Nope, these are all schedule 40. And the dwv is what TA is using in the first pictures. The high pressure elbows are a short bend. These are for drain but they are schedule 40.
That is a good point, I did see the thinner walled versions when I was shopping this morning but I think it is worth going with the normal stuff for the extra few bucks.
That said it is hard to tell in the pictures what these are, they say SCH 40 in the details on some of them.
I know very little about PVC, the ones I am using now are called a 90 degree street bend that you get at home depot.
Schedule 40 is thinner than Schedule 80. I believe HD sells the Sch 40 pvc pipe. I think they might have some SDR rated pipes too which is also different dimensions but I can’t remember.
For pvc scheduled pipe sizes:
I’m thinking if the pipe wall is too thin, there might be some light leakage for really high lumen flashlights
I haven’t seen schedule 80 pipe fittings very often and when I do they are grey and short radius bends. All those fittings at Lowes and Home Depot are schedule 40 except for the thin drain crap. The schedule 40 is the thickness. Dwv is a cellular core with pvc coating for use with Drain Waste and Vent. TA’s setup in the pictures in the OP says DWV. When ordering make sure you are getting schedule 40 dwv street 90’s cause the high pressure PVC elbows are short radius.
I have no idea where you are seeing the model in the pictures unless you are saying you just know that is what it is. I can’t find a model on the pipe itself lol.
Those look like the right thing in the pictures though and it looks like they are in stock so I would not have to worry about stocking issues.
I am going to do some number crunching with these new sites and see what I can figure out.
Ok, I have been crunching the numbers and they break down like this:
For the normal 3.5” tube like my own the cost of $100 with shipping in the USA is indeed a price I can do and I can get stock for that without an issue.
For a 4” pipe version (should be around 4.5” opening) the cost would be $150 + at least some of the shipping costs since it will not be able to fit in a large flat rate box like the 3.5” and the price could be quite high. I am saying with shipping $160 in the USA.
For a 6” version the cost is extreme, which is why I did not even consider it before. It would be $250 + shipping, which would not be cheap at all, it would be a massive box and take up a ton of space and weigh a lot as well. Although the option is on the table if someone is interested.
I really like the 3.5” version myself, it fits most lights and does not take up a ton of space.
So I will assume everyone on the list wants the normal 3.5” version unless you tell me otherwise.
I will send PM’s to everyone with my paypal address either tonight or tomorrow. If everyone pays by Monday then I will go ahead and order 30 of them and anyone else that signs up and pays before they are finished gets this price as well. This way they will be on the way to minimize the wait time for everyone.
Are you sure 4” pipe has 4.5” opening? Do you mean 4.5” Outside Diameter and 4.026” inside diameter right assuming it is 4” nominal size sch40 pvc?
I just did a quick search at head diameter of the largest flashlights
BLF GT: 5.27”
Thrunite TN42: 3.94”
Acebeam X65: 4.3”
I think if it can accept 4.5” light, it should cover 99.9% of all flashlights. For the extra large ones like the GT, I guess we can always do a ceiling bounce to compare with a light that we measured with the sphere and calculate the lumens.
The max should be around 100-200k (technically it should be around 200k but I have no idea what would happen up there since the highest I have personally tried is 25k)
I will not know for sure on the 4” until I build one but I should be able to calibrate it the same as the 3” version.
Ok, I will be busy most of the day tomorrow so I decided to go ahead and send out the PM’s tonight. Everyone should have them now, if I missed you let me know!
Please be sure to include in the payment notes the information I request, I don’t want to loose the orders and my paypal is a bit crazy right now lol.
