The new Jaxman E3 flashlight comes in the new year
211 posts / 0 new
g_damian
g_damian's picture
Last seen: 1 hour 30 min ago
beam0 wrote:
Yes thanks for the tailcap currents Thumbs Up
mode 3, eneloop………2.3A
mode 3, liion (2)……….2.7A
So Li-ion doesn’t offer much more brightness vs NiMH?
(1) is rested cell and (2) is fully charged? What is the voltage of rested?
W=A*V
So Li-ion is a lot brighter, because 2.7*4>2.3*1.35. (also note voltage of batteries)
(1) and (2) are two different 14500 cells, both charged. (1) is protected, (2) is not.
beam0
beam0's picture
Last seen: 1 year 3 weeks ago
W=A*V
Ok thanks, I didn’t consider the voltage Facepalm
So the NiMH only produces around 3.1 watts, and the Li-ion produces around 10.8 watts?
"Over 2000000 hours (about 200 years) standby time"  (DQG Tiny 4th)
"27,157 results for zoomable flashlight" (ebay)
Persechini
Persechini's picture
I got my new version E3. I like it a lot and it would be a candidate for my favorite AA/14500 flashlight, except when I use a 14500 cell all the modes are very close in brightness to max (not single mode, all 3 modes are different, albeit barely). I wonder if this is the intended behavior or my unit came defective
In my Tree
My collectionEmisar: D4 / D1 / D4 (broken) ― Convoy: C8 Clear / S2+ Clear / S2+ / S2+ UV / S6 ― Nitecore: Tube / Thumb / Concept 1 / HC30 / HC33 / TIP / TIP CRI / TINI ― Lumintop: Tool AAA / Tool AA / HLAAA / EDC05 ― Sofirn: SF10 / SF12 / SF12 / SF14 / SF14 / SF14 / SP10A / SP10A (gifted) ― Jaxman: E3 ― UTorch: UT01 ― Trustfire: Z2 ― Skyfire: SF-065 (trashed)
SKV89
Last seen: 3 hours 4 min ago
I really like my E3 alot. It has a very nice tint, which is rosier than most 219C I’ve seen. The start on moonlight mode and 3 brightness mode makes this a very user friend AA flashlight. If I were to choose the best AA flashlight to give muggles, I would choose either the E3 or the Reylights. Both perform about the same in terms of brightness but the Reylight looks alot nicer for 4x the price.
beam0
beam0's picture
SKV89 does your E3 have the same mode spacing issue (when running on Li-ion) as Persechini reported in the post above yours?
SKV89
Yes same issue. Fortunately the AA mode is pretty bright. If I want a bright 219C 14500 flashlight, I’ll use the Reylight Ti Lan or Pineapple.
d_t_a
Last seen: 1 hour 12 min ago
That means it’s a lottery with the tint?
I also ordered Jaxman E3 4000K, but the tint isn’t that great (sort of yellowish), definitely not rosy (unlike one of my BLF A01 which has a really rosy tint)..
Will post a pic to compare them…
With regards to brightness level when using 14500. While I could measure a difference in tailcap current from Low-to-High (it’s similar to the one mentioned above), the brightness (using our eyes) from Low-to-Medium is very little difference. While Low and High (although there’s a bigger difference in tailcap current drain, the actual brightness difference seen by my eyes is also not that big a difference. The flashlight does get hotter much more quickly when using 14500 in High mode though).
Unlike when using AA, there is a nice spacing of brightness levels from Low to Medium to High (I think the AliExpress website indicates it’s supposed to be 1-60-350 lumens? Anyone can confirm if those are the real values?) I wonder what is the actual lumens rating when using 14500 — maybe someone who knows how to measure lumens can answer it (I have a basic lux meter now but don’t know how to compute/convert that to approximate lumens…)
SKV89
It’s rosy compared to other 219C but not as rosy as the 219B 4000k an definitely not as rosy as my Emisar D4 5D tint, which has a tint that is almost pink.
