Yeah, I would most likely use acrylic instead of ABS since it is laser cutter friendly and then just apply the reflective tape to that.
Texas_Ace BLF Calibrated Lumen tube / Sphere No math skills needed - Several spheres still available
For my setup, I'm all for you doing whatever you need to regarding cost- and time-saving. I know I'll have a great product no matter how it's finally spec'd out, and optimization just makes sense as the process goes along :)
So yeah, mod/optimize as you see fit!
-Ben
I’m ok with whatever is more cost effective, easier, faster and achieves the same result. I know the product will be high quality no matter what you do.
I’m ok with whatever works. I’m sure it’ll be more than sufficient.
I’m ok with whatever you need to do.
I'm of the opinion - that I don't know enough about the alternative - to have an educated opinion.
Ok, Tomorrow I am going to try to finish up the outstanding MT09R mods I have here and the next day I will see about making up an adapter for the sphere to use laser cut centering discs instead of 3D printed.
The end results should be the same either way, this will be much quicker and a bit cheaper for me as well.
Whatever works and is cost effective. I think nkresho’s idea sounded good too.
Here’s a couple of pics of what i’m working on. The centering rings are in here.
Overall sphere design is a copy of the “match sphere”. Match's Mods: Homemade Integrating Sphere
I agree, I was thinking on it and I think I might of come up with an even better way of doing it, a bit more labor but should work good. Then just need to get the centering rings laser cut. I can do a 24” x 12” piece at a time and each sheet should take less then 15 minutes to cut. So I can finish it in a slow afternoon if all goes well.
If you go a manual route you could potentially clamp multiple together and knock out several at once depending on what your plan is
I found that a piece of 4” PVC pipe almost fits over the outside of the 3” perfectly, I just have to sand off some little nubs on the outside of the 3” fittings for it to fit and then cut a bunch of short pieces of 4” pipe. Which might actually be a deal breaker since I sold my miter saw a few months ago.
the 4” I would still need to 3D print either way, I will start off with that and see how things go.
For the laser cutting, I could possibly stack a few but this laser cutter is only 50w, it works great but does not like cutting through very thick materials.
I don’t have much time tonight but just wanted to give a quick update. Spent the afternoon working on the centering ring issue and nkresho’s idea is a far better idea for this situation I think, the end result could in fact be better then what I first panned.
I really like the materials I ended up with and while it takes a fair amount more labor, well thats what family is for when the skill level is low right? lol
I got some pictures of the stack of stuff, think small refrigerator sized pile of stuff. I will try to post them tomorrow.
What worries me is when they are spread out all over the place and then shipping. I never even thought about boxes for this many large items. That could prove a challenge. I am working through them though.
The lux meters will hopefully be here at the end of the week, possibly early next week. I want to have everything ready for calibration when they show up.
Nice TA. You got everything under control.
I assume you will add a bit of glue to the main pieces of pvc pipe so it can’t be taken apart. If it is, then the diffusers might get rotated and lose it’s calibration.
The inlet section that is aimed upward I can see leaving unglued. Rotate it flat for shipping and have a mark where it should be rotated 90° to face upward again.
These should not need much packing material as the pvc is so robust. Just wrap the meter and centering rings well and put it in the center.
I am not 100% sure where I will glue things yet. If the PVC itself is not glued together then the diffusers will be glued inside of the PVC.
Gonna have to see how things go before I figure out the glue, that will be the last thing that happens.
That said, I am pretty sure that all but possibly the first piece of PVC will be glued.
I am off to the laser cutter in a few minutes.
Well, I am 4 hours in at the laser cutter so far, think I have about 1/8 of them cut at this point. Took me a few hours to get the settings figured out and now I am having to run it at 15% speed which takes for stinking ever for each cut.
I am really liking this new setup, even more then the first setup.
Thanks for all your work on these TA. I’m sure by the time its over you will have decided you charged way too little for them We’ll be very grateful though.
On the glue situation, I know they’ll have to be glued some in order to keep things lined up for calibration. That’s fine, good even. I want mine to stay together. But I do hope any of the “vertical” pieces can be left loose so they can rotate down for storage. I don’t know about everyone else, but I don’t have a good place where I can leave mine out all the time. I’ll need to be able to fold it up and put it away…somehow. If at all possible.
Thanks sir!
You mean you don’t have a shrine for your sphere?
So you can hide it from your wife?
Wife: Is that our drain?
Flashoholic: Uhhh…no…
Wife: It looks like our drain! What is it?
Flashoholic: It’s a calibrated lumen tube no math skills needed!
Wife: what…
Flashoholic: It measures lumens!
Wife: loomans? Is that another thing for your stupid lights!?
Flashoholic: yes…
