Interested K30.
DQG 10220 XP-G2 Stainless Steel 120LM Mini LED Keychain Flashlight
Use coupon code 5f069b to lower the price from $30.95 to $23.99 (-$6.96)
- max 120lm
- 3 modes: 3.5lm, 15lm and 120lm
- cool white, neutral white and warm white tint options
- max runtime: 15-20h
- negligible size: 37mm(L) x 12.8mm(D) (1.46” x 0.5”)
- battery is included
” DQG Tiny AA XP-G2 Stainless Steel 230LM 3Modes EDC Mini LED Flashlight”:https://www.banggood.com/DQG-XP-G2-R5-180LM-3Modes-EDC-LED-Flashlight-AA14500-p-970068.html?ut_design=23&utm_source=bbs&ut_medium=Mail_mailad299_dealalert&ut_campaign=newsletter-emarsys&utm_content=chendongling&p=W813173278221201512Y&utm_medium=petemer&scm_src=email_2816263&scm_eh=f591cf431b7dfb139&scm_llid=911692&scm_lid=81126357&scm_uid=e9d1xZu603&ems=e9d1xZu603_911692_3864722_23
Use coupon code 27c6fb to get 27% off ($7.01 /$7.82)
3 tints options are available: Cool White, Neutral White and 90CRI warm white.
Very limited stock - only a few pieces in each tint available!
- can use both AA primary/NiMh and 14500 li-ion
- max 230lm (li-ion)
- max runtime: 60h
- 3 modes: 2.5lm, 40lm, 230lm (li-ion)
- tail stand ability
- extremely small (for AA): 16.5mm x 17.5mm x 67mm / 0.65” x 0.69” x 2.64 (body diameter x head diameter x length)
- only 32g (1.13oz)
BlitzWolf® BW-ET1 XP-L V6 750LM Stepless Dimming Mini EDC LED Flashlight 14500/AA
use coupon code: 51517a to lower the price from $39.95 $22.99 to just $12.87 (-$10.12 / –44%)
Extension tube available separately here:
BlitzWolf® BW-ET1 LED Flashlight Extension Tube for 2xAA
for $1.99 or $1.59(VIP5) - $1.69 (VIP0/1) using BG points.
How can I get the ext tube for $1.99? It’s showing $3.99 (I’m VIP2) Do I need to use points? How many would I need to use?
DQG 4th Tiny 18650 XM-L2 850LM Smallest LED Flashlight Black
Coupon code with discount is available.
» Request via PM here«
Niwalker Nova MM18 emitters 2 X MKR And 1 X XM-L2 5120LM LED Flashlight
$1.99 is the price in china warehouse - you are probably checking some local BG warehouse.
If you’re VIP2 you can use 32BG points to lower the price to $1.67
Rofis R3 XM-L2 U3 1250LM Magnetic Charging Adjustable-angle Head LED Flashlight Headlamp
Coupon code with nice discount is available.
The “silver” BLF A6 flash sale is worth mentioning/checking out.
Can you inquire please about the NW version of this?
Definitely.
BLF A6 XPL 1600LM 7/4modes Non-anodized EDC LED Flashlight 18650
It’s now in flash sale for $17.99
Offer expires in 5 days and 22 hours.
Astrolux S41 4x Nichia 219B/XP-G3 A6 1600Lumens Mini LED Flashlight
It’s right now in flash sale for only $23.69.
Offer expires in 4 days and 16 hours.
Additional 18650 body tube to achieve light full potential with high current 18650 cells is available here(now in black, blue and red):
Astrolux S41/Astrolux S1/BLF A6 LED Flashlight 18650 Body Tube for $3.29 or with BG points for:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$2.80 |
$2.76 |
$2.73 |
$2.70 |
$2.63 |
Any current deal for 14500 Li-on battery?
Yes - I will add deals in few minutes.
KeepPower 14500 840mAh Protected Rechargeable li-ion Battery
Use coupon code bcnlxk to lower the price from $7.99 to $6.95
2pcs KeepPower P1450C 3.7V 800mAh Protected Rechargeable 14500 Li-ion Battery
Use coupon code 8a955d to lower the price from $9.99 to $8.49
10pcs MECO 3.7V 1200mAh Rechargeable 14500 Li-ion Battery
Use coupon code bcnlxk to lower the price from $17.99 to $15.65 (~1.57/pc)
Attention: don’t expect those to be really 1200mAh - this is not possible. They are more like half the stated capacity. They should be ok for low power requirement applications but for high power flashlights this will neither give decent runtime nor amount of light.
Acebeam X80 19LEDs 25000Lumens 11Modes Super Brightness UV LED Flashlight
Coupon code with substantial discount is available.
- 15 × Cree XHP50.2 (White)
- 2 × Cree XP-E2 R2 630nm (Red)
- 2 × Cree XP-E2 G3 530nm (Green)
- 2 × Cree XP-E2 B4 475nm (Blue)
- 1×Nichia 276A 365nm (UV)
- max 25000lm (White light)
- min 80lm (White light, 52 hours)
- 270lm Red
- 350lm Green
- 170lm Blue
- 4×18650 cells included
AMUTORCH New JM70 XPL HI 1200LM Magnetic Charge Dual-switch Long-rang 1027m Searching LED Flashlight
