It will probably take a while to be able to do that mate! The project has not fully advanced, some details are still to decide! Let’s cross the fingers
@ FW3A Team, I sent “you” a PM
Will be looking for your reply whenever it is possible!! Thanks in advance!! :sunglasses:
I don’t think anyone actually checks that… or even logs in at all, except on rare occasions to post progress updates or edit the top post. It may get used more later, but for now it’s mostly a placeholder.
Just an FYI: I don’t think it’s going to be a tail clicky in the traditional sense, but a tail mounted contact that operates it. Similar to Liteflux, Novatac, or HDS.
Sorry if I’m stating something you already knew, there have been a lot of updated threads about lighted tailswitches lately and I wouldn’t want you to get your hopes up for this being a candidate.
Or, and this is certainly a possibility, I’m completely wrong.
It’s an electronic contact switch, not a hard power-disconnect switch. It isn’t compatible with any current lighted-tailswitch solutions, but if you replaced both the custom switch PCB and the metal boot it might still be possible.
Yeah should not have said clicky. Just a tail switch that is a lot easier to find than a side switch. That ramps and does all the other fantastic modes like candle and lightning.
