well,good choiceā¦i wrote them today.sadly,only smooth reflector and only cool whiteā¦.not for me.but the led could be changed for xmlā¦.hm.very interesting light.
its a shame,that the famous Emisar can be used with he max.output only for secondsā¦fot its money its not enough for me.
Thanks for the suggestion, that light is 122mm long, the DQG is 88mm and the Folomov is 99mm, I really wanted a short 18650 light and apparently the folomov checks on all my requirements + it has a cell charger, will find out this afternoon when I get it.
Iāve been on the āeternalā quest for the most compact 18650 (side switch) light for years.
Have held off on the DQG Tiny 4th (87mm) because of reported switch failures.
Zebralight SC64 (92.5 mm) looks great but I havenāt got to the point of wanting to spend $80 on one small light.
I donāt need USB charging but I wouldnāt mind a magnetic docking charging system like on the Olight S2R.
Olight S2Rā¦ā¦ā¦ā¦ā¦ā¦. (105mm)ā¦ā¦ $72.95 (but itās too long and also expensive)
. Hereās the smallest ones Iām aware of with built in USB charging:
Unfortunately none of these offer a NW version.
Iāve been waiting at least five years for Olight to offer a NW version and they still donāt.
. The Nitenumen C8 appears to be the same body as the Folomov EDC-C4 but with stainless bezel.
EDIT I just realized the Nitenumen the has a large-ish rectangular protruding area for the USB jack, the Folomov doesnāt. But since the switch is directly opposite, it may serve to help readily locate the switch in the dark.
I really like the stainless bezel. Iāve been trying unsuccessfully for days to get clarification from Nitenumen on the UI specifics, but language barrier seems to be an issue. In one of the photos it shows the Strobe and SOS as being āconcealedā modes, however a comment in the review leads me to think otherwise.
The Ultratac S20 does have hidden strobe: Ultratac S20
Iām really surprised after all these years nothing has come down the pike in the size realm of the DQG Tiny 4th, I probably should just get one already and look into to reinforcing the switch, maybe with glue/epoxy or something as Argo suggested. (glue/epoxy was also brought up several times in the Tiny 4th threads, as well as re-soldering/adding solder to the switch mounting pads)
even you can change the ledsā¦.i also dont like the cool white anymoreā¦the ānon optionā of get a nw instead of cw avoiding me from the buyingā¦
manker u11 has usb but it is somewhat longer and has {in my experience} a VERY poorly designed and implemented switch
mine broke and is totally unrepairable at least by me
tha manker u12 has one serious problemā¦the mcpcb as i heard is not fixed to the heatsinkā¦so,if it rotate inside and also there is not good heatsinkā¦
well now iam serious thinking about Folomov,which seems to be the highest quality,Nitenumen and Ultratacā¦but never seen any of them sadly.any special serious cons about this three lights??thanks
Today I recieved the Folomov, here are my thoughts so far:
Positive
I like the compactness
Brightness level spacing, with every press of the button it goes from L,M,H,T then T,H,M,L keep pressing and L,M,H.T etc.
The last mode memory
The tint seems to be around the 1C tint cool white semi floody like a zebralight or the C22C
The triple click for lockout
The strobe, SOS and beacon are hidden by a double click
I love the beacon on this light, wish everyone implemented it, it fades in and out.
The tactile feel of the buttons
To be able to charge it using a Micro USB cable
The power bank feature.
Protected batteries fit
Negatives
The treads and o-rings were not lubricated
You have to keep the button pressed to turn on or off (Might be good to prevent accidental turn on in pocket )
UI would have been awesome with Narsil
The led centering ring borders seem very high and blocks some of the peripheral light (Will sand it down)
The USB and the Switch look the same, if not careful you might remove the switch thinking it is the USB port
The driver looks like it was glued in place
The bezel seems to be glued shut, will try the strap wrenches.
Havenāt opened it up yet, I probably do that at a later time.
