I have a following of LED light.
(1)ACEBEAM-L30
(2)LED LENSER-P7R
(3)LED LENSER-P7.2
(4)LED LENSER-P7
(5)LED LENSER-i6
(6)LED LENSER-K3
(7)LED LENSER-M14X
(8)NITECORE-CONCEPT-1
(9)NITECORE-EC11
(10)NITECORE-EC23
(11)NITECORE-P12GT
(12)NITECORE-P26
(13)NITECORE-TINI
(14)ROFIS-MR70
(15)ThruNite -TC20
(16)ThruNite-TC12 V2
(17)Manker E14_II (It was broken in 2 hours after purchase)
I have a lot of LED lights.
But there is no knowledge of the LED light to me.
I like the light be equipped with a battery of 26650.
I plan to buy a OLIGHT R50 PRO SEEKER 3200.
What do you think of OLIGHT R50 PRO SEEKER 3200?
Is the OLIGHT R50 PRO SEEKER 3200 less trouble?
Do OLIGHT R50 PRO SEEKER 3200 have excellent performance?
Please tell me if there is an excellent light resembling an
Please tell me the choice of
non-OLIGHT R50 PRO SEEKER 3200.
Olight make good light. The only thing is you have to use oem battery for the usb charging. I got many 26650 lights. I will give you my opinion lumintop odf30 today.
I’m sorry to bother you.
I plan to order Lumintop ODF30 soon.
I have a few questions.
Please answer the following questions:
(1)Is the Lumintop 26650 5000mAh Battery included in ODF30?
(2)I want 2-Lumintop 26650 5000 mAh Battery. http://www17.plala.or.jp/x000x/battery.jpg
I can order the 2-Lumintop 26650 5000 mAh Battery Where?
Please tell me the URL where I can order a Battery.
The battery can be shipped to Japan?
(3)Can I use the following batteries?
KEEPPOWER IMR 26650 / 5200mAh Max30A Constant-OutPut/15A
4.2V~2.5V (Standard voltage 3.7V)
Diameter 26.1mm ±0.2mm / Length 67.5mm ±0.5mm http://www17.plala.or.jp/x000x/battery2.jpg
I thank for your detailed answer.
Is the battery of Efest the following product?
Efest IMR 26650 LI-MN 45A 5000mAh.
The consecutive electric discharge upper limits:45A
Maximum moment electric discharge:50A
Diameter:26.50mm
Length:65.20mm (±0.2mm) http://www17.plala.or.jp/x000x/battery3.jpg
You have Efest IMR26650 5000mah of 67.5mm.
The length of Efest which I checked, 65.20mm.
Are these two the same things?
Yes, it’s the same battery. My measurement might not be too good. Was using my daughters school ruler so it may be a little off. That is the same battery that fits in my ODF30 and works just fine. Going outside in a bit as soon as it’s really dark and I will post some beam shots.
Same here. I got my lumintop odf30 from banggood. Big discount using coupon code. Great quality light… lumintop did good job on the quality control and stuff.
I have a question about 26650 Efest IMR LI-MN 45A 5000mAh.
I checked Efest IMR 26650 LI-MN 45A 5000mAh.
Diameter:26.50mm
However, Mr.M4D M4X lists it when 66mm is too short.
Mr.toddcshoe,
You put Efest IMR 26650 LI-MN 45A 5000mAh in a flashlight.
And, please wave a flashlight lengthwise.
Does the battery not act violently in a flashlight?
I will purchase Lumintop ODF30 by the end of this month.
Lumintop ODF30 is not sold in Japan.
I will purchase it in gearbest or Banggoode.
And I will purchase 26650 Efest IMR LI-MN 45A 5000mAh.
Hi, CM2010
Do length and the diameter of Kppower imr6000mah 26650 not have any problem for ODF30?
I can obtain KEEPPOWER IMR 26650 5200mAh in Japan.
MAX : 30A / Constant : 15A
Diameter:26.10mm (±0.2mm)
Length:67.50mm (±0.5mm)
This battery is long.
As for your Keeppower imr6000mah 26650 battery, is Length 67.50mm?
Does the battery fit ODF30 without a problem?
I asked Lumintop.
Lumintop recommends the battery with the protection function.
It is not IMR battery.
Is Lumintop wrong?
Should I use IMR High-drain battery?
Is Efest IMR LI-MN 45A 5000mAh 26650 High-drain battery?
Is Keeppower IMR 6000mAh 26650 High-drain battery?
