I’ll just remind the general public that this light has more output (at all mode levels) when using a 14500 battery.
I have five SP10a lights and they all have the new UI. My wife gets NiMH batteries for her’s. The moonlight is about 1 lumen out of her light, but closer to 3 lumens out of mine. When you double click for the turbo, my SP10a kicks up very nicely (and throws better than I expected it would when I got it). But my wife’s when running on the lower voltage NiMH battery, hardly bumps up at all when turbo is initiated.
Anyway, she DOES use her moonlight for early AM jewelry selection (and she claims it’s fine as she lives by candle light each morning — I don’t know which we spend more on: these lights or candles?)
Great powerful little beast for me, and the wife is happy enough (as she hasn’t thrown it away yet— like the 10+ Harbor Freight “free junk” lights she has over the last 5 years).
Hey, anyone have issues with the tailcap being really tight and scratchy? Lots of binding, no obvious damage to the threads that I can see, but still really tight and scratchy about midway through.
Thought maybe it was just lack of lube, but it seems pretty decently coated.
Mine are obviously ALL new Revs of the SP10a. I ran all of them today checking them out, making sure they were all the same (Version 2 ui), etc. (I was supposed to be doing taxes).
They all checked out good and they (along with three SP32s) all checked out in all depts. I took the tail caps off to measure voltages about 5 times each light— all good on mine.
I received a SP10A from Sofirn @ AliExpress store, not Amazon.
The UI:
- click for ON, always on the firefly mode
- when ON, single click to change modes (FF > L > M) and “long” press for OFF (1 second, maybe)
- double click for Turbo
- triple click for Strobe
from OFF, 4 fast clicks to Lock/unlock EDIT: Long press from OFF goes to the last regular mode used before shutting OFF
Also, I bought a driver for my SP10B and it has the same UI!
What I found on this new SP10A is that only button top cells (at least the 14500s) work. There may be something different in the driver design that hinders the flat tops to work!
BUT, curiously, the driver I bought for the SP10B, works perfectly both with button or flat top batteries… This is something weird…
Also, using a Panasonic Ni-MH battery below 1.38V, the light almost doesn’t turn ON. It may be the LVP protection working. I don’t know if this supposed to happen constantly as I just tried it for experimenation purposes!
Last but not least, on this new light, and only by “eye measurement” the max level with AA / Ni-MH doesn’t seem so distant from the max level on 14500. But, as I said, it is eye measurement, not objective or accurate measure.
WHAAAA I hadn’t noticed that :person_facepalming: :person_facepalming: :person_facepalming:
You are right, mine does the same thing!! I will correct my words :person_facepalming:
Thanks for letting us know that!!! So…Sofirn has a similar UI to Olight
EDIT: It is not the same, sorry! What I meant was that the access to Firefly, Turbo, Strobe and last regular mode used are the same. The operation (clicks vs press & hold) are different :person_facepalming:
Hum… my flat top Panasonic runs fine in my several SP10a (new revs) I did test last week when I go them in. The same 14500 flat top HAS run also fine in my first SP10a I’ve had for about 6 weeks now (my indoor carry, so it’s been well checked out).
I love this little light, so I bought several of the same (newer) 10SPa’s for gifts to give my family muggles. At first, I was going to just let everyone getting one just use AAs. But Lightbringer explained the “alkileak” problem (set me straight fast! ) and so I bough a few chargers and BT 14500’s to pass out to them.
I’ll just tell everyone that IF they use any alkaline AAs: it may “produce poison gas, as ”this light goes to 11.” (which are both true statements… I think).
And since I’m also giving most of these kinfolk an 18650 light too— they can use the ONE charger to charge both battery sizes. So I’m using “light” fear tactics and giving them what they need to work it all out for themselves. No kids around with these gifts, so hopefully no little hand (or barns) get burned down.
I guess my SP10A has something wrong with it then
The Ni-MH and AA batteries (button top) work fine as do the Sofirn 14500 Li-Ion, button top as well.
My Sanyo 14500 and Efest 14500 don’t work, I tried if for a while… I’ll check on this again!
Thankfully it is not a general issue …despite mine is bugging me :confounded:
Thanks for the AE link. I ordered two (blue & red) for US$19.34 shipped to Australia. I got their US$2 off US$15 order store coupon, plus exchange 20 AE Coins for another $2 off. Great deal! Love colored lights
