The SYNIOSBEAM - CFT90 recoil thrower
a lot of work to get this driver done
here some pictures of the progress in cooperation with enderman
90 minutes work function block works
Upscaling to 8 circuits
a lot little things optimised
Central connecting pads added
Implementing inner layers for current conduction
Enderman wanted the connection on the back side, some minor improvements to inner layers and viases for curent transfer
After I saw this picture of mounting it I thought he is misunderstanding the colling concept with viases to the back side
So I told him to mount the driver with the back side to the case and we took thinner inductors to stay within 5mm thickness
enhaned the top and bottom ground connection as I removed the inner ground layer on a big parrt for LED+ paths
There are a ton of components on that thing…
wow
Amazing job!
The amount of ICs is just over the top! :wink:
How about the some status LEDs for the nerds? :stuck_out_tongue:
Lovely driver! Thanks for giving us a window into the design process, Lexel.
Enderman, great job on the light, and thanks for documenting it for us.
BTW, Vinh has shown his CFT-90 driver recently:
I have seen this as well, but the design seems not well cooled
He went a very easy way and simply bought a complete Constand Voltage module, externally PWMing it
Basically he put a 20A board from Mutara on top of a normal driver
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwiy1NPD3sbaAhXBLlAKHdamAD0QFggyMAE&url=https%3A%2F%2Fpower.murata.com%2Fdata%2Fpower%2Fokl2-t20-w12.pdf&usg=AOvVaw348cKN7GtTzFjlo9YErloo
He has practically all heat generating components on a slave board,
which is externally PWMing this with an external P-FET
I hope he is only PWMing low output levels with the external MOSFET to get Moonlight and get the higher Output regulated over the output voltage,
but still he is using a CV module for a CC operation which is not ideal
It uses P-FETs which are in general a lot less good than N-Types
My design has all heat generating FETs close to the edge and with at least 2 layers heat conducted to the outer diameter
Thanks you, and thanks to lexel for posting more info about how driver development process!
That’s nice, although I wanted a lot more power than 20 amps :wink:
With lexel’s driver I will be able to push the CFT90 to the limits of my watercooling system.
It has 8 dip switches on it too that allow me to change the maximum current by multiples of 6 just in case the watercooling isn’t enough for 48 amps haha
I have been following this and am amazed at the electronics and design at this level for a light!
Very impressive.
Thank you :slight_smile:
It’s probably the most complex project I’ve done, due to how limited the space is.
Had to restore my password and log in, just to compliment you on this project. Been following it, and I like it, I like it a lot!
Also have a question: What was the reason you went with a pretty thick, (1/4”?) backplate and not a thinner one?
Another thing, I saw you mentioned that something was touching the reflector edge earlier, have you solved that? Because if there is just the slightest pressure on these reflectors, it will deflect them and you get bad performance. Believe me, I know :cry:
They can report it but they’d have to find him first. That’s a large apt building with many others around. In a plane going 400+ miles per hour unless he had it on when they came around. You’d probably have better luck finding a needle in a haystack
Thank you!
The backplate holds all the electronics as well as the reflector, I though it would be nice to have it the same thickness as the tube body so that everything is the same, even though it is a bit overkill.
Better safe then sorry! Especially if this light is going to be carried around a lot.
And yeah there was a coolant tube slightly under 1/4” OD between the reflector and body which pushed the edge of the reflector and completely deformed the spot.
I had no idea they were so flexible! Luckily it caused no damage and just went back to it’s original shape, and now makes a much more clean die projection.
I replaced the tubing with some 3/16” tubing which doesn’t touch and is also softer, and now there is no problem.
PS- looking forward to your new carbon fiber superthrower :wink:
What about the GT mod with the CFT-90?Is the driver ready?And finally, is some guy ready to try this mod? Because I wait to see beamshots from CFT-90 as well as XHP70.2 leds,so as to make a decision which of the two to put in my GT, sending it to giorgoskok,(who is also a Greek member), to do the job,because I know his work from other mods he has done for me.
Yes, you do have quite a bit of stuff on the backplate, so in that regard the extra thickness certainly doesn’t hurt. And these reflectors are indeed very “springy” something I found out the hard way when I bonded one ever so slightly deformed (less than 0.5mm) and lost 50% performance, and the beam had a rectangular spot. :person_facepalming: The reflector itself was perfectly fine, but I had to return it to Phoenix and have it reinstalled.
Anyhow, I was wondering about another thing. How do you think the luminance on the CFT-90 respond to beaming light on the core, from a secondary light source? Compared to just increasing the current?
What I was thinking here, was if you installed a secondary LED in the vertex hole, with an aspheric lens, plus a bi or plano convex lens in front, and with the correct focal lenght, you could focus all the light from the secondary LED, directly on the core of the main LED. At some point, it would just overheat and burn up, but this stuff isn’t my field of expertise. Thoughts?
I will answer here:
It all depends on if you want to make the entire die brighter or just a smaller portion in the center?
Focussing an LED on such a small point will be difficult if you want high efficiency. A 450nm laser would be much easier to focus, but it’s more difficult to get a uniform beam (I have tried someting like this here, it’s in German).
If you want to make the whole die much brighter you will need a lot of blue light (similar to the CFT-90 itself). This would require much more power, big batteries, powerful cooling etc.
I don’t have a GT, I’m putting a CFT90 in this flashlight, not a GT :stuck_out_tongue:
Maybe you posted in the wrong thread?
Mhm, I specifically asked phoenix to make and install the mount for me, they did a great job.
You can double the intensity by adding more light to the core, however you lose a lot of efficiency since you would need something like 3 additional CFT90s in order to get a 2x improvement.
Similar to how a wavien collar collects an additional 75% more light and doubles the intensity.
The best option is to use lasers to excite phosphor, as they can make a very small spot of high intensity blue light.
Ok, so it does have decent potential then. In this case, I wasn’t necessarily thinking of doubling the luminance by adding extra CFT-90’s because of both power requirements and cost, but rather giving it a measurable boost by adding a less powerful and cheaper secondary LED. On the other hand, would it be worth the extra complexity? Probably not. Not sure you even have room for a lens stack like that.
Enderman, what reflector coating did you choose?
It seems yes.Mea culpa…
Haha yeah, there is like 5mm between the bottom of the reflector and aluminum plate :stuck_out_tongue:
Aluminum.
Protected silver was way too expensive and also delicate.
Rhodium is worse than aluminum and only necessary for stuff like short arcs.
