Gotcha, Terry, Not Dale. I think I read that Dale was at the doctorâs with his daughter? Hope sheâs doing alright, and that itâs nothing serious.
And thanks for trying to get to my light!
Ok, I got another light finished tonight. This one for Newlumen. He sent me an MT07S that came setup for 4S from the factory. First I had to convert it to 2S which was much harder then I first thought but the results were worth it.
In stock form it was doing 4700 lumens.
Now with a 2S conversion, Spring bypasses, TA driver and 5700k P2 LED it is doing a bit under 10k lumens! (It peaks over 10k for a few seconds)
It legitimately doubled the lumen output. I am quite impressed. This is the most powerful single LED flashlight I have seen to date. I knew that the XHP70.2 P! was capable of this from a cold start from my testing but never actually seen it pushed this hard in a light before.
A very quick and dirty throw test has the MT03 pulling ahead in throw by about 24% vs the MT07S.
This is to be expected, even with multi led setups the larger total reflector size is still going to generally throw further. Plus the XHP35 is a much better thrower.
Now with a dedome the MT07S should be on par or possibly even slightly ahead.
Ok, starting work on Keepitsharpâs V1 MT03. I have to agree the V1 is a step up in quality, the ano appears to be HAIII and it just feels a step up.
Before measurements with the stock xhp70 (not70.2) was 11k lumens.
I also realized this is my last 70.2 driver for the moment. I already have the components for 30 more here and the PCBâs are supposed to arrive early next week. So it should work out well with the next batch from Terry that should be arriving about the same time.
Thank you! Looking forward to the* after *numbers! This light was an early pre-order and some of the first had a few flaws. They did try hard to put a good product out.
Yes, as soon as I opened it up I noticed said flaws. Not major but existent none the less.
The biggest of which is the too short battery tube, obviously you have to be careful to get good contact with the cells but not crush them.
Ok, I just finished it up, and final numbers with 4000k 80cri LEDâs, TA driver and bypasses are just under ~21k lumens, much improved from the factory setup for sure!
I think the slightly lower numbers are from the very subpar solder used on the mcpcb connection, I tried to clean it up but it has a lot of flux mixed in and I would of had to completely strip the mcpcb and clean it and then redo it from scratch to make any real improvements.
I did not figure it was worth that much hassle for a few hundred lumens but if you want me to I can do it.
