Festures: -Active Current Distribution (ACD) -Monitors and charges each of the 8 slots independently -Compatible with and identifies Li-ion batteries, Ni-MH and Ni-Cd rechargeable batteries -Features three charging modes (constant current, constant voltage, -dV/dt) -Automatically detects power levels of batteries and selects the appropriate voltage and charging mode -Over-charging prevention -Reverse polarity protection and short circuit protection -Activation function for over discharged protected batteries -USB output -Designed for optimal heat dissipation -Made from durable PC material (fire retardant/ flame resistant)
beside the groupbuy: Wuben TO40R XP-L2 1200LM Dual Switch USB
i got some also quite ice items on sale:
(the pictures are links to the shop – please use them ;) )
only US$38.99 – get the discount code here: M4D M4X DEALS
Features:
-Aerospace-grade aluminum body with military-grade Type-III hard anodized finish
-Ultra-clear tempered glass lens is both impact and scratch resistant
-Smooth metal reflector surrounding primary LED for max beam distance
-Special secondary side LED used for softer, up-close lighting
-Single pushbutton side switch used to access all outputs
-Stainless steel crenulated tailcap used as glass breaker, self-defense tool
-Tailcap also used as tripod mount for hands-free illumination
-Micro-USB charging port underneath tailcap for recharging battery internally (18650 and 16340 Only!)
-LED power indicator above side switch glows when charging, flashes when fully charged
-Tail-stand capability for candle lighting
Package included:
1 x Sunwayman C22CC XM-L2 U2 + XP-G2 R5 820LM Rechargeable Flashlight
1 x Removable Pocket Clip
1 x Lanyard
1 x Spare O-Ring
Features:
♟ Smooth reflector gives perfect beam and throw.
♟ Digitally regulated output- maintains constant brightness
♟ Side switch on the head and tail switch available to use
♟ Aircraft grade aluminum body structure.
♟ Premium Type III hard-anodized anti-abrasive finish
♟ Toughened ultra-clear glass lens with anti-reflective coating
♟ Battery reverse protection function. And batteries low indicalion
♟ Strobe mode for tactical and emergency use
♟ Tactical knurling for firm grip.
♟ Intelligent temperature controlled light output for user safety
♟ Intelligent highly efficient circuit board design for max per-formance and long run time;
♟ Streamlined body design.
♟ Specially designed for military, Law Enforcement, Self-defense, Hunting ,Search & Rescue and Outdoor activities.
Package included:
1 x Acebeam L16 XHP35 Zoomable USB Rechargeable Tactical LED Flashlight
1 x Official-configuration gift box.
1 x 18650 Li-ion battery
1 x USB cable
2 x Replacement O-ring
1 x Switch button cap
1 x Lanyard
1 x Holster
1 x User manual
1 x Warranty card
My BlitzWolf® BW-ET1 XP-L V6 600LM Stepless Dimming LED Flashlight arrived from banggood, dead on arrival. Won’t work with all battery types.
Contacted BG customer service, their BlitzWolf rep emailed me back asking for details, then gave refund via paypal within 48 hrs. Item no longer in stock so replacement not possible.
