When I add to my cart, it shows Processing time: Expected on 10th May
I will check in here daily for next few days. Thanks for the update.
My ODF30 was shipped this morning, happy days.
Hello my dear friends!
new deals i hope you like:
(deals can be found here or you ask me)
Interested Skilhunt , Amutorch.
Please Code.
Can you get a good code on Astrolux K01 from BG?
Order placed for Lumintop ODF30 through your site, thank you
Can you find out if they plan to offer the NW 5000K version? (and convince them to!)
Any chance on a special for the Acebeam EC65? Cree XPL LEDs or Nichia 219C LEDs.
i am trying since i had it in my hands ;)
very good question:))
Hopefully my next purchase will be the EC65.
mine too:)
it would take a month if they pre-order now
Acebeam EC65 looked very interesting, until I saw lowest mode of 20 lumens. And they call it “firefly” mode!
who has them all?
deals can be seen here by members – or you ask me
Features:
• Mini-might brightness, thumb-sized.
• XP-L HI V3 LED, maximum output up to 600 lumens.
• Extreme runtime, up to 9 days in moon mode.
• Professional optical lens design, even-lit flood and soft beam.
• Tail magnetic base function, attach to a metal surface to provide “hands-free” illumination.
• Fade-in and Fade-out function when the turbo mode is the initial mode for on and off to promote eye safety and improve user experience.
• Newest Intelligent Temperature protection System(ITS) monitors internal temperature and adjusts output to regulate heat dissipation; protects LED and internal components for perfect balance of output and safety.
• Intelligent Battery Capacity indicator to view remaining battery capacity at any time.
• Unique lock-out mode prevents accidental activation; avoiding battery drains during storage or travelling and prevents unintended directly shining into eyes.
• Reverse-polarity protection prevents damage due to incorrect battery orientation.
• One-touch low and with mode memory function.
• Aerospace Aluminum Alloy construction; CNC precision machining; Mil-Spec HAIII anodizing, anti-abrasive, lighter and robust.
•Compatible with CR123A and 16340 Li-ion battery, KLARUS high performance 16340 battery with Micro- USB port included, no need to bring a charger, easy to use, safe and reliable.
Package included:
1 x Klarus Mi1C 600Lumens Mini-might Brightness EDC LED Flashlight
1 x 16340 Li-ion Battery with Micro-USB Charging Port
1 x Stainless Steel Clip
1 x Spare O Ring
Hi Martin,
Do you see any chance to get a substantial discount code for the Convoy L2 and L6 again? Unfortunately, the existing codes have been expired („more than 100x used“ or so). Thank you so much!
a lot people asked about a good 8-bay charger to use with their BLF GT (which sells for $250 if you are member )
here is a very nice one:
(picture is the link to the shop – please click it)
use my code: MI8NC to get the price to US$ 37.46
Festures:
-Active Current Distribution (ACD)
-Monitors and charges each of the 8 slots independently
-Compatible with and identifies Li-ion batteries, Ni-MH and Ni-Cd rechargeable batteries
-Features three charging modes (constant current, constant voltage, -dV/dt)
-Automatically detects power levels of batteries and selects the appropriate voltage and charging mode
-Over-charging prevention
-Reverse polarity protection and short circuit protection
-Activation function for over discharged protected batteries
-USB output
-Designed for optimal heat dissipation
-Made from durable PC material (fire retardant/ flame resistant)
Can you check on some codes for 18650 batteries? Most seem expired. Looking for higher end batteries, Samsung 30Q’s or equivalent.