I will post some comparison ceiling bounce values with other AA lights later.
Persechini
Hmm, so mode spacing using 14500 is not exclusive to my unit, it’s either a manufacturing issue or a design issue
As for tint, mine is quite neutral and pleasing, not particularly rosy, definitely not greenish or yellowish
In my Tree
djozz
djozz's picture
Last seen: 1 sec ago
It is most certainly a design issue. I think it takes quite some electronics and software expertise and probably extra components on the driver to get the modes right for both AA and 14500 when not all modes are made by PWM (the low mode isn’t). They chose to get the AA modes right and left the 14500 modes for what it is and that is understandable.
beam0
beam0's picture
Is the Li-ion mode spacing problem because of the current? So there would be the same (or near the same) problem with NiMh eneloop?
Persechini
Cheaper lights I have offer better aa/14500 versatility. This one kinda disappointed me, it should be advertised as AA only
In my Tree
DB Custom
DB Custom's picture
Last seen: 18 min 34 sec ago
NiMH works fine in it, it’s the Voltage difference that causes problems when using Li-ion.
When designing a driver that can use both AA/NiMH and Li-ion, compromises must be made. Expense considered…
ggf31416
Last seen: 4 hours 5 min ago
I don’t have the Jaxman E3 but from the current values I think the 350 lm may be true off the emitter for NiMH for the Cree version:
Fully charged NiMH: 2.3A x 1.3V = 2.99W. — 2.99 × 0.8 = 2.4
Partially charged NiMH: 2.3A x 1.2V = 2.76W — 2.76 × 0.8 = 2.2
Assuming 80% efficiency that means between 2.4W and 2.2W at the emitter.
From CREE PCT, a XP-G2 S4 should output (at 25ºC):
340.3lm at 700mA 3.04V = 2.13W
380.7lm at 800mA 3.07V = 2.46W
419.6lm at 900mA 3.10V = 2.79W
So, 350 lm at 2.4W is doable if the led doesn’t get too hot. That value ignores losses at the reflector and glass.
From Texas_Ace test a Nichia 219C D240 should output about 280lm at 2.1W and 350lm at 2.9W. Assuming 80% efficiency I would expect about 300lm with a NiMH AA for the Nichia version.
2.7A with a li-ion is almost like a 8×7135 linear driver, it should be able to output at least 800 lumens off the emitter.
To get an estimated of the actual output you can measure the lux (aiming the flashlight at the ceiling and measuring the reflection) both for a flashlight with an known accurate lumen rating and for the tested flashlight at the same position. The former will get you a lm/lux ratio for the lux meter position. You may need to repeat the meaurements with the lux meter at 2 or 3 different positions because how floody the light is may affect the results a bit.
See this thread for more details: http://budgetlightforum.com/node/35949
beam0
beam0's picture
Thanks for explaining.
When I get my E3 I’ll use NiMh for it, then eventually change the driver to use Li-ion and maybe gain a little power boost too.
Persechini
Jaxman replied me on AliExpress and said the listing on other sites was updated to warn about this, but the listing on AE ended up being left behind and not updated to reflect this. So it’s by spec that it behaves this way. A pity as my intentions involved the dual chemistry capability, but it’s a nice AA flashlight nonetheless and build quality is above average for products I have in this size
In my Tree
Lightbringer
Lightbringer's picture
Last seen: 6 hours 31 min ago
Try a LFP cell, 3.2V vs 4.2V.
hatman
Last seen: 3 days 9 hours ago
The Jaxman E3s are wonderful lights.
I have the two-mode version from a few months ago. It works well and the tint and beam are just beautiful. I have more expensive AA lights from EagTac and ZebraLight and the E3 is strong competition for all of them. At the price, it is a no-brainer.
I love the ergos — the light just fits my hand so well. It is light enough and compact enough to easily EDC.
The E3 works well on both Eneloop and 14500. (One of my AW’s is too thick to fit, apparently because of the label; my other AWs fit and work just fine.)
