I have had the same thought but everyone calls it a sphere when talking about a lumen measuring device. So trying to come up with a new name at this point seems like it would add more confusion.
Well Lumintop is not messing around when they assemble, that surely explains why I had to buy two boa constrictor rubber and metal strap wrenches and with degenerative disks in my neck that are just crushed it really kicked my butte getting those apart but I did it but not without paying the price in pain for over a week.
I do know Lumintop has some serious glue, just try and disassemble the AAA Ti Tool with the electronic stupid switch, geez, that is some work.
Wow a dedomed 70.2 with close to 10k lumens making 85% of XHP35 throw is amazing! Too bad the GT is so massive, otherwise I would buy it from you! I wonder what kind of throw you can get with MT07S or MT09R w/ 70.2 dedomed.
Yep, the numbers are even hard for me to believe so I am taking them with a large grain of salt until I get a new lux meter. These small HS1010’s work great for the sphere where the light is heavily diffused entering the meter but for direct lux readings they always ready low it seems. The dr meter did much better and got similar results to others with the GT.
I am also curious about a dedomed XHP70.2 in the MT09 or MT07, luckily I have at least 2 coming that are getting that treatment.
Yep, you are one of them.
The tint shift is noticeable for sure with the 4000k seeing it side by side in the GT’s. It ends up in the mid to high 3000k range for sure. Just so you are aware. I can change your LED’s order still since I had to wait to place the order till tomorrow or Monday.
Yeah, it took 2 full grow guys plus a strap wrench and vice to get mine apart finally. It is no joke.
The hardest part is getting a good grip, the vice made it much easier but I was so worried about scratching it up I tried to not use it at first. Luckily there was no damage.
That is the same one I plan to order this weekend, I have heard good reviews about it. It is also the same thing I used to use as well and liked it. The HS1010 is simpler to use but the dr meter seems more accurate for throw readings.
It is not dark yet… i did the ceiling bounce and its definitely over 20k lumen light… daylight ! ramping mode is super smooth. ( descending or ascending ). I like both version with the 5700k tint. Overall, its worth it. Brighter, highest bin led, TA driver, and more reliable. I a, happy with the mods…
When you remove the dome you automatically lose output. I could tell just by eye when I did that with an older xhp70. TA, do you know how much output you lose, 10%?
The last report I heard from you was that your GT was modded to 6A (12v) and did 1300 meters with the dome on. I can’t find the thread, but I think you bumped up the output to 8A (12v) on the GT driver, sliced the dome off and got about 1600 meters. Is that right?
Have you swapped in a FET driver to the GT? Has the distance gone up again?
Yeah, around 8-10% was what I was seeing in losses but it is hard to tell exactly as these output levels since I can only hold the reflector for so long before my fingers start burning lol.
Yes, I had it with the stock driver @ 6A and it was around 1300m with the dome on and 1600m with the dome off IIRC. I never ended up taking it to 8A. It was simpler to just go with a TA FET driver since the GT can handle the power. So I spent the last few months working on that off and on.
Now it is doing something around ~10-11A at 12v (20-22A @ 6v) and the numbers have gone up to match naturally. See the GT modding thread for the latest numbers BLF GT (preliminary) modding thread
I don’t have the same meter I was using (that is the meter you have now ) so I am having to use the cheap meters that I know read low. I am waiting until I get another Dr meter to really get some numbers I can trust. These just seem too good to be true but they are what it said.
OK, here’s my dumb question for today,
Could someone please explain to me what is meant with requesting a 50% ramping,
I think I understand 100% ramping but I don’t get the request for 50, what happens with the other 50 ramping?
That’s all the dumbness I can think of at the moment, but sure would like to know what this is all about.
Thank You, I will wait patiently until your all through laughing at me,
The only dumb question is the question that is not asked (or that is not learned from if it was already asked lol).
The 50% ramp simply stops the ramp at 50% power, this is around ~11-14k lumens on most lights. Then you can double click for turbo 100% power.
I find that limiting the ramp to 50% is more then enough light for 98% of tasks and reduces the stress on everything by half and also vastly reduces the overheating.
I actually setup my lights lower then this in many cases so that I can give it to anyone and they will not run it unnecessarily hot and bright.
Another thing I like about the 50% is that you can actually see a difference when you go to turbo, so it makes turbo mean something.
Just to get technical, do you set it to 50% the amp draw (or what is equivalent to that) or do you set it to 50% of the ramping numbers? I think NarsilM uses 150 steps? Something like that.
