All my lights are HCRI
Wellp, is there such a thing as a 90CRI S2+? If not, buy a host for 10bux or hopefully less, throw in the emitter of your choice, and probably a driver without the annoying blink-on-low to change modegroups.
Drawing a blank, probably, but other’n the BLF348-219, just how many other high-CRI lights are there? I can’t think of any others, at least not offhand. Oh, and the Lumintop Tool AA. That’s all I can think of offhand. Others, I ain’t got.
I wouldn’t waste it in a C8 for hi-rez spotting 100m out, but in a nice floody light for close-in work, absolutely.
If I need to see something in the dark, right now, I don’t really care about CRI.
If National Geographic sends me down to the Amazon to catalog poison arrow frogs, or I take up night time portrait painting, then I’ll worry about high CRI emitters, then.
Chris
:laughing: :+1:
I wish this were multi-select. Due to colorblindness, I can’t see a difference. And if I can’t tell the difference, it’s output over CRI all day!
When building lights for friends, though… they sometimes opt for high CRI.
Back in the day when bright was considered 100 lumens, I could understand that we would want to max out the lumen output.
Now that we are in the 1000+ lumens, you can barely notice the difference in output between a 1600 Lumen 90 CRI vs 2000 Lumen 70 CRI unless the lights are tried out side by side. On the other hand, I can def discern the difference in color rendering between 90+ vs 70…
Assuming the tint, and color temperature is already good, I really don’t see why one would chose a low CRI if they had the option to go with high CRI.
Now, trouble here is that many Cree LED’s in high CRI don’t have a great tint, so I completely get it that you would prefer a lower CRI with good even tint without nasty Green in it.
I find it interesting that there are very few throwers with high CRI. Why would color rendering not be as important in a thrower as oppose to something designed to light something up close? I used to have a 219C throwy light and the rendering was fantastic.
Factors I consider when choosing the output of an LED light in order of significance:
- Lumens
- Beam Pattern
- Tint: 4000K-4500K neutral white
- Below the black body line - I prefer my tint to be rosy and not greenish.
- CRI
Of the factors I look for when selecting an LED light, CRI seems to be by far the least noticeable and least significant. I’d take a 70 CRI light with beautiful rosy tint over a 90 CRI light with greenish tint any day.
Same. Would be nice if BLF had a poll style other than “vote for one”. Like, approval voting (vote for one or more) and various flavors of Condorcet. They tend behave much better for polls with more than two options.
Plain and simple there just aren’t many affordable (<$30) headlamps with a high CRI emitter.
I went with the H03 and don’t care nearly enough to swap the XML-L2 out.
Zebra = too expensive
Manker E03H = ugly with that sliding diffuser
With a good tint I can see things fairly well I prefer a good tint to high cri. 5000k is my sweet spot. But I still use my cw lights as long as its not pulsar blue. 6500k is the max cw I can go.
I do have a clear c8 with 90 cri 219c it and it has a great beam and tint. Reminds me of a c8 with xpg2 with the dome on. The light just gets hot quickly with a fet drivr.
Not available in the lights (hosts, UIs) I want and I’m not a modder.
Just because you can do a led swap doesn’t mean you always want to, plus some lights are extremely difficult to get inside.
Heck, I can’t even get NW in many of the lights I like, let alone High CRI.
Ya, there ain’t many…
Here’s a few I know of:
http://www.zebralight.com/SC53Fc-AA-Floody-Neutral-White-High-CRI-Flashlight_p_230.html
http://www.zebralight.com/SC64c-18650-Neutral-White-High-CRI-Flashlight_p_213.html
Although I prefer lights with high CRI emitters, for some applications other attributes are more important to me. For example, I went with XP-L HI in my D4 because for me that purchase was about getting the most ridiculous amount of light possible out of a tiny torch.
Generally a nice neutral white tint is good enough for me, and high CRI is a bonus. I generally don’t buy anything cool white unless I’m planning an emitter swap, although I did put an SST-40 in my L2 out of curiosity.
What I have learned recently is that colour temperature, tint, and CRI are somewhat independent of each other.
I was quite happy believing that colour temperature was everything, and the more neutral the temperature, with a certain bias for preference, the better colours would show.
In practice, this appears to be true (at least for me) to a much larger extent than CRI values.
I have high CRI Nichia lights with warm and cool temperatures and to my eye, neither of them represent colours as well as a neutral light such as my BLF A6 set to an equivalent brightness. I compare the three both outside with a wide range of foliage colours and inside with reds, greens, pastel colours, and browns. I apparently cannot see any advantage to a high CRI light if the temperature is not neutral, since it seems to my eye to taint the colours compared to a neutral light, which shows colours as I would expect them to be, despite much lower CRI.
Factory lights usually have only one or two emitter options with unknown CRI.
Fortunately e.g. Emisar’s lights have big palette of high CRI emitters.
I prefer high CRI for indoors. It is hard to feel any difference outdoors when surrounding areas are grey and ugly.
I have a good few of most options, so although I do like hi cri. It’s not always a deciding factor, colour temp and actual tint is more important for me. For example the xpl2 I have had, too yellow so don’t care what the cri is if my eyes/brain can’t stand it.
I tend to use hi cri at home, edc and at work mainly. If I am using a big gun, hi cri becomes less important than a light used for close up tasks. For example hi cri in dedicated throwers is not important for me personally. Yet for a mule , it’s pretty much critical!
So yes I buy hi cri, but it’s just a single part of my flashlight puzzle . If I want a 4500k light with 80cri, it won’t stop me buying it.
Someone said it above. When you’re looking to spot something far away, nothing really matters except that you get light on the person/place/thing that you’re pointing at. Usually, the more light the better, which is why cool whites are used a lot for throwers.
Okay, so… Jaxman and Zebralight. (I’ll throw in Lumintop for ya.)
Sofirn? Thorfire? Convoy? Thrunite? Niwalker? Nitecore? XTAR? Haikelite? Manker? UTorch? Wuben? Fitorch? …
3 brands out of 14 brazillion.
Yah, lotta choice there…
Like I said…
