Texas_Ace BLF Calibrated Lumen tube / Sphere No math skills needed - Several spheres still available
1500 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 2 hours 29 min ago
sp5it wrote:
100$ for a PVC pipe does not sound budget to me. I’ll pass that one.
Mike
You are not just paying for materials, you are also paying for knowledge, experience and calibration.
The fact that several people will have the same design calibrated so closely to one another also means that flashlight reviews from them can contain accurate lumen readings. Multiple people owning these means more models of flashlights can be tested. This is good because you can’t expect just a few people around the world with high end and expensive spheres to be able to test every light that comes out.
Besides, the more professional ulbricht spheres cost thousands of dollars. $100 is much more affordable for the more serious flashlight hobbiests.
Ps, plus it can measure a huge range of output. From at least 150 lumen to 25k lumen. It’s easy to use and there is no math involved. Flooder and throwers don’t matter. That’s pretty awesome in my eyes.
Texas Ace Lumen Tube calibrated with Maukka lights
Click this to go to signature links.
Texas_Ace
Texas_Ace's picture
Last seen: 1 day 1 hour ago
Bob_McBob wrote:
Texas_Ace wrote:
It will not seal perfectly but it should still give a reasonably close reading. You will just need to add a little bit for the light that escapes due to an imperfect seal. After some experience with the tube you will figure out a reasonable amount to add by playing with other lights of similar output and pulling them out of the tube slightly.
How about a spare diffuser ring with a custom cutout for the fins so it lies flat? I’m mostly curious because I do a ton of testing with modded Armytek headlamps so it’s worth the extra effort to me.
It is possible I could 3D print up a custom ring that could be used for this if they all have the same size head. Can you get me a measurement of whatever edge you would want the light to seal to?
Texas_Ace
Texas_Ace's picture
Narmattaru wrote:
i tried to use the same, but without diffusor.
may be some semi-transparent paper will work, have to check.
problem here was such – it felt like low brightness was really not precise.
have you checked low bright modes there? are they also precise like higher ones? if yes, i have to test my tube over again.
I have been using my sphere for almost 2 years now and have not had any issues at low or high brightness. It took a LOT of work to get it to the point though. Easily 6 months calibrating and tweaking the design. It looks simple now but there were dozens of versions before this.
I would not take it’s numbers down at at 5 lumens and less to be perfect but that is the price that is paid to allow for lights over 25k lumens to be measured. It will still register moon mode on most lights though.
This latest design should be even better since the diffusing sheets are much more ideal for this.
Also, all the LED tests in my sig were done with my sphere like this, so there is a pretty good dataset on it already as well.
Man Without Shadow
Man Without Shadow's picture
Last seen: 12 min 23 sec ago
sp5it wrote:
100$ for a PVC pipe does not sound budget to me. I’ll pass that one. Mike
Yes, it is not “budget”, nor is it a necessary tool for many of us.
But it IS a Texas Ace built and calibrated tool for accurately reading the output of various flashlights. The materials (including a measuring device—Lux meter), versatility, construction, calibration, accuracy, and work put into this device will justify it’s cost to those of us who desire accurate light output measurements with minimal hassle.
If Texas Ace is building it, you can count on it’s quality. I suspect the materials alone will be close to his costs and a small percentage will go to pay for his time and expertise.
In that regard, it may not be “budget” but it will definitely be a “bargain” for what those customers receive.
I suspect many would rather spend $100 on an awesome flashlight…and he makes those too!
When I'm spending mony foolishly, I like to do it wi$ely...
I have all the flashlights I need, but not as many as I want...
scannerguy1968
scannerguy1968's picture
I’ll take one. Would be great for all the reviews I do on youtube.
Someday I'll invent something worthwhile
miswas
I'll take 1.
T_A, that's some fine engineering and tuning work you've done there! Smile   Congratulations on making a precision instrument from something that took a little "black magic" to just come close to actual numbers.  Again, well done!
-Ben
-Ben Walker
miswas
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 33 min ago
Where is the list T/A/ Sign me up, I’ll take (1) please. Thumbs Up
KB1428 “Live Life WOT
Texas_Ace
Texas_Ace's picture
Thanks, making the first sphere was a labor of love for sure. Many many times I wanted to just give up but then I would get a new light and want to know how much I was being lied to and would keep trying.
The naked LED tests were a key part of the setup and testing, it really improved the ability to get good numbers across the board when I did those and applied what I learned from them.
