What do you think of OLIGHT R50 PRO SEEKER 3200?
Hello toddcshoe,
I thank for your detailed answer.
Is the battery of Efest the following product?
Efest IMR 26650 LI-MN 45A 5000mAh.
The consecutive electric discharge upper limits:45A
Maximum moment electric discharge:50A
Diameter:26.50mm
Length:65.20mm (±0.2mm)
http://www17.plala.or.jp/x000x/battery3.jpg
You have Efest IMR26650 5000mah of 67.5mm.
The length of Efest which I checked, 65.20mm.
Are these two the same things?
best regards.
Yes, it’s the same battery. My measurement might not be too good. Was using my daughters school ruler so it may be a little off. That is the same battery that fits in my ODF30 and works just fine. Going outside in a bit as soon as it’s really dark and I will post some beam shots.
Same here. I got my lumintop odf30 from banggood. Big discount using coupon code. Great quality light… lumintop did good job on the quality control and stuff.
image hosting
OK, Thank you!
Where can I buy Lumintop ODF30?
I do not know the coupon cord of banggood.
Will you tell me the coupon cord of banggood?
Should I purchase it in GearBest?
I know the coupon cord of GearBest.
The coupon cord is LODF30.
https://www.gearbest.com/led-flashlights/pp_1827679.html?wid=1433363?lkid=13532966
Which is a low price?
AND
I have a question about 26650 Efest IMR LI-MN 45A 5000mAh.
I checked Efest IMR 26650 LI-MN 45A 5000mAh.
Diameter:26.50mm
However, Mr.M4D M4X lists it when 66mm is too short.
Mr.toddcshoe,
You put Efest IMR 26650 LI-MN 45A 5000mAh in a flashlight.
And, please wave a flashlight lengthwise.
Does the battery not act violently in a flashlight?
best regards.
No, the battery does not shake inside the light. Fits just perfectly.
Agreed, I really like it so far. Lots of light and a great beam. Lights up a pretty large area.
Gotta to try those batteries.
I use Keeppower imr6000mah 26650 in my ODF30.
OK, Thank you, everybody.
That’s reassuring.
I will purchase Lumintop ODF30 by the end of this month.
Lumintop ODF30 is not sold in Japan.
I will purchase it in gearbest or Banggoode.
And I will purchase 26650 Efest IMR LI-MN 45A 5000mAh.
Hi, CM2010
Do length and the diameter of Kppower imr6000mah 26650 not have any problem for ODF30?
I can obtain KEEPPOWER IMR 26650 5200mAh in Japan.
MAX : 30A / Constant : 15A
Diameter:26.10mm (±0.2mm)
Length:67.50mm (±0.5mm)
This battery is long.
As for your Keeppower imr6000mah 26650 battery, is Length 67.50mm?
Does the battery fit ODF30 without a problem?
I asked Lumintop.
Lumintop recommends the battery with the protection function.
It is not IMR battery.
Is Lumintop wrong?
Should I use IMR High-drain battery?
Is Efest IMR LI-MN 45A 5000mAh 26650 High-drain battery?
Is Keeppower IMR 6000mAh 26650 High-drain battery?
best regards.
I have the Keeppower imr5200 and imr6000 and both fit and work great in the ODF30.
The length of the 6000 is 66.7
Hi, CM2010.
Thank you very much.
Your opinion served as a reference very much.
Just a note to mention that the ODF30 does not have reverse polarity protection so be careful.
I got the R50 Pro a short while ago and really like it but then I got it for a very good price with a 2nd battery. The build quality is excellent.
Hi OP, I can’t share the code. You will have to register m4d website. It was like $20 off from banggood. I link the website below.
https://m4dm4x.com
Hi, Newlumen .
OK, Thank you very much.
Lumintop odf30 fits liitokala 26650. ( 65.8mm ).
https://www.aliexpress.com/store/product/1PCS-LiitoKala-26650-50A-5000mah-26650-Li-ion-3-7v-Rechargeable-Battery-for-Flashlight-20A/217753_32793359110.html?spm=2114.12010608.0.0.338d2b2fRRj5Kf
Hi, Newlumen .
Hi,
Lumintop ODF30,
Does the side switch LED of Lumintop ODF 30 light up?
When do LEDs turn on?
Best regards.
Those discharge rate specifications are a lie. Period.
Efest rewraps cells from OEMs. Nothing wrong with this, but they like to inflate the actual OEM cell specifications in a twisting, consumer misleading way, and on top of this try to charge you more. No way Efest.
I second Newlumen's cell suggestion but please check these AliExpress vendors' offers with a much cheaper shipping and handling quote to Japan (cells are blue wrapped but they're equivalent):
Cheers
Love my r50 pro seeker LE
This is our family go to work horse for around the house.
Stays in the kitchen cabinet in its charger always ready to go.
Nice size and hand.
Olight perfection on fit and finish, if your into that kind of stuff…
Hi,
I’m sorry to bother you.
I bought the following products at Banggood.
I have a question to the following products.
Lumintop ODF30 XHP70.2 3500LM 6Modes
Brightness Power Indicator LED Flashlight
I have to 5-questions.
Please answer in detail to all the questions.
At first, please watch the photograph of the URL.
http://www.lumintop.com/wp-content/uploads/2018/03/20180315061816_66180.jpg
(1)What kind of situation is output/mode shift?
(2)How do you operate output/mode shift?
(3)How does the indicator of the switch shine?
and
I locked-out a flashlight.
However, the indicator in the switch does not change.
As for the indicator, the lighting does not flash on and off, too.
(4)Is not the problem that the indicator does not light up or blink?
I think that the indicator is broken.
and
Capacity of the battery decreased.
(5)Is not the problem that the indicator does not light up or blink?
I have never watched the light of the indicator.
I think that an indicator is broken.
At first, please answer a question.
Please check the correct information.
I want to know the answer as soon as possible.
Best regards.
