13583 posts / 0 new
DavidEF
DavidEF's picture
Last seen: 1 day 2 hours ago
Okay, I haven’t been keeping up with this thread. I honestly just came back to take a second look at it since MascaratumB is having a GAW for one of these and I wanted to see how things are going here. I like the new look of the prototype with the sloped/ramped side on the battery tube versus having ledges on both ends of the tube and smooth/flat in the middle. Then I looked at the FAQ’s and I have a couple questions now.
Quote:
Will there be a 18350 version / 18350 tube?
•No. The entire back half of the light would need to be redesigned/replaced.
Why is this? The design I saw in the OP looks like it could be cut down to fit a shorter cell. Why couldn’t it just be shortened? I’m confused by this.
Quote:
Will there be an empty host version?
•Probably not. The only components which aren’t custom are the LEDs and optic.
If you don’t want to do a host, that’s fine. But, this reason for NOT doing it looks more like a reason FOR doing it. Unless you’re saying that each light is literally a one-off because of how they have to be machined, and there’s no way to make a large-scale batch of these hosts (or it would be cost-prohibitive to do so). In that case, how is this GB even happening?
As I said, I haven’t kept up here. So, if these things have been addressed, please just point me to those discussions and I’ll look myself. No need to re-hash.
- The YKK Philosophy
ToyKeeper
ToyKeeper's picture
Last seen: 5 min 15 sec ago
Quote:
Will there be a 18350 version / 18350 tube? •No. The entire back half of the light would need to be redesigned/replaced.
The back half of the light is, on the first prototypes at least, basically one piece. Usually a shorty tube only needs one extra piece to be made and swapped… but in this case it would need a new inner tube, new outer tube, new clip, and probably all the tail parts too because they don’t really come apart.
DavidEF wrote:
Quote:
Will there be an empty host version? •Probably not. The only components which aren’t custom are the LEDs and optic.
By “custom”, it means “not standard” or “not easily replaced by common parts”. For this light, an empty host would be the same thing as a full light, but without the MCPCB and LEDs. I think a Noctigon would probably fit, but I haven’t checked to make sure. The driver isn’t easily replaceable though, since it’s not a standard size or shape or layout. The tail bits are also not standard, and nothing legos with other lights as far as I can tell.
Also, I don’t think Lumintop does host versions. It’s hard to get them to even offer replacement parts.
The driver is at least reflashable though, and there are several compatible UIs available. It’s just a weird layout, to accommodate the tail e-switch.
DavidEF
DavidEF's picture
Thanks for answering TK! I understand now. In the (original?) drawing that’s in the OP, the tail is separate from the tube(s). As for the “custom” host, I guess it does make more sense to just buy a whole light and make the small modifications that might be possible.
skinny_tie
skinny_tie's picture
Last seen: 11 hours 50 min ago
ToyKeeper wrote:
On my lightsaber, for example, this function is called “self destruct”. It animates an increasingly bright red warning before the reset, then explodes into a fading blue-and-white pattern when the reset has finished. The user can let go during the red phase to abort.
Way off topic, but do you have any videos of your lightsaber? It sounds amazing.
d_t_a
Last seen: 2 min 13 sec ago
ToyKeeper wrote:
As a side note, I don’t recommend pairing “low/med/high/off loop” and “special sequence of button presses”, since the click-per-mode UI is the most likely for people to accidentally input the six clicks to exit.
That could be alleviated by using an Olight Baton-style UI instead though, where it’s click for on/off and hold to change brightness. Perhaps there should be four UI options instead of three.
Hmm. I don’t have any Olight flashlights yet. I think a click for on/off and hold to change brightness might be good.
(my second choice for muggle mode would be the ramping but with less max lumens)
ToyKeeper
ToyKeeper's picture
Since it looks like “smooth ramp” is going to remain the clear winner of the muggle mode poll, I went ahead and implemented it. I also made it save this state to eeprom so it’ll persist across battery changes. Six clicks to enter, six clicks to exit. And since it only uses about half the ramp, I made it ramp half as fast.
