The problem with 18650’s is that they maxed out.
So in order to improve battery performance they needed to go bigger. And, yes Barkuti, the 2170(0) size is more efficient, given the (possible) improvements on the capacity and performance, in the space they have to build battery packs. So that’s the reason why they went with the 2170 size.
JasonWW, I thought Samsung came up with the 20700 cell before tesla came up with the 2170?
Well the 20700 was definitely before the 2170. Did Samsung make a 20700 before Tesla did? Idk. If they fid, why? What was it meant to be used for?
We always go off topic. Lol. At least this time we all seem to be learning things.
BTW, my Miboxer C4-12 can take a 72mm cell and my Xtar SV2 Rocket and Xtar VC4 can both take a 71mm cell. These unprotected 21700 look to vary between 70mm and 70.5mm. I am good to go! Lol
I voted for 26650 earlier, but now I think I will vote that both new sizes are okay by me. :+1:
Jason, my wife is gonna moidarize me and it’s your fault! I ordered 2 of the Samsung 30T’s to try in my triple 70.2, see how they fare against the iJ0Y’s. These are not cheap cells!
I can only see one place that has them and they are $18 each!
Once they start being imported in larger quantities I’m sure the price will go down. You know all the vapers are gonna want them. Lol
I hope they dont burn up your 70.2’s. I would be afraid to run them in my L6 with single 70.2 and FET. You have 3 emitters, so maybe you have more safety margin.
It looks like the 48G would be the better choice in a Sofirn C8F at about $9 each. Frankly all these 21700 are pretty pricey. It’s off putting, but once you buy it you’ll forget all about the expense. Lol
Actually Liitokala 50A delivers less current than Keeppower (really: PLB) “6000 mAh”.
BTW, I’m dreaming of PLB tech in 32650 cell…that would be like 8800 mAh at low currents and 8300 mAh at high.
I think maybe Jason hit on something we should think about here. If the new breed of 21700 can deliver TOO much, would it blow emitters in the Sofirn C8F triple?
So if the light is made FOR the 21700 size then it might be somewhat more difficult to find cells that perform LOWER, would be a lot easier and safer all around to have the light made for 26650 and when we mod we could take measure to prevent over-current if we plan to use the top 21700’s.
It has very unusual springs and battery sleeve to size down. If such a thing as a protected button top 21700 were to exist i’m not sure this would be compatible without changing the springs. By doing that you probably lose out on 18650 flat tops or may run into drop disconnects? I guess the point i’m trying to make is that for you and I this is clever and makes a flexible host but for a ready made light it’s sort of like a jack of all trades master of none. To be fair it does work well with flat top 21700 and flat top 18650 as is.
I suspect when I end up modding this light in the future I will choose springs which fit 21700 really well and if it ends up breaking other compatibility then so be it. I’d rather have a light that does one thing really well.
Your argument makes a lot of sense, considering a product released, you’d have to count on batteries available in the present, and for higher capacity 26650s still win
Yet my preference still lies with “aspect ratio” and portability. I don’t have any 26650 flashlights, but I have a C8 and it feels like it’s on the upper end of the size of flashlight I’d purchase. Both 26650 and 21700 sized tubes would fit our current 18650 cells, so they would still be useful in the present, and for that I’d rather have the narrower of the 2.
But maybe a 26650 version of a C8 or an SP33-like flashlight will make into my collection someday
I’m sure there is or will be. Companies can add protection circuitry to any battery type. Acebeam has a protected 20700 in their L30 light. It is about 74mm long, though.
Oddly enough, within a couple of hours of my ordering the Samsung 30T from IMRBatteries I got an email from them pushing this new cell. So it’s a brand new arrival with limited stock. The point really is that the new 21700 is taking off and they’re becoming available in many different brands now.
If Sofirn were to make the C8F in a 21700 format and supply a cell with it like they did the 18650 triple then it really wouldn’t be an issue of availability as it would come ready to go.
I change virtually all my lights anyway, so cell compatibility is really not a concern of mine.
Not sure protection circuits would work well on a high discharge cell of this caliber unless they have cababilites out there that they haven’t been using to date. With 50A and more on tap, the protection circuit would possibly be highly prone to failure. Not exactly sure how that works.
Hey everybody, just a heads up…. in case someone is thinking about these new Samsung 30T cells, be careful! They are POTENT! Like, wicked monster potent!
I built my triple XHP-70.2 from scratch, right? Found the best results with iJoy 21700 cells at some 32.2A at the tail for 18,940 lumens. I was really stoked about that, but I got the Samsung 30T’s today and all I can say is Dayum! These things will kill a lot of lights, I’m telling ya, fresh charged they did 48.8A in this light for a whopping 21,631.5 lumens!
Pretty sure they will damage lesser emitters than the 70.2’s, well ok, they’ll kill most emitters. Just saying beware that they are beasts and proceed with caution if you decide to get these, ok?
