Review: ROFIS MR70
@Rofisflashlight
Any idea when the MR70 will be back in stock at Banggood?
Thanks
Sorry,I do not know .you need contact Banggood sales.
You can buy on many platforms if you can not wait for it, like Amazon, eBay, Aliexpress, and so on
Is this light out yet? Would love to review one in the Dangerous Place!
Yes. Banggood is out of stock until April 5th. Rofis MR70 XHP70.2 CW+XP-G2 NW 3500LM Dual Light Multifunction Rechargeable LED Flashlight +26650
https://banggood.app.link/5wI5a6x7vL
Amazon has them right now.
My MR70 arrived today. What a great light. I just ordered a second one. Very unique design with tons of utility.
I like it … :slight_smile:
Nice reviews. One ordered!
Hi JasonWW,
I’m interested in this light. I was wondering if the emitter pcb can be easily swapped?
I might want to mod mine with a NW Xhp70.2 emitter.
Thanks
Don’t look to me, I don’t know anything about this light.
In theory, they are probably using a common 20mm DTP copper star. We need to get confirmation on that. Maybe someone has looked?
If so, then it should be pretty easy to swap it. Just undo the bezel and take out the reflector. Unsolder the 2 wires and undo any anti rotation screws. It will pop out.
I dont know any places near Africa that sells emitters mounted to stars so you’ll probably need to order a new one from China. Maybe Kaidomain. We also need to figure out if it is 6 Volt or 12 volt.
This is just basic emitter swapping stuff and is not specific to this light.
Getting the emitter and star is not an issue, MTN ships to SA, tried and trusted. I’m planning on buying a few items in the not too distant future, so now I’m bargaining on someone who owns one to open it and tests it.
Do you perhaps know of someone in the forums who owns one?
Hi weklund,
I see you already own a MR70! Are you perhaps willing to open the bezel of your light and perhaps test the voltage across the emitter and maybe post a picture of the star? :question:
Best light made to date?
Has anyone taken any amp draw measurements across the tail cap, yet?
How long does it hold turbo? The chart makes it look like 1 minute or so.
I got 70 seconds on Turbo but it wasn’t hot so I knocked it back up.
Sometimes turbo stepping down early can be a good safety thing. In red hot conditions sometimes a timed turbo can outlast a turbo set to 50c stepdown etc.
Hi,
I seem to get only 1-3 seconds before stepping down from turbo. What can I be doing wrong? Or could it be the battery?
Probably the battery. Is it fully charged?
It was, but I just charged it fully and now it’s better, but it was only down 1/3 or so.
What is your definition of 1/3?
Being a boost driver, it pulls a lot of current from the battery. I’m told the stock battery has a protection circuit added on and those typically cause extra voltage sag.
For the longest usage of turbo you need a good high drain unprotected battery. A Liitokala 5000 or Shockli 5500 for instance.
I totally agree. I have a Wuben T102 Pro and it came with a protected cell. I inserted my unprotected Shockli 5500 mah cell and it was an instant performance increase. Not sure if the Rofis cell is protected because I’m still waiting for mine. The South African postal service is on strike AGAIN so further delays. Fuuuuuu*#!
The bundled cell of MR70 is actually an unrpotected PLB INR26650-55A (yes, a simple re-wrap), which is, the same cell core used in Shockli 5500mAh. I’m a bit surprised that no one ever pointed this out…
This is odd, I was told this:
From this post.
I found a picture with the stock orange battery next to a unprotected KeepPower and they look the same length.
So I’m not sure what to think. Maybe Rofis uses 2 different batteries, one protected and one not?
