Discussion : - Utorch UT01
206 posts / 0 new
duvallite
Last seen: 1 week 2 days ago
Is there a solution for the problem where if you turn the light off, it won’t turn back on until you break the circuit by loosening the tailcap and then re-tightening it? Both of my UT01s do this, but only with my 14500 cells (unprotected).
beam0
beam0's picture
Last seen: 3 hours 1 min ago
Seems there’s been a few with this complaint, I haven’t seen a fix posted. I think I recall someone did say it may be the type of battery. Sounds like a driver issue to me. I would definitely file a ticket for refund or replacement.
wle
wle's picture
Last seen: 38 sec ago
I’ve had a UT01 for 3 months now, heavy daily use, no problems, great light, I mostly use an Eneloop LSD NiMH
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
nquinn
Last seen: 1 month 1 week ago
Has anyone posted a runtime test on medium on this thing?
I’m a little confused on how it could be so different from the SF14:
Sofirn SF14: Low 3 lumen/ 111h; Medium 33 lumen/ 10h27min
Utorch UT01 (AA/xp-l): Low 2 lumen/171h; Medium 60 lumens / 11hrs
Utorch UT01 (14500/xp-l): Low 10 lumen/44h; Medium 100 lumens / 12hrs
How could this light on medium run at nearly double the lumens for longer than the SF14?
The stats on 14500 are even more impressive.
Which ratings are accurate or not?
beam0
beam0's picture
Mine started this problem tonight. It had been working just fine on a Imren 14500 IMR, pulled the cell out measured 3.8v so I charged it and several other 14500’s, popped in an new Soshine 900mAh and the problem started, it will turn on only once until you break the circuit, and then only once again. It’s even doing it on an alkaline that measures 1.59v.
Very strange seemed like putting a fully charge battery in is what killed it. Filed a ticket with Gearbest, I’m pretty much done with this light for now.
pennzy
pennzy's picture
Last seen: 19 min 35 sec ago
I hope the problem is eventually fixed going forward. I’ll wait this one out until then.It must be a pretty great little light if everyone is still buying it knowing it has issues.
beam0
beam0's picture
Its a nice light but I wouldn’t buy another one right now, not even for the for $9.99 that I paid. I already had to fix the battery length issue and switch problem to make it usable, now it’s unusable again.
Not sure why anyone would buy one of these after reading these issues, unless they like to just roll the dice, even for a host they’d need to fix the battery length and maybe the switch, and I haven’t see any deals for $9.99 anymore. The Sofirn Sp10A would be a better choice, currently on sale for $10.93
I was quite happy with it after doing the switch mod, until this happened. I do like the UI, size/form and warm tint, considered the Lumintop EDC05 but I’ve already read many are having the same issues with that one too, (both the switch issue and having to break circuit every time issue) and it also is reported to have considerably lower max output. There’s also the Manker E11 that I believe is the original of this design, suppose to have output like UT01 and is rock solid reliable, but it’s $30.
Gearbest wants me so send in a video of the problem but the file needs to be less than 2mb, so now I have to work on that now too.
pennzy
pennzy's picture
Like they never heard of these problems before. By now , they should just ship out another one , no questions asked.
beam0
beam0's picture
Yeah exactly what I was thinking, so I replied I couldn’t make a video, we’ll see what they say.
Dunno if I want another one though, maybe a credit.
BLightSam
Had that issue also with another item, but did not progress further. Was going to ask them if they have a video showing the item working properly when shipped. Or any proof that the item was even inspected.
duvallite
One of mine was originally DOA, so I opened a ticket with GB. They wanted a video, but I told them I had no means to make one, and instead sent 3 pictures. Pic 1 showed the battery voltage on a DMM, the 2nd showed that same battery in the light, and the 3rd just showed the LED end of the light not lit up. They offered to replace, credit, or refund, and I could keep the DOA light. I took the credit and bought a On The Road M3 light, which is very nice and has a magnet in the tailcap. I still greatly prefer the feel of the UT01, and hopefully my 2 working ones will keep working properly with eneloops. Not as awesome as with a 14500, but still very good. It’s a great little light when working as it should. Really hope they get the driver issues fixed on the UT01 and also on the Lumintop EDC05. I’m thinking about trying to replace the switch. I’ve read some comments where doing that has fixed all problems for some people. Maybe worth a try.
