Astrolux "MF04" discussion thread
nice photos… how does the light feel in hand, is it balanced with that small battery tube?
Similar weight?
Maybe they made the MF04 a bit lighter on the big end?
It sure looks lighter around the switch area.
Hi … just a brush up on the GT
Weights BLF GT
with batteries 2273 g (8 × 35E)
tail-cap 91 g
one battery holder 64 g (empty)
one battery 48 g (35E)
one battery holder 259 g (with 4 × 35E)
two battery holder 518 g (with 8 × 35E)
battery tube 285 g
BLF GT head 1379 g (with screw 1381 g)
Here is what I found on:
Mateminco MT35 Plus
Battery 4*18650 battery
Weight 1290g (without battery)
That’s really nice. Wonder how it does compared to the GT…
beautiful pictures @steel_1024
Specs say 2000 lumens for the MF04 and my MF02 has 3000 lumens. Is 2000 lm a misprint for the MF04?
The MF02 has a measured output of 2100 lumens and with the LED binning that’s already overdriving it.
Thanks. Somewhat misleading for BG to post 3000 lumens then for the MF02. I'm going to take off 30% off whatever
they say the MF04 output is and bank on that.
2000 is probably pretty accurate. The xhp35 can only get so bright regardless of how much power you put to it. It’s physically not capable of 3000 lumen “out the front”. Also, the throw of the MF02 is less than 1587m. It’s probably around 1400m.
The MF02 is still by far my favorite light in my collection, but I don't get why BG feel they needed to stretch the specs so far away from reality.
It is a mystery. They released those specs before the light even came out. And then once it came out and everybody realized it was much lower than those specs, we knew it would be lower obviously, banggood never did change the specs to a more realistic level.
Long press to turn it OFF…
Is that different than the MF02?
This rhetorical question doesn’t make the MF02, MF04’s UI any better. It’s not because the MF04 shares the same UI as the MF02 that a long click to turn it OFF isn’t “bad”.
Fortunately the long click isn’t too long.
It wasn’t rhetorical. I don’t have an MF02 so I dont know if the long click for off is a new thing or not.
The way you said it made me think it was a new thing.
OK, my bad Jason, I thought you already knew the answer and was a bit ironical.
All mateminco/astrolux flashlights are sharing the same UI (listed in the above picture) so far which isn’t bad as a princip…if only it was a good UI.
Believe it or not, I don’t own a single Mateminco or Astrolux light even though I follow a lot of their threads. Like right now. I have zero intention of buying the MF04 as I alresdy have a GT, but I’m still curious about it.
I’ve considered buying some other Astrolux lights with the intention of swapping the driver to a Lexel unit and get NarsilM, but I haven’t done it yet.
That’s probably why I don’t know their UI, I never paid attention to it.
Their drivers tend to break anyway. It usually takes them a few redesigns to get it right. It seems the current MF02 drivers are finally working well so I guess the MF04 driver will work well, too.
Yes, The MT35s(MF04) driver works well.
Skylumen is very impress with astrolux or mateminco lights. He said mf02 have a great factory heatsink. His favorite is mateminco Mt18 with the xpl hi… I do believe him because he open and mod lights.
Yes, their machining and finishes are quite good. Notice that Skylumen always changes the Mateminco drivers out to his DriverVN, though. They make good hosts.
