I received a SP10A from Sofirn @ AliExpress store, not Amazon.
The UI:
- click for ON, always on the firefly mode
- when ON, single click to change modes (FF > L > M) and ālongā press for OFF (1 second, maybe)
- double click for Turbo
- triple click for Strobe
from OFF, 4 fast clicks to Lock/unlock EDIT: Long press from OFF goes to the last regular mode used before shutting OFF
Also, I bought a driver for my SP10B and it has the same UI!
What I found on this new SP10A is that only button top cells (at least the 14500s) work. There may be something different in the driver design that hinders the flat tops to work!
BUT, curiously, the driver I bought for the SP10B, works perfectly both with button or flat top batteriesā¦ This is something weirdā¦
Also, using a Panasonic Ni-MH battery below 1.38V, the light almost doesnāt turn ON. It may be the LVP protection working. I donāt know if this supposed to happen constantly as I just tried it for experimenation purposes!
Last but not least, on this new light, and only by āeye measurementā the max level with AA / Ni-MH doesnāt seem so distant from the max level on 14500. But, as I said, it is eye measurement, not objective or accurate measure.
WHAAAA I hadnāt noticed that :person_facepalming: :person_facepalming: :person_facepalming:
You are right, mine does the same thing!! I will correct my words :person_facepalming:
Thanks for letting us know that!!! Soā¦Sofirn has a similar UI to Olight
EDIT: It is not the same, sorry! What I meant was that the access to Firefly, Turbo, Strobe and last regular mode used are the same. The operation (clicks vs press & hold) are different :person_facepalming:
Humā¦ my flat top Panasonic runs fine in my several SP10a (new revs) I did test last week when I go them in. The same 14500 flat top HAS run also fine in my first SP10a Iāve had for about 6 weeks now (my indoor carry, so itās been well checked out).
I love this little light, so I bought several of the same (newer) 10SPaās for gifts to give my family muggles. At first, I was going to just let everyone getting one just use AAs. But Lightbringer explained the āalkileakā problem (set me straight fast! ) and so I bough a few chargers and BT 14500ās to pass out to them.
Iāll just tell everyone that IF they use any alkaline AAs: it may āproduce poison gas, as āthis light goes to 11.ā (which are both true statementsā¦ I think).
And since Iām also giving most of these kinfolk an 18650 light tooā they can use the ONE charger to charge both battery sizes. So Iām using ālightā fear tactics and giving them what they need to work it all out for themselves. No kids around with these gifts, so hopefully no little hand (or barns) get burned down.
I guess my SP10A has something wrong with it then
The Ni-MH and AA batteries (button top) work fine as do the Sofirn 14500 Li-Ion, button top as well.
My Sanyo 14500 and Efest 14500 donāt work, I tried if for a whileā¦ Iāll check on this again!
Thankfully it is not a general issue ā¦despite mine is bugging me :confounded:
Thanks for the AE link. I ordered two (blue & red) for US$19.34 shipped to Australia. I got their US$2 off US$15 order store coupon, plus exchange 20 AE Coins for another $2 off. Great deal! Love colored lights
I only got the SP10B (I got both red & blue versions, but not the black) from Sofirn @ AliExpress.
So far, I notice for batteries, my flat-top PKCell 14500 didnāt work. But I think there was once where it did work. So my guess, is the flat-top usually does not āmatchā the ā+ā side head of the SP10B (the head does not use spring). Using a magnet spacer on the flat-top PKCell 14500, did make the flashlight work always though (so it appears to be an issue with certain [but not all] types of flat-top batteries).
Another thing I tested, I just purchased a protected 14500 (my first time to get hold of them), these protected 14500s are much longer than the regular 14500.
I tested the protected 14500 and it seems to be just a wee bit too long for the flashlight tail (it seems to screw in fully, but light does not turn on). As a random thought, since I also got the Sofirn SF14 (which worked fine with the protected 14500 I tested with). I screwed the Sofirn SF14 tailcap on the SP10B (it appeared to fit perfectly), then I pushed the SF14 tail button (so itās ON), then used the side-switch. Now, the SP10B works with the longer protected 14500 battery.
(what that means is the SP10B tailcap is just a wee bit short so it doesnāt make proper contact when using longer protected 14500 batteries. But the SF14 tailcap is long enough to make contact with the SP10B body tube which made it work with the protected 14500.)
Just sharing my 2 cents worth of various random testingā¦
My SP10a ordered from Ali on March 28, 2018 has the UI MascaratumB described above and starts on Moonlight. The SP10a ordered from Amazon on April 10, 2018 starts on low, without moonlight, and is completely different. Annoying to have the same light with two different UIās, but whatever. A Sanyo flat-top UR14500P (49.5mm) works in both, while a protected button-top Nitecore NL147 (53mm) does Not work in either. Just some info for future people browsing this.
And how much ya wanna bet that the AX version has a nice neutral light, whereas the Amazon version is slightly green?
Iām getting used to the lmh version, and while I like the handiness of the flm+h version (2click to high, even from off), sometimes ā sometimes ā firefly is just a liiiiiittle too low.
i have received my blue one sp10b from sofirn store on aliexpressā¦i have no complaints, but one thing is making me unhappy a little bitā¦electronic switch button is a little bit loose or rattle a bitā¦in fact, the top of the buttonā¦it has good tactile feeling while pressing and changing modes, but you can hear it while shaking flashlightā¦it looks like the top of the button has some room to wiggleā¦otherwise, everything else is fineā¦i have sofirn sf10 as well, and sp10 is much brighter on maximumā¦sp10 compared to sf10 has cooler white tint, while sf10 is more neutral whiteā¦
