Hey, Texas Ace, looks like my light arrived at your place! FedEx tracking said delivered around 1pm.
Hope the mod goes well!
Did I hear you were out of the 5700k p2 70.2 emitters?
From the factory they have polarity protection, you would have to remove that to use flat top cells. Although I highly recommend not doing that, bad things would happen if you put a cell in backwards.
The easiest option is to solder blob the cells. Thats what I do.
I just got my latest order of LED’s in the other day, that should give me all the LED’s I need to finish off all the current orders as of early this week.
I am out of drivers though, the last one I have is being sent to HL for testing next week. I have the components to make more drivers and just waiting for more pcb’s. They should be in Wednesday. About the same time the lights from Terry show up (which is why I told him to wait). I will start up work on these mods again late next week. It will take me a day or 2 to build the drivers.
I needed a few days off anyways, got a lot of other things to take care of in real life during this “downtime”.
Fortunately, I don’t need a driver - yours is already installed
Just the LED swap, as I installed your driver and did the spring bypass a week ago when your driver came in.
But I understand the need for rest though.
I wonder what the lumens are with everything but the new emitters? I may have to buy one of your lumen tubes…
Have a blessed day!
Ah, I forgot which one that was that was coming with the driver already. In that case I can most likely knock yours out this weekend. Maybe tonight actually since the spring bypass is done, I am so sick of bypassing those springs lol.
Oh and I forgot the lights I was supposed to drop off today at home when I left this morning, so they will go out tomorrow instead. Sorry about that.
No kidding on the tedious spring bypass!
I did all five, sloppily, but with your new driver the main spring initially got hot almost immediately. After bypassing with 18 gauge wire, it doesn’t even get warm all the way to light step down. Definitely a necessary step.
Hmm, not sure if I have one on hand right now but I should have one for myself by the time I take the XHP70.2 GT out for some beamshots, I will try to remember to take it along for comparison, also the mt09R.
I forgot i am getting my mt07s 10k lumen light today. It is going to be a great night because the most i ever lift from the single xhp70.2 is 6700 lumen. 3000 lumen step up from the single emitter…
In the “hot test” yes a bit over 9k but from a cold start they can peak over 10k for a few seconds and then it drops as the light heats up until it stabilizes in the low to mid 9k range.
Ok, it looks like I got packages from BimmerNut318, Saypat and 808HI today.
I will open them up and see if any of them don’t need xhp70 drivers later, I am pretty sure Saypat does not. Any that don’t I will try to get finished on Monday.
The rest will have to wait until I get the next driver PCB’s, and build the drivers. It should be end of next week when I can start working on the rest of those lights.
