Thanks for answering TK! I understand now. In the (original?) drawing that’s in the OP, the tail is separate from the tube(s). As for the “custom” host, I guess it does make more sense to just buy a whole light and make the small modifications that might be possible.
Hmm. I don’t have any Olight flashlights yet. I think a click for on/off and hold to change brightness might be good.
(my second choice for muggle mode would be the ramping but with less max lumens)
Since it looks like “smooth ramp” is going to remain the clear winner of the muggle mode poll, I went ahead and implemented it. I also made it save this state to eeprom so it’ll persist across battery changes. Six clicks to enter, six clicks to exit. And since it only uses about half the ramp, I made it ramp half as fast.
It took a bunch of extra room though, so I refactored all the config mode code to be smaller… and ended up close to the same size as before the muggle mode changes.
Oh, and I changed button mappings so all config menus are on four clicks… even if there is no action on three clicks. Consistency is probably more important than density.
Not yet. It has been too cold, and I still need to finish a few parts of the code. And probably redesign the driver. Here’s a preview of its UI though:
Color patterns are configured in a manner similar to designing a sound on a synthesizer. This lets each person make their lightsaber unique. It also lets people see in real time what it will look like, so they can basically tweak knobs until it looks good.
Sorry to drag up this arcane point again, but it seems to me that the cross-section in the first post at http://i.imgur.com/AVSmLGN.jpg shows the current path through the outer tube is only through the square cut threads at the head. There is a clear gap shown between the end of the outer tube and the driver retaining ring. Only the inner signalling connection would be broken by unscrewing the head a little.
This is why I concluded that the square cut threads must be un-anodised. Hence mechanical lockout of the power connection would not happen.
This makes sense to me, and alleviates my concern about the precision of tolerances and assembly that would otherwise be necessary if the only contact was at the faces on the ends of the tubes.
Unless the design has changed ?
Edit: it should be simple enough to verify whether this is the case with a continuity check on one of the prototypes. Or simply unscrewing the head a little whilst the torch is on, it might keep on shining, assuming that the tail switch is a normally-open variety, and that there is no detection of it’s presence.
Hi! Sorry, hope this isn’t a pain, but please put me down for another 2 lights (currently #1025 and #1026) for a total of 4. This light looks awesome - gotta stock up!
Big request here that I dont think has been asked yet…
Can we machine a trit slot in the tail switch? Considering this will be nearly impossible to light the switch up a trit slot would be very handy to find this thing in the dark. I’m currently in the same boat with my black convoy s2+ metal switch. I wanted to use the light as a night stand light but nothing gets through that switch and I am going to experiment drilling my own trit slot adjacent to the switch.
Edit:
Lumintop has done this on several lights already so it’s in their wheelhouse for sure. Picture from giorgoskok’s Elfin review. I dont think the trit should be included. Just the slot…
Please make sure that the head is NOT glued. I’m fine with having no host option available, but would like the option to upgrade the LEDs myself in the future.
Also… is the clip removable? For those of us who don’t use clips, it’s just extra weight in the pocket.
Probably not. Every part of this light, including the button, is thinned down enough that a trit slot would likely go all the way through the metal. The only place I know trits could fit is under the optic. It’s also possible that some might fit in the thick part of the tapered body tube.
Most lights have a lot of extra material to drill into, but this one does not. It opts to be smaller rather than unnecessarily thick.
TBD.
The first prototype’s tail end was glued, so no. Not sure if later units will be glued too.
The quoted text is a measurement, not a theory. And yes, the parts are pretty precise.
Where there’s a will there’s a way. Just glue a magnet onto the tailswitch with a trit slot in that and get 3 mods in 1: proud tailswitch, magnetic tail, trit. I’m sure a few people will find space somewhere to carve out a slot if that’s what they really want.
Given a choice between no trits or making the entire light larger and heavier, I’d rather go for no trits. That’s a matter of personal preference though. I have other lights with a focus on machining, and they feel like bricks in comparison.
I don’t have any lights which are truly similar to the FW3A. The Emisar D4 is closest, but it’s significantly heavier. Otherwise, the only lights I can compare it to are designed for AA/14500 or 16340/18350. For example, a Convoy S2+ with 18350 tube is only a few millimeters shorter, and about the same weight when both lights have a battery installed. My Rey Ti has trit slots, but it’s heavier even in 18350 form. The FW3A is pretty close to the same size and weight as a SK-68, but it uses an 18650 cell instead of AA.
FWIW, Fritz successfully replaced the button with a rubber one. This makes it stick out, but it can also allow light through if it’s a clear rubber boot. I’m not sure if that really helps though.
