Texas_Ace BLF Calibrated Lumen tube / Sphere No math skills needed - Several spheres still available
1514 posts / 0 new
Texas_Ace
Texas_Ace's picture
Last seen: 1 day 23 hours ago
12-05-19 – The Group buy is complete but I found I have enough spare parts to build a few extras if I order the missing parts, they are still for sale, PM me for details.
Ok, I have had several people ask me if I can make them a lumen Tube / Sphere like mine in recent times. My first sphere was simply too much work (literally months to get it calibrated) to make this possible.
Then the other day when testing some 20k+ lumen flashlights. I noticed that my sphere was starting to melt slightly.
So I decided I needed to make a replacement while this one still worked as a standard to calibrate the new one from. I had also been thinking of improvements for some time and finally got my hands on the right materials and tools to make this possible.
And thus, the Texas Ace integrating Lumen Tube was born!
It uses all the same principles from my earlier thread on lumen spheres
The only real change is in the diffuser. Instead of foam this time I am using some laser cut diffusing sheets that fit perfectly inside the PVC pipe. This makes it much more consistent and repeatable. Interestingly the direction you insert the sheets has a noticeable effect on the readings.
I also put another sheet between the 2nd PVC connection to further spread out the beam to remove any bias for throwers or other lights that these type of spheres can have issues with. The end result is a perfectly smooth wall of light hitting the meter. I fine tune the readings with magic
The best part of all about this sphere is that unlike every other sphere I have ever seen, the lumens will be displayed directly on the meter!
You will not have to run the lux meter readings through one or more calculations just to see what the lumen reading is, you simply stick the light in there and read the lumen directly on the meter. When I am taking dozens or even hundreds of readings a day this is a lifesaver.
In this picture the light is putting out 193 lumens, this same light and mode reads around 195-196 on my old sphere for reference. I can get that closer but have just not had the time with all the mt09R mods and frankly don’t care since I only give it a ~10% accuracy rating anyways.
So I am planning on making a 1 time batch of these spheres. They will all be calibrated by me with my sphere so the readings will be comparable.
These spheres will come with everything in the pictures
The PVC tube itself, able to fit up to ~89mm reflector lights
HS1010A Lux meter like mine
a range of centering rings for different size lights
calibrated to match my sphere within ~5-10% or so (to give some wiggle room since it is impossible to get things perfect)
I have tested this sphere with lights up to 25,000 lumens and it should in theory be able to read well over 100,000 lumens if the light would fit in the tube, although you would have to worry about melting something at that power level.
Ask anyone that has tried to calibrate a sphere from scratch, it is way harder then it sounds. My sphere took me 6+ months and countless lumen readings before I was happy with the readings.
The lumen tube is far from my idea, The credit for the basic lumen tube setup belongs with BLF members from long before my time.
Making it an “integrating lumen tube” by adding the diffusing sheets and the centering rings to make the readings more consistent light to light was simply my evolution of the idea.
The addition of diffusing disks inside the tube also vastly improve the consistency from light to light and removes the advantage that throwers have classically had in PVC light meters.
Thanks to JasonWW for the illustration.
Edited by: Texas_Ace on 12/05/2019 - 15:33
Texas_Ace
Texas_Ace's picture
1-9-19 – The Group buy is complete but I found I have enough spare parts to build a few extras if I order the missing parts, they are still for sale, PM me for details.
$175 – 3.5” version List:*
1- Texas Ace
2- shirnask – 3.5” – Paid – Shipped
3- steel_1024 – 3.5” – Paid – Shipped
4- emarkd – 3.5” – Paid – Shipped
5- Terry Oregon – 3.5” – Paid – Shipped
6- slimkango – 3.5” – Paid – Shipped
7- peabody – 3.5” – Paid – Shipped
8- charles lin – 3.5” – Paid – Shipped
9- JasonWW – 3.5” – Paid – Shipped
10- Krash610 – 3.5” – Paid – Shipped
11- John-Galt – 3.5” – Paid – Shipped
12- Blazer296 – 3.5” – Paid – Shipped
13- teacher – 3.5” – Paid – Shipped
14- WillyD – 3.5” – Paid – Shipped
15- miswas – 3.5” – Paid – Shipped
16- Muto – 3.5” – Paid – Shipped
17- scannerguy1968 – 3.5” – Paid – Shipped
18- nechronius – 3.5” – Paid – Shipped
19- leroycp – 3.5” – Paid – Shipped
20- Dividedhead – 3.5” – Paid – Shipped
21- lights_and _pieces – 3.5” – Paid – Shipped
22- Lumens Industry – 3.5” – Paid – Shipped
23- Bob_McBob – 3.5” – Paid – Shipped
24- inrealtime – 3.5” – Paid – Shipped
25- Ozythemandias – 3.5” – Paid – Shipped
26- beam0 – 3.5” – Paid – Shipped
$235 – 4.5” Version list:*
1- SKV89 – 4.5” – Paid – Shipped
2- Newlumen – 4.5” – Paid – Shipped
3- Newlumen – 4.5” – Paid – Shipped
4- Newlumen – 4.5” – Paid – Shipped
5- staticx57 – 4.5” – Paid – Shipped
6- Micael – 4.5” – Paid – Shipped
7- KawiBoy1428 – 4.5” – Paid – Shipped
8- jmm244 – 4.5” – Paid – Shipped
For a 6” version the cost is extreme, which is why I did not even consider it before. It would be ~$375 + shipping, which would not be cheap at all, it would be a massive box and take up a ton of space and weigh a lot as well. Although the option is on the table if someone is interested.
I really like the 3.5” version myself, it fits most lights and does not take up a ton of space.
So I will assume everyone on the list wants the normal 3.5” version unless you tell me otherwise.
