only reason i got the BB first was simply due to being rare and all digital. Mudmasters are easier to find(well i have seen plenty so far anyway).
Watch this space! pun intended
Hopefully i can stop at just 2 :person_facepalming:
Edit- figured the back light, can change it from 1s to 3s………….job done!
Not really because I live on the east coast (Long Island, NY) where there’s a very weak signal. I have a satellite wall clock that almost always never connects. I think it might have connected twice in the 6 months I’ve owned it
Sometimes the older ‘atomic clocks’ just quit working.
I’ve never known why.
But plenty of other atomic clocks in the same place, resync every night.
So, just because one clock quit, doesn’t mean the signal is weak or changed.
As I know there’s a difference between traditional radio controlled watches and satellite / GPS controlled ones like the Seiko Astron for example. You can sync your GPS controlled watch anywhere in the world while the syncing of the radio controlled ones are limited to the reach of the emitters.
