M4D M4X deals - Astrolux WP1 and WP2 LEP
it would take a month if they pre-order now
Acebeam EC65 looked very interesting, until I saw lowest mode of 20 lumens. And they call it “firefly” mode!
NEW: Klarus Mi1C army green / rose also black, copper and titanium
Hello my dear friends!
who has them all?
Klarus Mi1C
XP-L HI V3 600Lumens Mini-might Brightness EDC LED Flashlight
Army Green
Rose
Black
Copper
Titanium
deals can be seen here by members – or you ask me
Features:
• Mini-might brightness, thumb-sized.
• XP-L HI V3 LED, maximum output up to 600 lumens.
• Extreme runtime, up to 9 days in moon mode.
• Professional optical lens design, even-lit flood and soft beam.
• Tail magnetic base function, attach to a metal surface to provide “hands-free” illumination.
• Fade-in and Fade-out function when the turbo mode is the initial mode for on and off to promote eye safety and improve user experience.
• Newest Intelligent Temperature protection System(ITS) monitors internal temperature and adjusts output to regulate heat dissipation; protects LED and internal components for perfect balance of output and safety.
• Intelligent Battery Capacity indicator to view remaining battery capacity at any time.
• Unique lock-out mode prevents accidental activation; avoiding battery drains during storage or travelling and prevents unintended directly shining into eyes.
• Reverse-polarity protection prevents damage due to incorrect battery orientation.
• One-touch low and with mode memory function.
• Aerospace Aluminum Alloy construction; CNC precision machining; Mil-Spec HAIII anodizing, anti-abrasive, lighter and robust.
•Compatible with CR123A and 16340 Li-ion battery, KLARUS high performance 16340 battery with Micro- USB port included, no need to bring a charger, easy to use, safe and reliable.
Package included:
1 x Klarus Mi1C 600Lumens Mini-might Brightness EDC LED Flashlight
1 x 16340 Li-ion Battery with Micro-USB Charging Port
1 x Stainless Steel Clip
1 x Spare O Ring
Hi Martin,
Do you see any chance to get a substantial discount code for the Convoy L2 and L6 again? Unfortunately, the existing codes have been expired („more than 100x used“ or so). Thank you so much!
a lot people asked about a good 8-bay charger to use with their BLF GT (which sells for $250 if you are member )
here is a very nice one:
(picture is the link to the shop – please click it)
Nitecore i8
Multi-Slot 5V USB Intelligent Charger For Li-ion/IMR/Ni-MH Battery
use my code: MI8NC to get the price to US$ 37.46
Festures:
-Active Current Distribution (ACD)
-Monitors and charges each of the 8 slots independently
-Compatible with and identifies Li-ion batteries, Ni-MH and Ni-Cd rechargeable batteries
-Features three charging modes (constant current, constant voltage, -dV/dt)
-Automatically detects power levels of batteries and selects the appropriate voltage and charging mode
-Over-charging prevention
-Reverse polarity protection and short circuit protection
-Activation function for over discharged protected batteries
-USB output
-Designed for optimal heat dissipation
-Made from durable PC material (fire retardant/ flame resistant)
Can you check on some codes for 18650 batteries? Most seem expired. Looking for higher end batteries, Samsung 30Q’s or equivalent.
try this
type Brand model = my Link Code price (US$) shop
cell Samsung 30Q M30QN depends banggood
finally its on stock!
Fitorch M30R
XHP35 HD 1800LM 6Modes Dimming USB Tactical LED Flashlight & Mobile Power Bank
find the deal here: M4D M4X DEALS or ask me…
(pictures links to the shop for further info and specs)
beside the groupbuy: Wuben TO40R XP-L2 1200LM Dual Switch USB
i got some also quite ice items on sale:
(the pictures are links to the shop – please use them ;) )
WUBEN T103W
XHP35 HI 1280Lumens USB Rechargeable Tactical LED Flashlight +18650
>>for the deal just look here or ask me <<<
Convoy S9
XM-L2 580Lumens 4Modes USB Rechargeable EDC LED Flashlight 18650
>Code: YCVS9 loweres the price to US$ 15.95-16.95 <
Sofirn SP32
XP-L2 V6 956Lumens 6Modes Neutral White EDC LED Flashlight
> Code: 6cbdf8 loweres the price to US$ 14.69 <
Sofirn SF36
XP-L V6 1100Lumens 4+1Modes Neutral White Tactical LED Flashlight
> Code: f6b801 loweres the price to US$ 15.69 <
AMUTORCH JM30
XM-L2 U4 1000Lumens 4Modes Tactical LED Flashlight
> Code: YJM30 loweres the price to US$ 31.80 <
AMUTORCH VG10
XM-L2 U4 1200Lumens Portable Tactical LED Flashlight 18650
> Code: YMVG10 loweres the price to US$ 25.99<
JETbeam II PRO Copper
Xp-l Hi Anniversary Limited Edition 510Lumens Tactical EDC LED Flashlight
> Code: JTIIPO loweres the price to US$ 73.69<
Blackwater SR71
3x XP-G2 1000LM USB Rechargeable Mini LED Flashlight
> Code: 1c6741 loweres the price to US$ 63.0 – 105.00<
Miboxer C2-4000
LCD Display Rapid Smart Battery Charger For 16850 26650 Battery 2Slots US Plug
> Code: 8fa94b loweres the price to US$ 24.69<
Klarus K1 USB
LCD Display Smart Li-Ion/Ni-Cd/Ni-MH Battery Charger For Almost all Battery Types
>Code: 934eva loweres the price to US$ 3.99<
Manker 20mm Copper MCPCB
XPL XPE XPG Direct Thermal Path Circuit Board
>Code: 1147a7 loweres the price to US$ 1.69<
and last, but not least:
A BIG collection of discounted flashlights
CODE ECFKL can add another 20% OFF
todays deal:
Sunwayman C22CC
XM-L2 U2 + XP-G2 R5 820LM Rechargeable LED Flashlight
only US$38.99 – get the discount code here: M4D M4X DEALS
Features:
-Aerospace-grade aluminum body with military-grade Type-III hard anodized finish
-Ultra-clear tempered glass lens is both impact and scratch resistant
-Smooth metal reflector surrounding primary LED for max beam distance
-Special secondary side LED used for softer, up-close lighting
-Single pushbutton side switch used to access all outputs
-Stainless steel crenulated tailcap used as glass breaker, self-defense tool
-Tailcap also used as tripod mount for hands-free illumination
-Micro-USB charging port underneath tailcap for recharging battery internally (18650 and 16340 Only!)