GreenLights
Last seen: 5 hours 2 min ago
[/quote=beam0]Mine started this problem tonight. It had been working just fine on a Imren 14500 IMR, pulled the cell out measured 3.8v so I charged it and several other 14500’s, popped in an new Soshine 900mAh and the problem started, it will turn on only once until you break the circuit, and then only once again. It’s even doing it on an alkaline that measures 1.59v.
Very strange seemed like putting a fully charge battery in is what killed it. Filed a ticket with Gearbest, I’m pretty much done with this light for now.[/quote]
Nothing has happened to mine yet, thankfully, but after reading this I immediately put in a fully charged battery. Maybe if I keep the battery above 4v I can prevent the problem. I don’t know, just a theory I came up with after reading your post. I hope someone finds a fix, or Utorch fixes this problem, as it is a great little light.
Edit: I guess I don’t understand how to quote someone.
Just discovered this wonderful addiction.
d_t_a
Last seen: 4 hours 49 min ago
My 2 UTorch UT01 behave that way (one was using AA, the other a 14500)..
After turning on and turning off, it won’t turn on again. Will need to unscrew (break the current) before it will turn on again.
Already past the Gearbest refund period.. (bought a few months ago) — well actually one had been refunded due to another issue it had before I fixed it. But now, this is a new issue that affects both units..
komeko
komeko's picture
Last seen: 3 hours 2 min ago
My UT01 worked reasonably well, i.e. the switch was uncertain. Putting the washer, it worked well, but over time it got worse. Today I decided to replace the old one with a new switch. As I put it together, it turned out that I was affected by the general problem, i.e. not turning on the light at 14,500. Just in case, I checked all February, changed the switch again, etc. With NiMh it works perfectly.
The 100% problem here is electronics, not mechanics. As UT01 was in good working mode, he was charging 4.7uA on NiMh and 14uA for 14500 in standby mode. Now, as something changed, it is 101uA and attention, 2.3mA so 164 times more than before. In my opinion, this high drainage is the reason that the lamp does not turn on. I can not find the culprit. The pipe and tail do not affect this parasitic drainage.
Click on:        ANSI WHITE
Click on:        MY COLLECTION
Click on:        Q8, D4, D4S, D18, K1, FW3A, SDmini, Mini AAA, TIP, M43, H1, H03, TC20, TN40S, TN42, V6, H600Fw, SC600w, SC64w
eas
eas's picture
Last seen: 4 months 1 week ago
I have no problem with high standby drain when I take the tailcap off and test with a 14500, but when I put the tailcap back on, the button only works once before I have to break the circuit to reset things again.
d_t_a
I have 2pcs UltraFire “1200mAh” 14500 (actual tested discharged capacity with analyzing charger for both is between 250-300mAh).
(not a scientifically controlled test)
Freshly charged both of them. Placed one of them on my UT01, the other is not used.
With the UT01, I tested that it works (it turns on, then turn off). I know mine has the issue that after turning off, it won’t turn on again until I break the circuit.
In my test here, I did not break the circuit after I tested the battery. But I was wondering how much was the self-drain when I did it.
Anyway forgot about it until several days or maybe up to 2 weeks, I didn’t touch both batteries (both the UT01 and the other 14500).
After that period of time, I tested the UT01 and it won’t turn on, even when I broke the circuit. I removed the 14500 inside the UT01 and tested that it has drained to below 2.0v! (so the UT01 drained that 14500). The other Ultrafire 14500 has also self-drained a bit, but it was still around 4.0v or somewhere there (from being freshly charged and just kept in storage).
Just to test if it’s self-drain or these low-quality Ultrafires or the UT01, used a different 14500 (capacity around 14500).
It was around 3.9x volts when I placed the battery inside the UT01, then turned it ON and then OFF, and did not break the circuit after that.