It took a bunch of extra room though, so I refactored all the config mode code to be smaller… and ended up close to the same size as before the muggle mode changes.
Oh, and I changed button mappings so all config menus are on four clicks… even if there is no action on three clicks. Consistency is probably more important than density.
ToyKeeper
ToyKeeper's picture
Not yet. It has been too cold, and I still need to finish a few parts of the code. And probably redesign the driver. Here’s a preview of its UI though:
Color patterns are configured in a manner similar to designing a sound on a synthesizer. This lets each person make their lightsaber unique. It also lets people see in real time what it will look like, so they can basically tweak knobs until it looks good.
joechina
Last seen: 3 weeks 3 days ago
Thank you for the 4 clicks to go to config Toykeeper!
And also thanks for the detailed explanations!
Tom Tom
Last seen: 1 year 1 week ago
ToyKeeper wrote:
Er, when the tube is loosened, it breaks electrical contact with both power and the e-switch. Mechanical lockout works without removing the cell.
Sorry to drag up this arcane point again, but it seems to me that the cross-section in the first post at http://i.imgur.com/AVSmLGN.jpg shows the current path through the outer tube is only through the square cut threads at the head. There is a clear gap shown between the end of the outer tube and the driver retaining ring. Only the inner signalling connection would be broken by unscrewing the head a little.
This is why I concluded that the square cut threads must be un-anodised. Hence mechanical lockout of the power connection would not happen.
This makes sense to me, and alleviates my concern about the precision of tolerances and assembly that would otherwise be necessary if the only contact was at the faces on the ends of the tubes.
Unless the design has changed ?
Edit: it should be simple enough to verify whether this is the case with a continuity check on one of the prototypes. Or simply unscrewing the head a little whilst the torch is on, it might keep on shining, assuming that the tail switch is a normally-open variety, and that there is no detection of it’s presence.
Parallax
Last seen: 3 weeks 1 day ago
Hi! Sorry, hope this isn’t a pain, but please put me down for another 2 lights (currently #1025 and #1026) for a total of 4. This light looks awesome – gotta stock up!
contactcr
Last seen: 10 hours 23 min ago
Big request here that I dont think has been asked yet…
Can we machine a trit slot in the tail switch? Considering this will be nearly impossible to light the switch up a trit slot would be very handy to find this thing in the dark. I’m currently in the same boat with my black convoy s2+ metal switch. I wanted to use the light as a night stand light but nothing gets through that switch and I am going to experiment drilling my own trit slot adjacent to the switch.
Edit:
Lumintop has done this on several lights already so it’s in their wheelhouse for sure. Picture from giorgoskok’s Elfin review. I dont think the trit should be included. Just the slot..
Firelight2
Firelight2's picture
Last seen: 1 hour 10 min ago
Please make sure that the head is NOT glued. I’m fine with having no host option available, but would like the option to upgrade the LEDs myself in the future.
Also… is the clip removable? For those of us who don’t use clips, it’s just extra weight in the pocket.
lmcmann
Last seen: 1 month 1 week ago
Please put me down for 2 of these.
Great work, thanks.
Larry
ToyKeeper
ToyKeeper's picture
Probably not. Every part of this light, including the button, is thinned down enough that a trit slot would likely go all the way through the metal. The only place I know trits could fit is under the optic. It’s also possible that some might fit in the thick part of the tapered body tube.
Most lights have a lot of extra material to drill into, but this one does not. It opts to be smaller rather than unnecessarily thick.
TBD.
The first prototype’s tail end was glued, so no. Not sure if later units will be glued too.
Tom Tom wrote:
Sorry to drag up this arcane point again, but …
The quoted text is a measurement, not a theory. And yes, the parts are pretty precise.
contactcr
That’s too bad because it’s very practical all things considered and similar lights with a focus on machining tend to have them.
bmengineer
bmengineer's picture
Last seen: 7 hours 18 min ago
Where there’s a will there’s a way. Just glue a magnet onto the tailswitch with a trit slot in that and get 3 mods in 1: proud tailswitch, magnetic tail, trit. I’m sure a few people will find space somewhere to carve out a slot if that’s what they really want.
