I was going to pull the plug on this light due to how long it is taking to develop, but that pic looks awesome, so I’ll continue to stick it out with everyone!
I don’t think anyone actually checks that… or even logs in at all, except on rare occasions to post progress updates or edit the top post. It may get used more later, but for now it’s mostly a placeholder.
FW3A Team:
You can disable PMs for this team account. People won’t even have the option of PMing the account and wondering why no one responds.
Mr.Scott
When I sent the PM was to check on the possibility to make a GAW with this light! After TK’s answer, I decided to go along with it and started the GAW. I will deal with the process when it’s on the move Thanks for the info on this!!
BTW: the more I see this light, the more I love it
I’ll wait for the things yet to be deciced, but this is growing and growing on me
I have’t been buying many lights lately because I’m waiting for this which is better than all the other ones I keep considering for purchase which are currently available.
You are at #1100 page 71, ¿You must remove the strike?
Oh, that one is not an error. The list has the correct number (1) for kahvitahra. To check this, look in the right column of the list, which shows requests per person).
I just for the first time ever carried a side-switch EDC light in my pocket for a week (Utorch UT-01 with 4000K R9080 E21A) and although the size, output, beam, tint, and everything else is wonderful, the switch on the side is a royal pain in multiple everyday use, even though in the UT-01 it sticks out well enough to feel it. I swapped back to a tail clicky EDC (E2L shorty with BLF-A6 driver and 4000K R9050 SM407e, lighted tail) this morning and thankfully everything is back to normal: draw and click-on, instead of draw, fumble, click-on.
Morale: the design decision of the FW3A to move the e-switch to the tail is a very good one, and for me essential to make it EDC-worthy.
Morale II: please sign me up for a second FW3A, preferrably in desert tan ano
Couldn’t agree more. Side switches work OK in benign conditions, but when you’re hands are frozen, or gloved, useless.
That said, I really like my Olight S15 and On The Road M3 for EDC, but only because they have pocket clips that I have glued into place 180 degrees from the side-switches, so no difficulty finding them. Un-glued they can gradually rotate and lead to confusion. Without the clips I would be lost.
BTW, what did people think about the muggle-mode UI poll? I was thinking of doing a similar one for emitter type, if people found the poll method acceptable. It’ll need more explanation though, since the emitter tradeoffs are more complex.
Are we talking 3000 lumens out of this lamp? Sorry if I missed the output(s), but what’s the turbo Lumens and time as well as a sustainable “high” lumems spec if there is one at this point? If not, a target brightness would be interesting.
Please and thanks!
DB Custom wrote:
Yes Cawi, fully aware… I built the first X5 Quad at over 3000 lumens. (How do I know it was the first? Because it was done on a prototype. ) Also built the first Triple and Quad X6. Something about a small high powered light…
My MecArmy PT16 is making 3400 lumens as a quad. Ramping. Just Gotta Love It! lol
The FW3A specs are vague because the emitter type hasn’t even been nailed down yet. However, it’ll probably do somewhere around 2000 to 4000 lumens on turbo. And the highest sustainable level at room temperature while tail-standing will probably be under 500 lumens, due to thermal concerns. The sustainable level during actual use depends on how the light is cooled… it’ll be capable of more in cold weather than in hot weather.
Deals: Skilhunt H03
the new rendering looks good, please add me to the list for 1 if it’s not too late to join the party.
REVIEWS: AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 & SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B018 /// ACEBEAM: H20 /// BLITZWOLF: BlitzWolf BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 & A5R / E300S / A8 ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 TIR Lenses: 1 / 2 Others: Biscotti 3 & 1*7135 Triple TIR & XP-G2
MY GIVEAWAY (FW3A)
Please add me for a 2nd one. Hopefully there will be both neutral and cool white tint options so I can have one of each.
Beam me up!
Been following this light for months now, but that new rendering has me hooked. Please add me to the list for one, please.
Just discovered this wonderful addiction.
Yes! Not the new D4 blue type.
1 Please
I like the machined bevels on the battery tube. They look “right” to my eye and it’s getting me even more excited for this to come to life.
I like the sloped battery tube. please add me for a third one. #1003, 1056.
put me down for 2 please
add a second one for me please. Many thanks
عُمَانْ
List page 71 updated
I observe:
http://budgetlightforum.com/comment/1294460#comment-1294460
Not included in Post 4 TK list.
http://budgetlightforum.com/comment/1302728#comment-1302728
You are at #1100 page 71, ¿You must remove the strike?Sorry for my bad English
(google translator) , (https://www.deepl.com/translator)
Thanks! I didn’t see that one earlier. It helps a lot having more than one person looking for requests.
link to djozz tests
Please put me down for two
Add me to the list for 1 please! Thx.
Put me down for one please.
Anything is amphibious if you can get it back out of the water.
I interested for 1 piece with Nichia 219c NW
my blog: http://torchobzor.blogspot.ru
And sorry for my english.
Emitters are not defined yet!
MY GIVEAWAY (FW3A)
Add me for one please!
WishIwereaSkibum
Ok, i need just 1 piece.
This is true.
I thought that poll was superb. Easy to use while also allowing for degrees of opinion.
Please and thanks!
WishIwereaSkibum
Perfect
Thank you
Understood and clear
WishIwereaSkibum