Texas_Ace
Texas_Ace's picture
I can ship these internationally as well, contact me for a quote.
Also these have been tested from ~5 lumens to ~25,000 lumens and should be able to read over 100,000 lumens if the PVC didn’t melt lol.
All of the LED tests in my signature were done on my sphere like this.
shirnask
shirnask's picture
Last seen: 18 min 47 sec ago
I’m in for one
SKV89
Last seen: 50 min 15 sec ago
Im in for one. Is it large enough for a big head like blf gt?
Ozythemandias
Last seen: 1 month 1 week ago
In
DavidEF
DavidEF's picture
Last seen: 1 day 21 hours ago
Maybe it’s not really important, but it might be nice in the interest of full disclosure to say in the OP that the “integrating pipe” is not your original idea. Others have been doing it for years. Although, I’ve not seen it done with diffuser material like you have. Thanks for offering this to the community!
- The YKK Philosophy
Texas_Ace
Texas_Ace's picture
Updated the list.
Sadly no, even 4” PVC is not big enough for the GT and getting larger is very very expensive and somewhat hard to find locally. I considered stepping up to that size myself but it was just not worth 4x+ the price.
This can support up to a 3.5” (~89mm) light, which I find covers the vast majority of lights I want to measure. Thus far the GT is basically the only light I have had that would not fit, the TN42 would be just over as well but I don’t have one.
If someone wants a custom larger sphere setup with larger PVC I can do this, it will just cost much more.
Texas_Ace
Texas_Ace's picture
Yes, the lumen tube is far from my idea, I never intended for it to sound like it was.
saypat
saypat's picture
Last seen: 11 min 23 sec ago
I do not know how Texas_Ace can get so much done, has he cloned himself?
Very thankful to have him and his services in our Forum!
leroycp
Last seen: 5 days 21 hours ago
In
DavidEF
DavidEF's picture
Grad Thumbs Up
blueb8llz
Last seen: 1 hour 37 min ago
Out of curiosity for me and maybe others. How much would the lumen tube cost us for the bigger version to accommodate the blf gt? I don’t think this will be the last time companies will be making heads this large. I already have a few lights from acebeam and thrunite that are 4 inch. I believe olight and manker will also release some large head lights.
cellguy
cellguy's picture
This looks very neat! I definitely do not NEED one, but the WANT is strong! Must think…
Current Favorites:
BLF Q8, Thrunite TC20, Convoy L6
steel_1024
steel_1024's picture
Last seen: 5 days 50 min ago
+1
Sorry for my poor english.
teacher
teacher's picture
Last seen: 7 months 4 weeks ago
Thanks TA!! Sign me up please. Thumbs Up
Bob_McBob
Last seen: 21 hours 24 min ago
Is this design useable with right angle lights?
chops728
Last seen: 8 hours 48 min ago
Vry Nice—-I’ve been using DC Fix in my light tube—-I still have a multiplying factor but my results are much more reliable and consistant
Texas_Ace
Texas_Ace's picture
Hmm, that is a good question. I know the PVC itself was several times the price. If there is interest I will go to a specialty plumbing supply store and see how much it would cost.
Remind me to check into this if I forget, this week is going to be VERY busy for me.
Texas_Ace
Texas_Ace's picture
Just let me know if you want me to add you to the list. If you end up sending me the L6 to mod I could ship them back together.
Texas_Ace
Texas_Ace's picture
It should be, you only need the very tip of the light sticking through the centering ring for it to work. In fact sticking the light in even 1/2” too far can have a pretty noticeable effect on the readings.
Texas_Ace
Texas_Ace's picture
Indeed, this version does seem slightly more consistent then the foam I used before and way WAY better then using nothing like I tried at first.
cellguy
cellguy's picture
You are definitely getting the L6. 8500 lumens is too good to pass up!
Current Favorites:
Bob_McBob
I am thinking of designs like the Armytek Wizard where the cooling fins protrude in front of the bezel, preventing it from lying flat on a diffuser.
SKV89
Yea I also want to know because I’m interested in the upcoming Astrolux MF03, MF04, MF05, TN42VN, and Acebeam X70 or whatever other high power lights might be coming out.
Texas_Ace
Texas_Ace's picture
!{width:100%}https://i.imgur.com/XuP3KDf.jpg!
It will not seal perfectly but it should still give a reasonably close reading. You will just need to add a little bit for the light that escapes due to an imperfect seal. After some experience with the tube you will figure out a reasonable amount to add by playing with other lights of similar output and pulling them out of the tube slightly.
Texas_Ace
Texas_Ace's picture
Ok, I will look into it. I don’t think I will get time to do this until Friday at the earliest, Remind me tomorrow if you can. I will be silly busy the next few days.
Bob_McBob
How about a spare diffuser ring with a custom cutout for the fins so it lies flat? I’m mostly curious because I do a ton of testing with modded Armytek headlamps so it’s worth the extra effort to me.
Newlumen
Newlumen's picture
Last seen: 2 days 19 hours ago
I will take one. Thanks.
sp5it
sp5it's picture
Last seen: 19 min 37 sec ago
100$ for a PVC pipe does not sound budget to me. I’ll pass that one.
Mike
Think of how stupid the average person is, and realize half of them are stupider than that. George Carlin
 Anyone offended by my signature please fill Complaint Form. Thank you.
Narmattaru
Narmattaru's picture
Last seen: 1 day 8 hours ago
i tried to use the same, but without diffusor.
may be some semi-transparent paper will work, have to check.
problem here was such – it felt like low brightness was really not precise.
have you checked low bright modes there? are they also precise like higher ones? if yes, i have to test my tube over again.
"How to choose flashlight, Main things in simple words":http://budgetlightforum.com/node/68418
