hkequipment – Manker MK36 Palm Size for 12,000lm. Can act as Power Bank...
Hi
Sorry. We don’t have coupon for Tiara and both models sold out right now.
MecArmy SGN3 - US$29.9 only. Five color including Stonewashed finish available
FLASH DEAL up to 38% off…Limited stock including flashlight, finger spinner….
nice flash sale, please have them more often :wink:
Haha, will try our best. Thanks for support
Real capacity…Fireworm 18650 3500mAh simple test…
Undelivered mail returned to sender…
I’ve been trying to send mail to cs@hkequipment.net for some time and it bounces back.
I still have a Ultratac K18 brass unresolved issue but can’t reach you.
Do you have an Opus BT-3100 v2.2 and use the ‘discharge’ test?
That “Powerfocus”, if I recall correctly, is the earliest re-badged 3100 v2.0 and has issues with capacity readings.
PowerFocus Test unit not v2.0, and it is latest version. Need check
It (the version) will show on the display immediately when plugged.
Can you please try a full charge, then do a simple Discharge?
ACEBeam X80UV with 8pcs NIchia UV…
Very cool X80, it would be even neater if they put a ZWB2 filter in front of that 276A-array. I would at least mod it that way if I could justify buying that light.
MecArmy SGN3 USB Rechargeable Flashlight with White/UV/Red light - US$29.90
MecArmy PS14 Dual Color Temp Flashlight
Something for clearance…
One more target for copper fans…Nitecore TIP Cu
Fenix TK45 Brand New with box
4000lm can be provide by palm size flashlight…ACEBeam EC65, take one 21700 only with USB-C fast charge !!
Has the HKE80 code expired? I tried to use it today but with no joy.
Yep expired since March.
