*BLF LT1 Lantern Project* (Post #5354 Production design ready!
5496 posts / 0 new
WolfDiesel
Last seen: 3 weeks 1 day ago
I’m interested!
Wølf/Diesel™
Sonullo
Last seen: 1 year 2 weeks ago
Please add me to the list.
RobertB
RobertB's picture
Last seen: 9 hours 32 min ago
Got to keep the UI as simple as possible. TF will want to sell this to more than just flashaholics !
BazzH
BazzH's picture
Last seen: 1 month 6 days ago
Cool. Sorry for your hardship and appreciating you going on with this!
DBSAR
DBSAR's picture
Last seen: 7 hours 20 min ago
Definitely true. it needs to be user friendly for general campers, travelers, emergency preparedness, Scouts groups, mariners, remote locations, expeditions, even under-developed locations where good, bright lighting is needed. This lantern with a USB charging input, added with a simple 10-watt foldable solar charger panel can be a infinitely sustainable light source for anywhere where thee is no lighting.
DavidEF
DavidEF's picture
Last seen: 1 hour 24 min ago
Yah, but shipping from the manufacturer by default in “muggle mode” should take care of that. I don’t se why the Q8 driver couldn’t be used pretty much as-is with just the physical change from a FET to a bank of a few 7135s and the Narsil or maybe Anduril firmware, including TK’s candle and thunderstorm modes, and set to “muggle mode” out of the box.
- The YKK Philosophy
DBSAR
DBSAR's picture
Agreed, I hope to hear back with some input from DEL & Tom-E ( and the other Q8 project team) on their input if it is ok to use & incorporate the Q8 driver in the BLF lantern, and if its possible to adapt changes to the driver for the lantern, As in lowering its peak output for continuous running, any alterations to the mode & groups, (with addition of ToyKeeper’s Candle & sunset-modes, ) and at least the addition of the USB input charging capability to charge the lantern’s cells. (and maybe ad the power-Bank feature if that is feasible or not)
As of right now once the Q8 mule for the lantern arrives, I will build the new prototype using the Q8 body, parts of the head, and its driver to get a working design to go from.
ToyKeeper
ToyKeeper's picture
Last seen: 31 min 52 sec ago
The hard part is getting USB to work. And, if desired, getting the light to do constant-current output instead of PWM. I think DEL already solved the constant current bits though, and was finishing up USB.
Taking a Q8 driver and limiting its output is easy. Literally just build an already-designed FET+N+1 Q8 aftermarket driver… minus a few chips. Changing modes and UI is easy too.
litenutz
Last seen: 1 day 3 hours ago
Please put me on the list for ONE lantern.
bmengineer
bmengineer's picture
Last seen: 1 hour 6 min ago
If the board is being redesigned is there any change of using a single usb-c port in lieu of separate usb in and out? Would that end up being higher or lower in cost?
Find all my reviews of flashlights and more gear at www.bmengineer.com
DBSAR
DBSAR's picture
Difficult to know, ToyKeeper & DEL would be able to answer that better. But right now standard USB inter face is planned as most Solar chargers or power banks have not incorporated USB-C yet, and none of my Solar folding chargers or panels have USB-C. (without the need for an adapter cord, etc.) USB-C seems more practical for data devices like phones & tablets, all this lantern will need is a common USB micro plug cord to charge it from any USB power source.
g_sintornillos
g_sintornillos's picture
Last seen: 11 months 5 days ago
+1
Sorry for my bad English (gogole transtorla)
bmengineer
That’s fair – your project, your rules. It just seems to be the way every phone, powerbank, and eventually solar panel is heading in so I wanted to bring it up. Can’t wait!
Spacegrass
Spacegrass's picture
Please add me to the list! Thanks.
AgentWhiteBread
Last seen: 1 week 2 days ago
I am absolutely interested. Please put me down for +1 lantern.
DBSAR
DBSAR's picture
Right now its the cost too of USB-C interfsce because its such a new option. see how it goes with the driver designers for this project, both Toykeeper & DEL may be able ot answer that better for you.
DBSAR
DBSAR's picture
  • Interest List updated in OP Post **
timezero
I’m new to the forum, but definitely want to be put on the list (for 2)
steel_1024
steel_1024's picture
Last seen: 15 hours 41 min ago
Check #1130 please.
I am in 1
Sorry for my poor english.
DBSAR
DBSAR's picture
steel_1024 wrote:
Check #1130 please.
I am in 1
Added you to # 678 on the list Smile ( sorry i missed your original request.)
angerdan
angerdan's picture
Last seen: 6 days 17 hours ago
GreenLights wrote:
I sure hope ToyKeeper’s candle and sunset modes will be incorporated. Those little details will take this lantern, which is already going to be amazing, over the top.
Can you explain candle mode? If it’s a flickering light pretending to be a candle, it’s really annoying and shouldn’t be part of a lantern.
How’s the price difference between an USB-C socket against an microUSB socket? USB protocoll doesn’t change with that.
Is QC or PD planned to be used and wt which current can be charged?
How about using dual USB socket (USB-C & microUSB), so that the lantern will be usable even in 10 years without adapter?
What are the current plans and planned options for color temperature and red light mode?
ToyKeeper
ToyKeeper's picture
If candle mode annoys you, don’t use it. Other people really like it, though. Here’s a preview:
LG
Last seen: 2 weeks 5 days ago
Wow that is cool (the candle mode). Does that follow a predefined pattern or is it just randomized?
djozz
djozz's picture
Last seen: 2 hours 4 min ago
The Q-team, after half a year, just got a mail from Barry (our contact at Thorfire for the Q8) asking if they can do additional stuff for the Q8. In other words, Barry got out of hibernation and has his hands free to do new development work. Shall I ask him about doing the lantern, or do you already have contact with him or someone else at Thorfire?
djozz
djozz's picture
It is a bit windy around that candle Party Did you consider a more calmed down version?, I think I would use it for more than just showing off if it was calmer. (or you could add a windforce ramp to the candle-mode! Big Smile )
juhha
Last seen: 5 hours 37 min ago
Interested in 1.
Batch1
Interested in 1
BlueSwordM
BlueSwordM's picture
Last seen: 3 min 4 sec ago
BTW, @DBSAR, how about we use Samsung 351Bs 3000k R9070 instead of XP G3s?
They have excellent color reproduction, fit on XP sized pads, are more efficient than it, and are quite cheap for what they are, at 0.5$/pcs.
Here is the group buy:
http://budgetlightforum.com/node/58883
goshdogit
goshdogit's picture
Last seen: 2 hours 24 min ago
TK’s Andúril UI is amazing. I have it running on several Q8s, an EagleEye X6R, and an Emisar D4, D1, and D1S.
I burn a Q8 in candle mode quite often with a warm diffuser. It’s quite realistic in person, and even has brightness adjustment to go from candle to torch. Party
It’s random. Thumbs Up
TK has also mentioned adding a ‘sleep timer’ to candle mode. I can’t wait!
DBSAR
DBSAR's picture
I have not spoken to Barry, but would be great to talk to him on this project! send him our way. Smile