Find all my reviews of flashlights and more gear at www.bmengineer.com
DavidEF
DavidEF's picture
Actually, a very neat idea! Crown Thumbs Up
ToyKeeper
ToyKeeper's picture
Given a choice between no trits or making the entire light larger and heavier, I’d rather go for no trits. That’s a matter of personal preference though. I have other lights with a focus on machining, and they feel like bricks in comparison.
I don’t have any lights which are truly similar to the FW3A. The Emisar D4 is closest, but it’s significantly heavier. Otherwise, the only lights I can compare it to are designed for AA/14500 or 16340/18350. For example, a Convoy S2+ with 18350 tube is only a few millimeters shorter, and about the same weight when both lights have a battery installed. My Rey Ti has trit slots, but it’s heavier even in 18350 form. The FW3A is pretty close to the same size and weight as a SK-68, but it uses an 18650 cell instead of AA.
JasonWW
JasonWW's picture
Last seen: 25 min 49 sec ago
contactcr wrote:
I wanted to use the light as a night stand light.
The BLF X5 and X6 are excellent for this. Factory lighted tail switches.
Tixx
Last seen: 2 weeks 2 days ago
Yeah, definitely prefer this to be as minimalist as possible. Comparable to a ZL SC64 without the triple?
ToyKeeper
ToyKeeper's picture
FWIW, Fritz successfully replaced the button with a rubber one. This makes it stick out, but it can also allow light through if it’s a clear rubber boot. I’m not sure if that really helps though.
ToyKeeper
ToyKeeper's picture
Fritz made a new render showing the latest model with a tapered tube.
This is what Lumintop is working on right now, if I understand correctly.
As for the comparison to a ZL SC64, that’s probably pretty accurate. Here are some measurements:
  • FW3A proto1: 92.6 mm x 25.5 mm (length x head diameter)
  • ZL SC64: 92.5 mm x 24.5 mm (measurement doesn’t include extra thickness for the button area)
  • SK-68: 92.1 mm x 26.3 mm (99.2 mm long when zoomed)
  • Emisar D4: 94.4 mm x 28.1 mm (with SF L2 clip) (30.2 mm at widest part of head)
chadvone
chadvone's picture
Wow , I love it.
Mr.Scott
Last seen: 9 hours 46 min ago
ToyKeeper wrote:
MascaratumB wrote:
@ FW3A Team, I sent “you” a PM
I don’t think anyone actually checks that… or even logs in at all, except on rare occasions to post progress updates or edit the top post. It may get used more later, but for now it’s mostly a placeholder.
FW3A Team:
You can disable PMs for this team account. People won’t even have the option of PMing the account and wondering why no one responds.
Mr.Scott
JasonWW
JasonWW's picture
This render looks to have a grain type finish to it. Like it was spun and someone held some fine sand paper or scotchbrite to it. I think it is nicer than the bead blasted finish.
Firelight2
I agree. And it looks AWESOME!!!!
When can we buy this again?
Tom Tom
It is a render.
But, lets face it, this has become too big a run to have a very fine machined finish, that would require frequent re-sharpening of even the best carbide cutters, the best free-cutting alloys, slow cuts, and even then there might be moans about it not being quite perfect.
If it was made of e.g. SS it could be electro-polished, but that would defeat the whole point of this very fine minimalist torch, cut down to the minimum. It seems like a “Swiss Watch” construction, definitely not ordinary.
It looks good to me, preferably tumbled in ceramic media rather than crude bead-blast.
Please keep the anodisation top-quality.
Looking good.
stephenk
stephenk's picture
Last seen: 14 hours 22 min ago
That’s a very cool UI which would be very popular with light painters (as well as Jedi Knights).
Shame-Ranger
Shame-Ranger's picture
Last seen: 11 months 1 week ago
Please add me for 1. It looks great.
lionheart_2281
lionheart_2281's picture
Last seen: 1 day 5 hours ago
I was going to pull the plug on this light due to how long it is taking to develop, but that pic looks awesome, so I’ll continue to stick it out with everyone!