-LED power indicator above side switch glows when charging, flashes when fully charged
-Tail-stand capability for candle lighting
Package included:
1 x Sunwayman C22CC XM-L2 U2 + XP-G2 R5 820LM Rechargeable Flashlight
1 x Removable Pocket Clip
1 x Lanyard
1 x Spare O-Ring
I have an older C22C and really like it. The switch on this newer one looks much better!
seems some people did not like my choice of terms - sorry
Klarus K1 says code invalid.
Jetbeam E20R showing “Sold out”
Is it not being restocked? Discontinued?
its payback time ;)
today i got a new deal for the:
Acebeam L16
XHP35 2000Lumens 7Modes USB Rechargeable Tactical LED Flashlight
you can find the deal HERE or send me a message
Features:
♟ Smooth reflector gives perfect beam and throw.
♟ Digitally regulated output- maintains constant brightness
♟ Side switch on the head and tail switch available to use
♟ Aircraft grade aluminum body structure.
♟ Premium Type III hard-anodized anti-abrasive finish
♟ Toughened ultra-clear glass lens with anti-reflective coating
♟ Battery reverse protection function. And batteries low indicalion
♟ Strobe mode for tactical and emergency use
♟ Tactical knurling for firm grip.
♟ Intelligent temperature controlled light output for user safety
♟ Intelligent highly efficient circuit board design for max per-formance and long run time;
♟ Streamlined body design.
♟ Specially designed for military, Law Enforcement, Self-defense, Hunting ,Search & Rescue and Outdoor activities.
Package included:
1 x Acebeam L16 XHP35 Zoomable USB Rechargeable Tactical LED Flashlight
1 x Official-configuration gift box.
1 x 18650 Li-ion battery
1 x USB cable
2 x Replacement O-ring
1 x Switch button cap
1 x Lanyard
1 x Holster
1 x User manual
1 x Warranty card
here are some nice deals for your attention:
(low stock on some!)
JETBEAM TCE-1 Ti $133.99
XPL Titanium 600LM Waterproof 16340 LED Flashlight
Code: f37656 – only 2 left!!
Astrolux E01 flashsale $16.95
XP-L 900lumens 8modes Mini LED Flashlight 18350
Rofis TR10 $31.99
Xp-l Hi V3 900LM Adjustable Head LED Angle Flashlight 16340
CODE 1f7225 loweres to $31.99 (39.99)
SKILHUNT H03R $36.99
XM-L2 1200LM Multi-level EDC LED Flashlight Headlamp
my Code SHH03R works on BOTH TINTS
SKILHUNT H03 $36.33
XM-L2 1200LM TIR lens EDC LED Flashlight Headlamp
my Code MSHH031 works on CW and NW !
XTAR R30 $53.99
XM-L2 U2 1000LM 6 Modes Rechargeable LED Flashlight
Code: e550d1 – Only 3 units!
JETBeam T6 $119.99
4xXp-l-High Power 4350LM 18650 Camping Outdooors LED Flashlight
Code 1d4b73 – M4DM4X.com member price: 114.91
CRELANT VD98 $79.99
XP-L 7C 10W 18650 1220LM Fishing Camping LED Flashlight Under Water 30m
Code: ef9781 – Only 5 units
Eagle Eyes X5R $23.85
XM-L2 U2 900Lumens USB Rechargeable Tactical LED Flashlight
Code: SEX5R
Xiaomi Mijia Wowcase Mini $3.99
Upgraded Electric Screw Driver Drill Bit Box For Electric Screwdrivers Kit
Code: 9f3fcb (empty!)
Hey madmax do you have a code for the uni-t ut210e?
Thank you.
unfortunately expired (a 28 USD deal)
i asked banggood for a new one :)
here is todays update on some deals:
Niwalker C11 XP-L V6 1300Lm Rechargeable Dual Switch Tactical
$ 31.99 code: c151f4
Xiaomi Wowstick H1 Mini Electric Power Screwdriver Kit with 12pcs Bits
$ 21.99 FLASH SALE
Liitokala Lii-202 18650/26650/16340 14500 Micro USB Battery Charger
$ 6.69 FLASH SALE
$ 8.69 FLASH SALE
Fitorch P20R XP-L2 1180Lm Rechargeable Tactical
$ 29.99 FLASH SALE
Astrolux C8 Host
$ 14.41 code: 8a955d
$ 25.46 code: 8a955d
Astrolux S1 XPL 1600LM 7/4modes 3D Mini 18350
$ 16.99 FLASH SALE
and some gearbest deals:
https://docs.google.com/spreadsheets/d/1GOqEcL2aYm6bCmMtPbkQgvz2GKieM2nIVjz5oQjZ3Yo/edit?usp=sharing&widget=true&headers=false