After several days (maybe 5 days or so), that battery still works (tested by breaking the circuit and turning it back on). But the voltage has dropped a slight bit (was 3.9x, and now was 3.8x volts resting voltage). So maybe the UT01 indeed has some high parasitic drain (or at least my UT01 has).
I haven’t had time to do more comprehensive controlled testing though..
sovereignknight
sovereignknight's picture
I have the EXACT same issue with the Lumintop EDC05!
https://en.wikipedia.org/wiki/John_3:16
Flashlights:
x2 Sk68 modded 1 Nichia 319AT, 1 Cree XP-G3 - x1 Solorforce P60 drop in custom XM-L2 U4 1C, Qlight Rev.A 7135*8 3.04A Driver - x2 Lumintop EDC05 CW - x2 Jaxman E2L tripple XP-G2 S4
x1 Jaxman Z1 Zoomie, w/ Cree MT-G2 Q0 LED - x1 Acebeam K40m thrower with MT-G2 Q0 LED - x1 Xintd SC-82 V5 Limited Edition C8, XM-L2 U4 1C, Qlight Rev.A 7135*8 3.04A Driver
x1 Convoy L6 moded with a Cree XHP-70.2 P2 1D LED - x1 Rare Olight x7 Maurauder with a Nuetral White LED - x1 Astrolux MF-01 Nichia 219c - x1 Astrolux MF-01 Cree XP-G3 - x2 Zebralight SC5w MKII
x2 Lumintop Tool AA - x1  x2 Lumintop Tool AA 2.0 - x1 Lumintop ODL20C - x1 Lumintop GT mini - x1 Olight i3E EOS - x2 Zebralight SC600w Plus MK IV XHP 50.2 4500k 80 CRI - x1 Fenix CL30R - x1 Lumintop C01 Bike Light - x1 Lumintop Zoom 1 - x2 Zebralight Sc700d - x2 Lumintop Tool AA 2.0 Ti - x1 Olight I3T EOS
joechina
Oh, the new Utorch S1 mini has also a prolem at 3.8V: At 3.8V you had to cycle power if you want HIGH for a second time.
garbaetsch
Last seen: 1 year 2 weeks ago
Ha, ha, 4 of my 5 UT01 have this bug… All of them (incl. the good one which still works without any issues) I therefor switch off by turning off.
eas
eas's picture
It used to be that 2 out of 4 of mine had this bug. Then, a week or so ago, I decided to do an emitter swap on one of the ones that worked with 14500s. A few days later, it developed the problem, too, despite never seeing much use before or after the emitter swap.
So, I pulled out my once tested and otherwise unused UT01. I swapped the emitter in, and noticed along the way that the reflector was no longer threaded like it had been on the first three (so they’d done some redesign). Now, tonight, after a few days of minimal use, it now has the same problem.
This makes me very angry.
Zulumoose
Zulumoose's picture
Last seen: 1 month 1 day ago
I thought I had one of the good ones. Worked fine for a month or two, then it developed the same issue as everyone else’s. Not buying Utorch again in a hurry, this issue was known LONG before I bought mine, seems like they had no interest in solving it.
Beam me up!
eas
eas's picture
Oh, even better. I downgraded this latest casualty to NiMH; It has the same problem with those!
Petr J.
Petr J.'s picture
Last seen: 3 weeks 5 days ago
I have UTOCH UT01 for about a year and it works without any problems. I use it irregularly. After reading today’s answers, I measured the battery. After a few months when I did not use the lamp, it has a voltage of 3.9 volts. So my UTORCH does not have a large parasitic current drain. I only use the Li-ion 14 500 battery.
wle
wle's picture
mine broke after 1 year
i probably use it 30 times a day so that would be about 11,000 switch operations
still
bad design or bad part
wle
-Greg Lemond.
T-boon
how hard is to make a properly working light,
my UTOCH UT01 have the same problem, need to break the contact after turning off the light,
i mean i love this light, so nice and compact but common this fukin switch/driver is a deal breaker,
i need to buy more AA/14500 light but nothing new the past year or so Facepalm
