$1.99 is the price in china warehouse - you are probably checking some local BG warehouse.
If you’re VIP2 you can use 32BG points to lower the price to $1.67
Rofis R3 XM-L2 U3 1250LM Magnetic Charging Adjustable-angle Head LED Flashlight Headlamp
Coupon code with nice discount is available.
» Request via PM here«
The “silver” BLF A6 flash sale is worth mentioning/checking out.
Can you inquire please about the NW version of this?
Definitely.
BLF A6 XPL 1600LM 7/4modes Non-anodized EDC LED Flashlight 18650
It’s now in flash sale for $17.99
Offer expires in 5 days and 22 hours.
Astrolux S41 4x Nichia 219B/XP-G3 A6 1600Lumens Mini LED Flashlight
It’s right now in flash sale for only $23.69.
Offer expires in 4 days and 16 hours.
Additional 18650 body tube to achieve light full potential with high current 18650 cells is available here(now in black, blue and red):
Astrolux S41/Astrolux S1/BLF A6 LED Flashlight 18650 Body Tube for $3.29 or with BG points for:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$2.80 |
$2.76 |
$2.73 |
$2.70 |
$2.63 |
Any current deal for 14500 Li-on battery?
Yes - I will add deals in few minutes.
KeepPower 14500 840mAh Protected Rechargeable li-ion Battery
Use coupon code bcnlxk to lower the price from $7.99 to $6.95
2pcs KeepPower P1450C 3.7V 800mAh Protected Rechargeable 14500 Li-ion Battery
Use coupon code 8a955d to lower the price from $9.99 to $8.49
10pcs MECO 3.7V 1200mAh Rechargeable 14500 Li-ion Battery
Use coupon code bcnlxk to lower the price from $17.99 to $15.65 (~1.57/pc)
Attention: don’t expect those to be really 1200mAh - this is not possible. They are more like half the stated capacity. They should be ok for low power requirement applications but for high power flashlights this will neither give decent runtime nor amount of light.
Acebeam X80 19LEDs 25000Lumens 11Modes Super Brightness UV LED Flashlight
Coupon code with substantial discount is available.
- 15 × Cree XHP50.2 (White)
- 2 × Cree XP-E2 R2 630nm (Red)
- 2 × Cree XP-E2 G3 530nm (Green)
- 2 × Cree XP-E2 B4 475nm (Blue)
- 1×Nichia 276A 365nm (UV)
- max 25000lm (White light)
- min 80lm (White light, 52 hours)
- 270lm Red
- 350lm Green
- 170lm Blue
- 4×18650 cells included
AMUTORCH New JM70 XPL HI 1200LM Magnetic Charge Dual-switch Long-rang 1027m Searching LED Flashlight
Coupon code with discount is available.
Do not buy this battery! The actual capacity I measured is ~340 mAh :exclamation:
Using what current? Reviews on product page are claiming this battery is between 500 - 700mAh.
Did you get your money back?
Use coupon code 5b2f84 to get another 12% off (light is already discounted by 12%) - final price drops to $21.11
- max 1200lm
- 2x18650 3000mAh cells included
- ~4h runtime in high mode
- 4 modes: 3 constant + flash
- USB rechargeable
- aluminium alloy body with HAIII
- LED battery level indicator
Rofis TR20 Xp-l Hi V3 1100LM Rechargeable LED Anglelight Flashlight
Use coupon code 0f5529 to get $49.99 price (-$14.96)
Xiaomi Mijia Wowstick Wowpad 2 Magnetic Screw Pads Position Plate Remembrance Mat Repair Tool
It’s now in flash sale discounted from $9.59 to $3.99
Offer expires in 4 days and 15 hours.
It’s now in flash sale discounted from $9.99 to $5.55
YIHUA 995D 2 In 1 Soldering Station Hot Air Gun Soldering Iron Repair Desoldering Welding 110V/220V
Use coupon code 9061b0 for additional $13.67 discount (it’s already discounted by 24%) to get the final price of $122.99 (was $178.87)
