XTAR USB probe
“XTAR USB probe is specially designed by XTAR engineers, with good conductivity, perfectly connected to DRAGON VP4 Plus for testing voltage and internal resistance of battery”
http://www.xtar.cc/products_detail/productId=164.html
I did look a bit at them in my Dragon review. They do improve IR measurement significantly because some wire and connection resistance is eliminated, but they are not perfect. The probes for YR1030 & YR1035 eliminates all connection and contact resistance.
It only works with the VP4 Plus Dragon and HKJ already tested it here:
https://lygte-info.dk/review/Review%20Charger%20Xtar%20VP4%20Plus%20Dragon%20UK.html
How do you know they don’t work with other USB power meters?
From what I see they are just passive probes.
Yes, so they can be used with any USB Voltmeter. But only in the voltage range of the voltmeter.
Like the YZXStudio ZY1263.
https://lygte-info.dk/review/usbMeter%20YZXStudio%20ZY1263%20UK.html
No, the connections in the sb connector do not fit.
ISDT A4 10W 1.5A DC Smart Battery Charger
Very compact smart charger for 4 batteries
firmware can be upgraded
powered from USB 5-9V, 1,5A
Battery Size: AAA,AA,10500,12500
Battery Types: NiMH,NiCd,Li-lon,LiFePO4
11€
I like to suggest these USB power supplies:
http://www.navilock.de/produkte/1415_DC/62624/merkmale.html?setLanguage=en
http://www.navilock.de/produkte/521_Power-Supply/62950/merkmale.html?setLanguage=en
EAN’s: 4043619626243 & 4043619629503
https://www.google.com/shopping/product/10152502862511782079?prds=scoring:tps
https://www.google.com/shopping/product/16856431056906493871?prds=scoring:tps
https://www.reichelt.de/Chargers-for-USB-Devices/NAVILOCK-62624/3/index.html?ACTION=3&GROUPID=5158&ARTICLE=163004&START=0&OFFSET=16&
https://www.reichelt.de/Chargers-for-USB-Devices/NAVILOCK-62950/3/index.html?ACTION=3&GROUPID=5158&ARTICLE=214640&START=0&OFFSET=16&
Generally I like your suggestions, but there is one problem and that is money. I use a few 100$ (It is that high) each month on stuff to review and that is acceptable for me, but a lot of our suggestions would basically drain my budget for a few items (A month is nearly 31 days and I publish a review most days). If you want to pay for the item I would gladly review it, but when I have to pay for it, the number of your suggestion that get reviewed is rather low. I am sorry about that , but I do not have unlimited funds (your suggestions are usual very interesting).
On another note: I do seldom ask manufactures about review items, I do not like to beg for anything (That may be silly, but it is how I have learned to live), but if a dealer/manufacturer ask me about reviewing a item I will usual say yes (As long as it is on my review list).
That charger probably is an OEM charger, seen that design many times:
If you need funds to review this charger, I’m willing to help. There is a shortage of good higher wattage multi port USB/USB-C chargers and I’ve rarely seen good (technical) reviews.
I have been a bit quite when people is suggesting USB-C PD type chargers, mostly because I could not test them. This has been fixed now and I can run my usual test on all the supported voltages in a charger. The last couple of days I have been testing a few.
I have also added a Paypal account to info@lygte-info.dk if anybody what to help me pay for some of the stuff I test. I cannot promise that any specific request is honored, but I will try.
I do not believe so. Maybe one or two support it in the auto coding, but I have not tested it.
How about the Xiaomi CDQOM06 ?
https://aliexpress.com/item/XIAOMI-Fast-Charger-3-0-Phone-Smart-Device-110-240V-60W-5-USB-1-Type-C/32855364919.html
https://aliexpress.com/item/XIAOMI-3-0-110/32855364919.html
The review is written, but I do not know when I will publish it. The type number I have is CDQ06ZM
Great to know!
I’d just find some teardown pictures from another site:
http://chargerlab.com/2018/03/16/dismantling-the-xiaomi-mi-6-usb-port-fast-charger/
http://wemedia.ifeng.com/59342258/wemedia.shtml
HKJ, can you give us a bottom line thumbs up/thumbs down on that Xiaomi charger?
From the sidebar on that review Angerdan suggested, some topical info:
http://chargerlab.com/2018/03/15/amazon-recalls-260k-power-banks-due-to-fire-hazard/
That is a thumbs up, but it has more ports than power.
I have just published the Xiaomi review: Test/review of Xiaomi Mi 60W Fast+QC+PD usb charger CDQ06ZM
