Hi Martin, Interested in Imalent RT70 and RT35.
Thanks
Thanks so much, M4D M4X! I bought the MR70 earlier using your code too. That huge discount coupon was simply irresistible!
Tried to buy the Q8 just after penzzy ordered it & saw the out of stock notice immediately.
Do inform us here when you are informed that the new stock is in. A couple of us here are ready to order it I think.
i was told today they spped up restocking as possible ;)
When I add to my cart, it shows Processing time: Expected on 10th May
I will check in here daily for next few days. Thanks for the update.
My ODF30 was shipped this morning, happy days.
Hello my dear friends!
new deals i hope you like:
(deals can be found here or you ask me)
SKILHUNT H03 RC
SKILHUNT H03R RC
SKILHUNT H03F RC
XM-L2 U4 1200LM NW/CW Magnetic Charging LED Flashlight Outdoor Headlamp Headlight
AMUTORCH New JM70
XPL HI 1200LM Magnetic Charge Dual-switch Long-rang 1027m Searching LED Flashlight
Interested Skilhunt , Amutorch.
Please Code.
Can you get a good code on Astrolux K01 from BG?
Order placed for Lumintop ODF30 through your site, thank you
Can you find out if they plan to offer the NW 5000K version? (and convince them to!)
Any chance on a special for the Acebeam EC65? Cree XPL LEDs or Nichia 219C LEDs.
i am trying since i had it in my hands ;)
very good question:))
Hopefully my next purchase will be the EC65.
mine too:)
it would take a month if they pre-order now
Acebeam EC65 looked very interesting, until I saw lowest mode of 20 lumens. And they call it “firefly” mode!
NEW: Klarus Mi1C army green / rose also black, copper and titanium
who has them all?
Klarus Mi1C
XP-L HI V3 600Lumens Mini-might Brightness EDC LED Flashlight
Army Green
Rose
Black
Copper
Titanium
deals can be seen here by members – or you ask me
Features:
• Mini-might brightness, thumb-sized.
• XP-L HI V3 LED, maximum output up to 600 lumens.
• Extreme runtime, up to 9 days in moon mode.
• Professional optical lens design, even-lit flood and soft beam.
• Tail magnetic base function, attach to a metal surface to provide “hands-free” illumination.
• Fade-in and Fade-out function when the turbo mode is the initial mode for on and off to promote eye safety and improve user experience.
• Newest Intelligent Temperature protection System(ITS) monitors internal temperature and adjusts output to regulate heat dissipation; protects LED and internal components for perfect balance of output and safety.
• Intelligent Battery Capacity indicator to view remaining battery capacity at any time.
• Unique lock-out mode prevents accidental activation; avoiding battery drains during storage or travelling and prevents unintended directly shining into eyes.
• Reverse-polarity protection prevents damage due to incorrect battery orientation.
• One-touch low and with mode memory function.
• Aerospace Aluminum Alloy construction; CNC precision machining; Mil-Spec HAIII anodizing, anti-abrasive, lighter and robust.
•Compatible with CR123A and 16340 Li-ion battery, KLARUS high performance 16340 battery with Micro- USB port included, no need to bring a charger, easy to use, safe and reliable.
Package included:
1 x Klarus Mi1C 600Lumens Mini-might Brightness EDC LED Flashlight
1 x 16340 Li-ion Battery with Micro-USB Charging Port
1 x Stainless Steel Clip
1 x Spare O Ring
Hi Martin,
Do you see any chance to get a substantial discount code for the Convoy L2 and L6 again? Unfortunately, the existing codes have been expired („more than 100x used“ or so). Thank you so much!
