Review: ThruNite Neutron 2C V3 with Ramping Firmware
25 posts / 0 new
robo819
robo819's picture
Last seen: 1 day 10 hours ago
This is the ThruNite Neutron 2C V3 (newest version) sent to me for review from ThruNite and NO other compensation other than keeping the light.
Light can be found at the main ThruNite site …. http://www.thrunite.com/thrunite-neutron-2c-v3-1100-lumen-flashlight/
(20% off during the Christmas sale on the main site.)
or at the Amazon link …. https://www.amazon.com/dp/B06XWXVZH7 …. (Links are NON Afilliated)
I know I am posting this a little late for Christmas to get the light for anyone who may want it by then , but I have had a number of things cut into the time I could spend getting the review finished with the holidays coming up and just everyday life , so my apologies for not getting this posted sooner.
I will start by saying the Neutron 2c V3 is a very nice light from the time you get it out of the box , as it just has the look and feel of a quality light , which I have come to expect with the ThruNite products.
The package comes with the instruction manual and thank you card , the ThruNite 3400mAh cell , USB charging cable , 2 extra USB port covers , 2 extra O-rings , an extra rubber boot that goes under the side switch and detachable clip.
This latest upgraded model has the XP-L V6 emitter in it and comes in a cool or neutral white. The emitter is well centered inside the somewhat deep reflector (for a tube style light) and the reflector itself looks pretty much flawless. The lens is AR coated and the Anodizing is very well done. The knurling is somewhat aggressive , but not overly so and has a really good feel to it with alot of grip. The threads are square cut , well machined and were lubed just about right when I received the light. The Neutron is also USB side port rechargeable , or you can remove the cell and charge it on an external charger if desired. The USB charging is rated at 1 amp.
With the tube extension in place (or removed) The light can be used with a single 18650 , 2 × 16340 or 2 x CR123A , single 18350 or single 16340. This makes the light compatible for a number of different configurations and cells , so to me that is very big plus.
There is NO tail switch on this new model and ALL functions are through the side switch , which is a nice looking metallic one. There is also a small indicator light in the very center of the switch button that is a constant on , blue in color , when the light is powered on. This same indicator light is also a Low voltage indicator and RED in color when the battery voltage starts getting low. The Low voltage warning will start blinking at first and when the cell is more near depleted , then the indicator light is a constant red , until the Low Voltage Protection will turn the light off when the cell gets to the low voltage level. (Noted in charts below)
The indicator light also functions when using the USB side charging port. When the cell is depleted the light will be Red when you start charging and turns Blue when the cell is fully charged. If the cell is inserted wrong or if there is not a good connection , such as the tubes not screwed together good or a bad contact , then the indicator light will show Purple.
The driver seems to be a constant current driver that is used , but at this time I do not want to try to get the light apart and risk damage to check it , as it seems to be glued tight.
The UI is my favorite feature of this new model. It has what ThruNite calls “Infinity Modes” , most of us know it as Ramping. The ramping is used by simply turning the light on with a single quick press , then to go up or down you simply hold the side switch until the desired brightness level wanted is reached. If you are going higher in brightness and stop then then next press will go back down or if you are already going down and stop , the next press will go back up in brightness. You can achieve any level of brightness desired with this firmware , so there is always the perfect level of brightness. The ramping does move a little slower than some I have seen , such as the “Narsil” , but it does give you a little more reaction time when trying to fine tune the brightness. There is also memory , so no matter what level of brightness you are at when the light is turned off that is the level it will come back on in throughout the “infinity” or ramping mode and that level stays in memory even if you go into Turbo , Strobe or Moon. The Turbo , Strobe and Moon mode are not memorized. The Moon mode is activated with a long press from off , the Turbo is a quick double click (from any mode including off) and the strobe is another quick double click from there , a single quick press to turn the light back off.
