Yeah, I saw that one. But the lumen rating is half the Defiant one. The barrel will fit 26650 more easily. All Husky lights are loose and batteries rattle easy.
“Battery bonk” is what I call it when batteries rattle against the insides of the battery tube .It’s made worse with multiple cells and 3 has got to be painful . I started off using the slick postcard thickness junk mail to create paper tubes for the batteries to slide down into . Now I just use a drinking straw cut to the length of the cell or cells and slit the straw lengthwise. It doesn’t go all the way around the cell but it quiets down and eliminates battery bonk …That obnoxious battery rattle just makes a light feel cheap.
Guessing you guys are talking about the 3C version of the Husky 500lm?
I’ve got a 4xAA Husky 500lm, and to the naked eye, it puts outs as much light as the 1,000 lm Defiant. Alas, being a 4xAA light makes it problematic to convert to li-ion, which is a shame because it chews through AA cells in no time - 30 mins on NiMH on high, if that.
I’m getting about 11 Watts from the Husky 4xAA, and about 13 Watts from Defiant 3C.
Yeah Pete the 3 C version at 500 lumens. The MOD I did for Defiant 1000 lumens will work for use of the 26650. The only reason I did not pick up is because lumen rating is lower for Husky light.
BTW, if you want Husky lights pick them up. Some are out of production : 650 lumen 3 D cell, 500 lumen spotlight 3 C cells, etc…
Please! Someone post pictures on how the 3C triple is disassembled!
Like I said, I get 7+ Amps with my 26650 (28+ watts) but don’t want to overdrive the driver or switch until I know how to upgrade it. This is an awesome throwing flooder and I’m sure I’m producing greater than 1200 lumens.
I still want to know what emitter it uses ???.
I burned out the Husky 500 4AA driver and replaced it with a Qlite +1 7135 chip. The driver retaining ring has a lot of space and you need a 26mm driver or contact board to make all tight. !HUSKY 4AA XP-G3 HUSKY 4AA XP-G3 - Album on Imgur!
I used a copper washer to adapt the driver to fit.
I replaced the XP-G3 with an XM-L2 3C on 20mm Noctigon DTP. The only issue I have with this light is the reflector… kinda ugly beam.
The Defiant 1000 lumen is encased in 1 piece. The only thing remove able I can see is tail cap, and head bezel area.
The Husky one is the worse. The thing is built from 1 solid unit. Meaning all emitters, dome, is enclosed as 1 unit. You have to destroy light is you want to MOD. The only thing that comes apart is tail cap.
Nope! Take a look at my photos in the link. Husky 4AA Modified 4AA XP-G3 HUSKY 4AA XP-G3 - Album on Imgur You need to apply hot air from a hair dryer or heat gun because the head is glued on. The glue is a slicone, soft type but you have to be patient. It took a minute or more to heat it up and then you apply steady pressure. It will come off.
Considering the 3C triple, it looks like there are metal tabs that secure the pill to the battery tube. I hope not! I guess to really find out, I’d have to be willing to destroy it. But why break it if it ain’t broke? LOL.
Now with the 500 Lm Husky, with perseverance, determination and patience, I’ve been rewarded with a little modding fun and that’s just one of the many interests most of the people have in this forum. I waited on those copper washers to arrive so I could install the 1st driver (9*7135 Qlite) I had on hand. Richard didn’t have the (FET Driver - 26mm
2S+ Cell: LDO (Momentary) NO LVP
Firmware: Standard w/ Memory
Turbo Timer: 90 Seconds) mosfet driver I originally wanted but it came in and I have it ready. I’ll be able to use the 4AA carrier, 2*26500s or just a 26650. I didn’t opt for the LVP so it should light up MORE or less with all these battery options.
I refitted a 2×C River Rock light to take a 26650. Cut a section of foam tube (like you’d stuff under drafty doors) with a metal rod down the center. Forgot what metal I used, probably just chopped a long-enough brass screw to fit.
I got a few, and at least capacity-wise, they were quite good. (Good per the capacity rating on the wrap, that is.)
Don’t recall the 26650 (bought 2, 1 bricked, 1 still going in an F13), but it tested at or above its capacity rating. Same with a pair of 16340s for my Jet-II.
I got mine probably just before the mass slaughter of stores, when they wanted stuff cleared out yesterday. Prices were decent, from what little I recall. No complaints.
You’d be retarded to buy them for full-price, but for the 5bux for a pair of 26650s or whatever the deal was, yeah, I got a set.
Well, I modified Home Depot to accept both single 18650 or 22650 battery running ” stock emitters and driver ” The light seems brighter with Li ions running it.
I fabricated a ” dummy cell ” out of thicker grade copper pipe with copper end caps. The cooper ” dummy cell ” fits snug inside flashlight barrel. Then used a 26650 that fit in barrel.
For the 18650 mod. I used a kids toy tube OD 15/16 inch and ID 7/8 inch for battery spacer. Used contact cement to glue 1/32” foam to inside and outside of tube. Then used black duct tape to wrap inside of tube. The process prevents any type of rattle. Battery fits snug inside tube. Tube fits snug inside of flashlight barrel.
Painted the entire battery spacer tube black. Looks like it came from factory.
Now I can use 3 types of batteries if I run into jam. 18650, 26650, or Alkaleaks ( emergency )
Have no idea how to [post pictures with photobucket now gone.
I bought some Liitokala 21700s (yellow), made a new Cu dummy cell/tube and I'm pushing 9A through this light. I was a little worried about a POOF but it's handling the current. Since this light has unknown manufacturer emitters, I can't say for sure but I'm hoping it's putting out at least 2000 lumens. It definitely has a high candela.
It comes apart very easily, nothing is glued. But you have to go in a certain order.
Start by unscrewing the bezel.
grab the reflector, and unscrew that from the body. The pill, which is screwed to the reflector, comes out (unthreads from the battery tube) with it. Pretty easy to get the rest apart from there…unfold those thin little tabs holding in the board with the spring, to get to the screw holding the reflector to the pill. Btw there is no driver in the pill. Is is a very compact e-switch driver with slow PWM located in the tailcap. Would be hard to change, as ther is no easy replacement.
I got 2000 lumens from this light, direct driving it with a single 18650 medium drain panasonic pd cell. High mode has PWM so I’m sure you won’t get the 2000 lumens going through the driver. I didn’t bother to see.
This is a very cheaply made, lightweight light and I dont feel like putting any time into it. The pill is very light and thin, the negative wire attachment to the body is a joke. Much better as a giveaway light for a non-flashaholic.
