Haha, will try our best. Thanks for support
Undelivered mail returned to sender…
I’ve been trying to send mail to cs@hkequipment.net for some time and it bounces back.
I still have a Ultratac K18 brass unresolved issue but can’t reach you.
Do you have an Opus BT-3100 v2.2 and use the ‘discharge’ test?
That “Powerfocus”, if I recall correctly, is the earliest re-badged 3100 v2.0 and has issues with capacity readings.
PowerFocus Test unit not v2.0, and it is latest version. Need check
It (the version) will show on the display immediately when plugged.
Can you please try a full charge, then do a simple Discharge?
Very cool X80, it would be even neater if they put a ZWB2 filter in front of that 276A-array. I would at least mod it that way if I could justify buying that light.
Something for clearance…
Has the HKE80 code expired? I tried to use it today but with no joy.
Yep expired since March.
Sorry about that. It may be system error. I just reset the coupon and work well now… Thanks for remind
Sorry to bring back this issue in your thread, but i’m left with no other options as you don’t reply to my PMs.
That was on April 15…
The issue dates back from last December and is still unresolved.
What’s this?
I’ve never had such a non responsive CS. :rage:
Buy Manker MK35, MK39 or TimebackII - FREE Manker TACTICAL PEN
