Future development of the maximum luminance of LEDs
Speaking of Osram Stage…
LE RTDUW S2WP has 1.8 mm² white die (and 3 others that we can ignore).
Specs look largely like a quad Q8WP, quarter thermal resistance, four times thermal pad size. Actually marginally worse than that.
Now…if a single die can’t widen its thermal path to use that of neighbouring dies, it should be slightly worse than Q8WP.
However if it can move some meaningful heat through the other parts of the package, it could be a winner.
That’s an interesting idea, but very impractical! Centering the white die of that LED will be “fun”. It seems to have the same die and lumen range of the Q8WP.
You surely know this stuff much better than I do…could you please elaborate why is it going to be significantly harder to centre than Q8WP?
I would think that with both lights having their dies offset would cause the same kind of troubles. OK here the die is offset in 2 dimensions.
Well it has a non-standard solder footprint. It wont center itself correctly when you put it on a pcb for 5050 (XM-L etc.) LEDs. The next problem you will have (which has nothing to do with focussing though) is that the solder connections underneath for the indvidual dies have a really impractical layout for this scenario. Anode and kathode of a single die are on the same side of the LED. So soldering it onto a 5050 pcb will not work.
Many people wont drill new holes for correct centering when modding a flashlight. You might need to even drill new holes in the light, not just in the pcb. With Q8WP you just need to widen the holes a bit. But I’m not sure, maybe it’s not so bad after all.
It also depends on what kind of light you want to build or mod. The bigger the reflector, the more headaches little things like this will give you.
Thanks for the explanation.
I’m still waiting for some people to actually try the Q8WP. I will definitely use it in the light in my sig (the light was designed with this LED in mind).
The_Driver,
Any link to purchase them?
Rs-online, taobao
Some time ago Hoop offered to make custom MCPCBs for a reasonable price.
He hasn’t been active for quite some time, but maybe it would be possible to get some other machinist to do such job?
Why a machinist? We just need a standard pcb company to do it. We could ask someone like led4power to make pcbs for the Q8WP.
I was talking about S2WP. For now (and likely forever) too niche for even small volume order.
But I agree, it should be possible to gather enough interest for Q8WP.
Ok so I found out two things:
1) The KW CSLNM1.TG (image A) has a smaller lm and cd value than the KW CELNM1.TG (Image B) simply because the datasheet has a larger bin range for the second one. The website then lists the average lumens and candela as the (min+max) / 2 making it seem like the CELNM is better.
image A, CSLNM)
image B, CELNM)
Even though the CELNM may have a higher bin, we likely will never have a chance to purchase those anyway, so effectively it is the same as the CSLNM.
2) Also, as expected, you can see in the datasheet that the smaller thermal pad does hinder the overdriving ability, as the curve only shows 1.7x output at 2 amps, where the CSLNM has 1.75x output.
For this reason, the CSLNM is a much better choice because not only does it perform the same, assuming you get the same bin, but it has the same thermal pad as the black flat allowing it to be used on XP-size boards and gets better overcurrent ability than the CELNM.
As for the performance compared to the black flat, lower thermal resistance only seems to make it maybe 0.05x higher output at 1.5A when compared to 1A according to the flux-current graph. The main benefit will be not having the notch in the corner.
Despite smaller contact pad size, the CSLPM1.TG (seen below left) has almost the same thermal resistance as the Q8WP and gives it the same overcurrent capability according to the datasheet graphs.
The benefit will be that it can now fit on an XP-size board easily just like the black flat.
It is unclear how having the new only-surface-emitting design will affect the intensity, it has no weird polar distribution from side LES like the Q8WP does, The die area is 0.08mm^2 larger, and the flux for the minimum bin is 400 now instead of 355.
With similar or more lumens, and no side LES, but larger die area, I would expect similar cd/mm^2 than the Q8WP, which is already extremely high 245cd/mm^2.
The specs from the website (in this post) show the Q8WP as higher flux because the highest bin goes up to 710lm while the new LED only goes to 630.
But since we seem to never get the highest bin anyway when buying our LEDs this likely does not matter as much as the minimum bin does.
Based on this, there are two LEDs which are important to test as soon as they are available to buy:
OSRAM OSTAR® Projection Compact, KW CSLNM1.TG
OSRAM OSTAR® Projection Compact, KW CSLPM1.TG
Very interesting, thanks for the heads-up! These looks like a very nice, practical upgrade! The bigger die of the KW CSLPM1.TG could allow for higher max lumens. The central solder pad is smaller though compared to the Q8WP, but the thermal resistance is actually the same.
Yup!
I would guess the CSLPM will get similar intensity to the “new black flat” CSLNM and just more lumens.
The insulated center pad and no cut corner makes these LEDs really appealing, even if they don’t perform much better than the current ~250cd/mm^2 LEDs.
But of course I do hope that they perform a bit better.
I can’t wait for them to be available :slight_smile:
It would be interesting to test Stanley HCNW115AJTE
  • 0.96 mm²(unclear, up to 1 mm²) (Blackie: 1.122)
  • 265-410 lm at 1A*3.25V (Blackie: 250-400 at 1A*3.05V)
  • 3 K/W (Blackie: 4.3)
  • 2.096 mm² thermal pad (Blackie: 2.67)
If top bins are orderable, that could be a win.
Interesting, the package does look a bit weird though!
One difference: the Stanley has two bond wires.
Luminus now has a new LED on the site, the XP-G2 sized brother of the SST-40, the SST-20 (datasheet).
Features:
  • Thermal resistance: 3.5°C/W (XP-G2: 4°C/W, CSLPM1.TG: 2.6°C/W)
  • two different solder profiles:
  • => A120: XP solder profile with neutral center solder pad
  • => B120: smaller Osram (Black Flat, Square etc.) solder profile with neutral center solder pad
  • rated up to 3A
  • square die (not retangular)
  • brightness at 1.5A: up to 10.7% higher compared to XP-G2 S4, average might be closer to S3
Maybe 220-230cd/mm^2 are possible? Benefits here are that the new Luminus LEDs seem to be chaeap and easy to obtain. They also seem to still have a cool-white tint after de-doming.
Love those bond wires… :person_facepalming:
I wouldn’t worry about those right now. The SST-40 goes up to 9A and also had just two. It’s possible that they use the same ones in this LED.
And, though not the scope of this thread, the SST-20 comes with some warm 95 CRI versions.
