Texas_Ace BLF Calibrated Lumen tube / Sphere No math skills needed - Several spheres still available
In
Maybe it’s not really important, but it might be nice in the interest of full disclosure to say in the OP that the “integrating pipe” is not your original idea. Others have been doing it for years. Although, I’ve not seen it done with diffuser material like you have. Thanks for offering this to the community!
Updated the list.
Sadly no, even 4” PVC is not big enough for the GT and getting larger is very very expensive and somewhat hard to find locally. I considered stepping up to that size myself but it was just not worth 4x+ the price.
This can support up to a 3.5” (~89mm) light, which I find covers the vast majority of lights I want to measure. Thus far the GT is basically the only light I have had that would not fit, the TN42 would be just over as well but I don’t have one.
If someone wants a custom larger sphere setup with larger PVC I can do this, it will just cost much more.
Yes, the lumen tube is far from my idea, I never intended for it to sound like it was.
Making it an “integrating lumen tube” by adding the diffusing sheets and the centering rings to make the readings more consistent light to light was simply my evolution of the idea.
I do not know how Texas_Ace can get so much done, has he cloned himself?
Very thankful to have him and his services in our Forum!
In
:student: :+1:
Out of curiosity for me and maybe others. How much would the lumen tube cost us for the bigger version to accommodate the blf gt? I don’t think this will be the last time companies will be making heads this large. I already have a few lights from acebeam and thrunite that are 4 inch. I believe olight and manker will also release some large head lights.
This looks very neat! I definitely do not NEED one, but the WANT is strong! Must think…
+1
Thanks TA!! Sign me up please. :+1:
Is this design useable with right angle lights?
Vry Nice—-I’ve been using DC Fix in my light tube—-I still have a multiplying factor but my results are much more reliable and consistant
Hmm, that is a good question. I know the PVC itself was several times the price. If there is interest I will go to a specialty plumbing supply store and see how much it would cost.
Remind me to check into this if I forget, this week is going to be VERY busy for me.
Just let me know if you want me to add you to the list. If you end up sending me the L6 to mod I could ship them back together.
It should be, you only need the very tip of the light sticking through the centering ring for it to work. In fact sticking the light in even 1/2” too far can have a pretty noticeable effect on the readings.
Indeed, this version does seem slightly more consistent then the foam I used before and way WAY better then using nothing like I tried at first.
You are definitely getting the L6. 8500 lumens is too good to pass up!
I am thinking of designs like the Armytek Wizard where the cooling fins protrude in front of the bezel, preventing it from lying flat on a diffuser.
Yea I also want to know because I’m interested in the upcoming Astrolux MF03, MF04, MF05, TN42VN, and Acebeam X70 or whatever other high power lights might be coming out.