The beam pattern on the Neutron is a semi throwy beam but with some good coverage area also. The tint I am reviewing is listed as “cool” but it is not like the really cool , blueish color that we normally associate with cool , the tint is more of a pure white to my eyes.
The light should have some good runtimes with a high capacity 18650 for sure. Due to so much going on right now with getting ready for the holidays time constraints kind of kept me from doing more run time testing than I did.
The test I did with the included cell and the 16340 Efest cell are noted in the below chart , as well as my tested lumens and amperage with the included cell.
Overall I am very pleased with the newest Neutron 2C V3 for the overall fit , finish , feel and UI and I think ThruNite has a winner with this one.
For those who do not want to watch the whole video , the still shots of the light and the beamshots start at 9:19 of the video timeline and the live outdoor footage starts at 13:28 of the timeline.
Video followed by listed specs…………
Specifications
•LED: XP-L V6 with a lifespan of 20+ years of run time.
•Compatible with: 18650 × 1, 18350 × 1, CR123A x 2, 16340 × 1, 16340 × 2
•Working Voltage: 2.7 – 9.0 V.
•Output mode/Runtime:
-Strobe(650 lumens /5 hrs)
-Turbo(1100 lumens /2.2 hrs)
-Infinity High(650 lumens /2.7 hrs)
-Infinity Low(12 lumens /130 hrs)
-Firefly(0.5 lumens /49 days).
•Peak Beam Intensity: 14399cd (max).
•Max beam distance: 240m (max).
•Impact resistant: 1 meter.
•Waterproof to IPX-8 Standard (2meters).
•Weight: 86g without battery.
•Dimensions: 125 mm in length x 25.4 mm in head diameter.
•Accessories: Holster x1, Spare O-rings x2, Lanyard x1, Pocket Clip x1, 18650 3400mAh Battery x1, USB Charging Cord x1
Operation
•Turn ON/OFF
Single click the switch to turn the light on and off.
Long press the switch to get firefly mode.
Double click the switch to get turbo mode.
•To Change Modes:
When the light is on, long press the side switch to cycle through infinity high and infinity low.
Double click from any mode to turbo, another double click to get strobe.
•Memory Function:
The light will turn on in the last mode accessed, except firefly, turbo and strobe.
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
Edited by: robo819 on 05/22/2018 - 02:39
robo819
robo819's picture
I am kind of surprised this one hasn’t had a lot of attention with the Ramping firmware , upgrades and all.
The Big monster lumens lights taking over all the attention now days?
Or has it been reviewed to death already that I didn’t see?
hIKARInoob
hIKARInoob's picture
Last seen: 11 min 46 sec ago
Hey robo how are you doing man? I kinda feel Thrunite is primarily known for their big guns, especially their monster thrower TN42. Their sub $50 lights are just not discussed here extensively. However at the same time they do have a fan base here.
The Neutron 2C V3 is a good example of a solid performing light, but without the mind boggling specs. You really need to have one to truly appreciate it. It reminds me a bit of the Thrunite TN4A; another great performer that just isn’t discussed a lot either.
robo819
robo819's picture
All good points hIKARInoob …….. I kind of feel like the attention now days is mostly on the Big , High output lights also , no matter what brand really.
These smaller lights though are the biggest part of what I use personally for 80% of anything I do with flashlights to be honest.
Don’t get me wrong , I do have a lot of nice throwers in the collection and I use them when I can or if they are needed , but as I say for most of the normal usage and EDC the Neutron and other lights of similar size (or smaller) just seem a lot more practical.
beam0
beam0's picture
Last seen: 11 months 3 weeks ago
Curious what the length of this is with the 18350/16340 shorty tube?
