I guess it could be made to fit as it is close. Diameter is the problem, I think it would fit nicely otherwise. However, myself, I’m not willing to file down the switch nor open up the threads in the tail.
I will soon offer ILC-1 kit without brass ring at significantly lower price than assembled ILC-1, top and bottom pcbs have 16.5mm diameter , so such "ringless" ILC-1 should fit in more lights (brass ring is not really necessary, but without it switch and top pcb should be glued to prevent twisting).
Doh! Good eyes led4. Without the tape it measures 18.08mm. I guess I could force it but since I don’t want the switch in that light I’m still not going to …
Depending on the machining it might well fit in other E14’s / S41’s :question:
Even with a “turn-key” illuminated switch, your driver may not be up to the task. Many require a bleeder resistor in order to function properly. So I don’t think it’ll be as easy as just buying some switches, unfortunately.
I’ve done my fair share of illuminated switches - I love them. I’ve put ’em in Convoy S2 / S2+ / M1 / C8, Astrolux S41S & SS, Brinyte B158, etc. I use the PD68 Rev5.3 ring boards, similar in appearance to what Lexel is displaying. Bright, efficient, and 6 LEDs with up to 2 (sometimes 3) different colors.
I don’t really want to open up shop and have a flood of requests, but I’d be willing to help a BLF’er or two fulfill their dreams of a custom illuminated switch. Due to the bleeder resisters, it’d probably be best to send the entire light back & forth. Shipping wouldn’t be cheap, but at least you’d know it would work upon receipt without any fiddling around.
Samples… left to right: Astrolux S41S with blue & green, hand-polished Convoy S2+ with cool white, Astrolux SS with blue & white, Convoy S2 with blue, Convoy M1 with green