I will most likely use some naked LED’s on my bench for calibrating a lot of these since they are much more stable in output then most lights due to the stable input power and massive heatsink.
I think I have everyone added to the list up to now, let me know if I missed anyone.
SKV89
Last seen: 1 min 47 sec ago
Considering lawyers and engineers charge a couple hundred dollars an hour for their time and expertise, paying $100 for a quality lumen measuring device that requires a huge chunk of time for R&D and the TA quality is definitely a bargain. Also material and shipping cost money so I don’t see TA making much profit for this. Remember earning profit is not an evil thing. Everybody needs to eat and live. Some people put in time and effort at their job to get paid by their employer, while some people put in time and effort to get paid by customers.
DavidEF
DavidEF's picture
Last seen: 2 hours 3 min ago
Crown Thumbs Up
- The YKK Philosophy
chops728
Last seen: 2 hours 55 min ago
Those 4” PVC street 90s are not very cheap / plus a meter with all the acc to make it a working device not to mention that free shipping we all can aquire for something that big—- $100 is a steal—you couldn’t buy mine for a $100
ToyKeeper
ToyKeeper's picture
Last seen: 24 min 6 sec ago
This looks like a good way for people to get decent measurements… and it always helps when different people’s numbers can be compared to each other.
I’ll stick with my “Integrating Milk Carton” for now though, since it’s small and seems good enough for my purposes. Smile
staticx57
Last seen: 3 min 36 sec ago
in for one
Texas_Ace
Texas_Ace's picture
This PVC has an ID of 3.5” at the opening for the light, I forgot to put this in the OP.
Newlumen
Newlumen's picture
Last seen: 22 hours 36 min ago
I will take 2 more. . One is for my brother and friend. Thanks.
teacher
teacher's picture
Last seen: 2 months 6 days ago
Mike
With due respect, this was a completely unnecessary comment you felt the need to share.
JasonWW
JasonWW's picture
teacher wrote:
Mike
It did have the benefit of people explaining why it IS such a good price. Plus maybe Mike will think it over and realize it’s not so expensive after all.
It’s not a product for everyone. It’s not like the GT where your going to have 1700 people waiting in line to buy one, but for a very small group of people, it is very worthwhile.
Speed4goal
Last seen: 10 months 6 days ago
100 dollars is a steal in my eyes I can’t afford it. But if I could I would no doubt. To be able to test my own lights. Without having to mail my lights to someone to test and have mailed back. Would be much easier to have a kit already calibrated and ready to go. And it be the same calibration as 20+ others on here it’s only a good thing. Instead of ta lumens, dzozz lumens, speed4goal lumens etc. For the most part everyones results are directly comparable
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
teacher
teacher's picture
Yep, very true! Good point…… Wink
emarkd
emarkd's picture
Last seen: 3 days 2 hours ago
In, I’ll take one
Texas_Ace
Texas_Ace's picture
Ok, just to confirm, that is 3 total correct?
Texas_Ace
Texas_Ace's picture
emarkd wrote:
In, I’ll take one
Got it, I should have it updated now.
Man Without Shadow
You need to set up an assembly line:
Texas_Ace
Texas_Ace's picture
Thats basically what I feel like right now lol. Desperately just trying to keep up.
Newlumen
Newlumen's picture
Yes.. I want 3. 100% sure. I can send deposit right now.
Texas_Ace
Texas_Ace's picture
Great, just wanted to check.
It is looking like I might need to make all 30 spheres which is going to be a much much larger investment then I planned on, so I might end up needing to take payments in advance afterall although I would prefer not to.
I will see what the grand total works out to in a week or so after people have more time to sign up.
Might also need to see if I can find another sheet of this diffusing film if this keeps up.
Newlumen
Newlumen's picture
Good idea. $100 deposit for each tube sound great.
steel_1024
steel_1024's picture
Last seen: 1 day 10 hours ago
Sorry for my poor english.
Tjhosan
Tjhosan's picture
Last seen: 8 hours 17 min ago
Any idea of what shipping to sweden would end up at?
Texas_Ace
Texas_Ace's picture
steel_1024 wrote:
https://www.amazon.com/d-c-fix-Self-Adhesive-Window-17-71-346-0012/dp/B0...
d-c-fix snow
This is what I was considering until I found these diffusing sheets. They seem to work better then the DC fix plus they fit in the PVC without a separate piece of glass.