"Over 2000000 hours (about 200 years) standby time"  (DQG Tiny 4th)
"27,157 results for zoomable flashlight" (ebay)
robo819
robo819's picture
94mm with the short tube.
arficus
Last seen: 1 year 1 month ago
My 2+ year old 1000lm nitecore HC30 is 98mm w/18650. When is someone going to make a decent NW/WW 18350 light w/reflector that is actually small?
beam0
beam0's picture
Thanks guys for the measurements!
beam0
beam0's picture
Eagtac DX3B Mini:
(Been out for over a year)
  • Length: 3.2 inches (82 mm)
  • Smooth aluminum reflector
LED Options:
  • CREE XHP50.2 K2 Cool White LED
  • CREE XHP50.2 J4 Neutral White LED
  • CREE XHP35 HD E4 Cool White LED
  • CREE XHP35 HI E2 Cool White LED
  • CREE XHP35 HD Neutral White LED
  • CREE XHP35 HI Neutral White LED
Also:
Eagtac DX3B Mini Pro
  • Length: 3.4 inches (86 mm)
  • Adds tail magnet / black clip / 18650 ext. tube
    (Same LED options)
My 18350 flashlight thread: http://budgetlightforum.com/node/59323
arficus
Thanks for the suggestion (and I’ve been following your 18350 thread). But, alas, the eagletac has a lowest mode of around 20lm, complete deal breaker for me. Guess I should’ve included need for sub-lumen mode (or something close) in my post…
beam0
beam0's picture
Even without your sub-lumen mode requirement being reveled in your post I would have still wanted to make it known there are decent smaller NW reflector18350 lights. The main attraction of the Eagtacs is having XHP emitters and outputs up to 2480lm (1830lm ANSI) from such a small light.
Since you’re following the thread I’m sure you’re aware of these Jetbeams, but I thought I’d mention they’re even shorter than the Eagtacs, with low modes of 1.1lm & 5lm, although there’s no NW/WW option. I’m not sure how difficult it would be to swap LED’s on a Jetbeam.
The EC-R16 in particular is incredibly small for a reflector light.
(Note they’re listed by Jetbeam as 16340, however it’s been confirmed they also can accept 18350)
Jetbeam E20R
  • 76.45mm length
  • SST40 N4 BC
  • Lowest mode 1.1lm
Jetbeam / Niteye EC-R16
  • 71mm length
  • Cree XP-L
  • Lowest mode 5lm
beam0
beam0's picture
Does this have the exact same knurling as the TC20?
robo819
robo819's picture
It is pretty darn close…………….
beam0
beam0's picture
Wow nice close up pic. It looks the same to me, does it feel any different?
The TC20 knurling is about the best of any light I own, on par with DQG. It prompts me to consider other Thrunites.
Same with the UI.
robo819
robo819's picture
Same with the UI.
They feel pretty much the same also , like the regular Thrunite knurling usually feels on both really.
beam0
beam0's picture
Does this have LVP?
beam0
beam0's picture
(Quote from OP / review)
Charts with amperage missing?
robo819
robo819's picture
beam0 wrote:
Does this have LVP?
robo819
robo819's picture
Something going on with the server on Postimage……heres the charts………..
beam0
beam0's picture
Okay thanks, so it has LVP (shut off)
I wasn’t sure because I don’t see that in the description on Thrunite’s website, It’s probably in the user manual which I think can be downloaded there. EDIT: no user manual downloads there.
Not sure why you mentioned in your reply about it not having a tail switch?
robo819
robo819's picture
that was actually a quote from the above review.
beam0
beam0's picture
OK I see, Thumbs Up was wondering why you were telling me that! Facepalm
I tried to find about the LVP in the review but read too fast and missed it Facepalm
RobertB
RobertB's picture
Last seen: 1 day 11 hours ago
The Neutron 2C is one of the most recommended lights over at reddit/flashlight. Especially to FL newbs.
beam0
beam0's picture
It’s at the top of my wish list right now.
I’ve never been to reddit/flashlight, maybe read one or two reviews from there before.
I wonder why it’s getting more attention there, and not much here (as robo pointed out)?
RobertB
RobertB's picture
I don’t know. Maybe just a lot more FL newbs over there from elsewhere on reddit. Pretty huge platform with 40 million user accts.
