Ideally, something more opaque would be better, like the Olight GitD traffic wand included with the S1 Mini, or the Thrunite T10T traffic wand. Those are both nice, except for being too small.
some hot running olights has this staged turbo (turbo 1 -> double click -> turbo 2) and it works for the users.
The FW3A overheats (without regulation) in Turbo, so I guess it makes sense.
a double click, double click brings you to TURBO
With this setup you has quick access to 4 different brightness levels froom OFF
floor (or Moon if you chose that low)
memorized level
ceiling
TURBO
The FW3A will run about 15sec on turbo an than throttle, so it will reduce anyway. I guess most will have as ceiling a level which is thermally stable. The ussage of a 15sec blast is for me limited.
you can set the ceiling to TURBO, and you can have different ceilings in SMOOTH and STEPPED
maybe it can be configured by the user if he wants to to have from OFF -> double click -> TURBO
The question will come anyway
Please add me for a 3rd. I am 494 and 1106 already.
Love the clean look of the prototype and would keep at least one as is.
Don’t want anything to slow down production but would also like an optional head with indents cut out to install tritium vials. Guess I could find someone to do that for me but don’t know if that causes problems with the anodization.
I remind that Lumintop produced some small diffusers for the Tool AA! They are made of a soft luminescent material (silicone?!).
Maybe they can produce something alike, even if not in that material. Not sure how much cost that would add, though…
I prefer a ramping muggle mode. I have eight lights running TK’s excellent Andúril UI. When I lend out a Q8 or Emisar I simply say, “Click for on and off. Hold to change brightness.” I don’t even mention ‘reversing,’ and people still catch on quickly.
Exiting muggle mode with a simple power cut isn’t ideal. Like djozz mentioned and joechina reiterated, the first thing most people do with a flashlight is open it to look at the cell. Then they usually try their best to cross-thread it back together. :person_facepalming:
Quite often, someone will borrow my light and enter battery check or strobe mode by clicking repeatedly while staring into the emitter. “Hmm, it’s not doing what I expected. I’d better press the button some more!”
Thank you TK, so I didn’t miss out that’s great, such a beautiful light.
I’ve sort of learned on some of these projects to sign up and then when it happens it happens,
The BLF GT took along time and I actually forgot about that light until I got the notice,
Thanks again and keep up the great work as always…!
As bmengineer and joechina said, the user can configure it to do turbo from off by setting the ceiling to turbo. In that case, the sequence is:
Off -> double click: Go to turbo.
Turbo -> double click: Go back to memorized level.
The floor, ceiling, and anything above the ceiling aren’t remembered unless ramped to. So if you take a shortcut to the floor, ceiling, or turbo, it does not replace the memorized level. It’s safe to turn the light off from those levels, or take another shortcut from those levels, without erasing memory.
Momentary uses the memorized level, which is the last-ramped level. If the user ramped up to turbo, momentary uses turbo. If they took a shortcut to turbo, the memorized level is lower so momentary is lower too. Same story with beacon.
What is not yet determined is what the light should do if it’s on, at a low or medium level, and the user double clicks. Should this go to the ceiling, or should it go directly to turbo?
There probably isn’t enough material to remove for that. Cutting slots for tritium vials would probably expose internal parts of the light or interfere with threads. Some other lights have enough extra bulk for vials to fit, but this one is thinner and avoids extra material to reduce weight.
However, trits could still be installed in or under the optic.
Please put me on the list. I kept looking at those first 2 pictures in the thread and kept asking myself: do I really want to have a BLF light that I dont like the shape off. Now I finally saw the proto type pics and actually like it.. Much better than the original design, that looked like a $5 ebay light to me. Glad it came out nicer than expected and thats the reason im so late to the game :$
