I can only see one place that has them and they are $18 each!
Once they start being imported in larger quantities I’m sure the price will go down. You know all the vapers are gonna want them. Lol
I hope they dont burn up your 70.2’s. I would be afraid to run them in my L6 with single 70.2 and FET. You have 3 emitters, so maybe you have more safety margin.
It looks like the 48G would be the better choice in a Sofirn C8F at about $9 each. Frankly all these 21700 are pretty pricey. It’s off putting, but once you buy it you’ll forget all about the expense. Lol
Actually Liitokala 50A delivers less current than Keeppower (really: PLB) “6000 mAh”.
BTW, I’m dreaming of PLB tech in 32650 cell…that would be like 8800 mAh at low currents and 8300 mAh at high.
I think maybe Jason hit on something we should think about here. If the new breed of 21700 can deliver TOO much, would it blow emitters in the Sofirn C8F triple?
So if the light is made FOR the 21700 size then it might be somewhat more difficult to find cells that perform LOWER, would be a lot easier and safer all around to have the light made for 26650 and when we mod we could take measure to prevent over-current if we plan to use the top 21700’s.
It has very unusual springs and battery sleeve to size down. If such a thing as a protected button top 21700 were to exist i’m not sure this would be compatible without changing the springs. By doing that you probably lose out on 18650 flat tops or may run into drop disconnects? I guess the point i’m trying to make is that for you and I this is clever and makes a flexible host but for a ready made light it’s sort of like a jack of all trades master of none. To be fair it does work well with flat top 21700 and flat top 18650 as is.
I suspect when I end up modding this light in the future I will choose springs which fit 21700 really well and if it ends up breaking other compatibility then so be it. I’d rather have a light that does one thing really well.
Your argument makes a lot of sense, considering a product released, you’d have to count on batteries available in the present, and for higher capacity 26650s still win
Yet my preference still lies with “aspect ratio” and portability. I don’t have any 26650 flashlights, but I have a C8 and it feels like it’s on the upper end of the size of flashlight I’d purchase. Both 26650 and 21700 sized tubes would fit our current 18650 cells, so they would still be useful in the present, and for that I’d rather have the narrower of the 2.
But maybe a 26650 version of a C8 or an SP33-like flashlight will make into my collection someday
I’m sure there is or will be. Companies can add protection circuitry to any battery type. Acebeam has a protected 20700 in their L30 light. It is about 74mm long, though.
Oddly enough, within a couple of hours of my ordering the Samsung 30T from IMRBatteries I got an email from them pushing this new cell. So it’s a brand new arrival with limited stock. The point really is that the new 21700 is taking off and they’re becoming available in many different brands now.
If Sofirn were to make the C8F in a 21700 format and supply a cell with it like they did the 18650 triple then it really wouldn’t be an issue of availability as it would come ready to go.
I change virtually all my lights anyway, so cell compatibility is really not a concern of mine.
Not sure protection circuits would work well on a high discharge cell of this caliber unless they have cababilites out there that they haven’t been using to date. With 50A and more on tap, the protection circuit would possibly be highly prone to failure. Not exactly sure how that works.
Hey everybody, just a heads up…. in case someone is thinking about these new Samsung 30T cells, be careful! They are POTENT! Like, wicked monster potent!
I built my triple XHP-70.2 from scratch, right? Found the best results with iJoy 21700 cells at some 32.2A at the tail for 18,940 lumens. I was really stoked about that, but I got the Samsung 30T’s today and all I can say is Dayum! These things will kill a lot of lights, I’m telling ya, fresh charged they did 48.8A in this light for a whopping 21,631.5 lumens!
Pretty sure they will damage lesser emitters than the 70.2’s, well ok, they’ll kill most emitters. Just saying beware that they are beasts and proceed with caution if you decide to get these, ok?
Barkuti, these are XHP-70.2 emitters, making them 6V. So there are 2 cells in series. So even if you’re talking that kind of sag it’s crazy watts for sure! I have a $25 Tofty switch in it so if anything is going to withstand the current this one should do… I was still scared to run it very long though, blew me away seeing 48.8A on my meter. Gotta get used to the idea before I just whale away at it.
Let me shine it in your face from 6’ away, we’ll see what you buy into…
I set it up with my son videoing and ran amperage while on the light box. It started at 47.3A for 20,148 lumens and in 45 seconds dropped to 45.8A at 14,455.5 lumens. The gold plated banana plugs on the ends of my 6” long 12Ga loop were about to burn my fingers. The big TeCu head was too hot to touch coming off the light box. Remember, this head started out in excess of 3 pounds of copper. Current was really amazingly stable once it dropped that first bit, I just couldn’t hold the leads on anymore.
I’m assuming output was dropping from the excessive heat on the emitters…
Correction: I transposed what I saw at the end of the video incorrectly… it dropped from 47.3A to 41.9A, from 20,148 lumens to 15,801 lumens.