I just ordered two of the three-mode version — a 4000k and a 5700k.
Jaxman, I hope you keep the E3s in production — they will make fine gifts for non-flashaholic friends.
Persechini
How are the modes with 14500 on the previous driver?
In my Tree
hatman
As Jaxman says, there’s just one mode with 14500s.
I have mostly used my two-mode E3 4000k with Eneloops. High produces enough lumens to walk the dogs around the block in a suburban setting. There’s also little heat on high.
Eneloop use also makes the E3 perfect to stash in a drawer, tool chest or car.
I do sometimes switch to 14500s. But that’s mostly out of curiosity to see how much light this little guy can produce. I have 18650s for when I know I want lots of lumens.
d_t_a
“one mode for the 14500” — actually it’s not one mode, it also has 3 modes, however, there is very little visible difference in light output from Low-Med-High. I measured 0.9A, 1.3A and 2.3A using a (nearly-but-not-full-charged) 14500. However, the actual brightness of Low and Med is almost negligible, and even the High mode is not that visibly much brighter than Low and Med (although when High mode, the flashlight will get warmer more quickly).
I suppose that’s what Jaxman means by “one-mode”..
hatman
Correction — upon further investigation, there are TWO levels of output using the 14500 on the “two mode” Jaxman E3.
The difference is clearly visible although it is not huge, at least on my wall. And “hi” does put out more heat.
I am looking forward to getting my three-mode E3s — I love this little light.
Persechini
My only gripe is it being presented as a double chemistry flashlight, but an AA flashlight, yes, it’s impeccable.
In my Tree
SKV89
For those interested, I posted ceiling bounce measurements of my AA flashlights. I didn’t convert them to lumens because I don’t have benchmark lights that I can claim to be super accurate to obtain a multiplier. However, since I measured so many, you can compare their brightness relative to each other and get a good idea how each perform relative to other AA flashlights.
Carpe Cuprum
Last seen: 10 months 2 weeks ago
I just picked one of these up on Aliexpress, and I am really impressed by the quality. I didn’t use it much in stock form (not the flashlight’s fault…I never intended to), but I can tell you that it is an excellent AA host. It is MUCH smaller and thinner than I anticipated. With some filing, I squeezed a triple XPL HI V2 5D Noctigon soldered to an MTN electronics copper S2+ spacer under a Carclo 10507, and dropped in one of MTN’s 17mm FET/DD drivers. It’s a tight fit, but it is INSANELY bright for a AA and handles heat very well. I can also confirm that the deep carry clips from both the Astrolux S3/SC and the Olight S1a fit it perfectly. Fantastic little EDC torch!
Persechini
That’s an insane mod XD
In my Tree
MascaratumB
MascaratumB's picture
Last seen: 21 min 42 sec ago
Apart from the XPL-HI, that is the kind of mod I’ve been wanting to do with that light…when I get one Wink
Did the Carclo optic fit without being “shaved” or filled? That is my only “if” on that building as I already know what I will prefer for the driver and emitters Wink
If you can, show us the mod on the thread “What did you mod today” Wink
[REVIEWS] AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// ACEBEAM: H20 / TK16 /// BLITZWOLF: BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 / E10 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// KLARUS: XT1C /// LUMINTOP: Tool AA V2.0 + Tool 25 /// LIVARNOLUX: 314791 /// SKILHUNT: M150
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2 /// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
GIVEAWAY: 1
SKV89
Wow thats a really cool mod. High output and beautiful 5D tint. Do you have any lumen estimates or comparisons with stock emitter?
Carpe Cuprum
MascaratumB wrote:
Apart from the XPL-HI, that is the kind of mod I’ve been wanting to do with that light…when I get one Wink Did the Carclo optic fit without being “shaved” or filled? That is my only “if” on that building as I already know what I will prefer for the driver and emitters Wink If you can, show us the mod on the thread “What did you mod today” Wink
Unfortunately you do have to shave the optic, but it still had quite a bit of real estate to spare. The inside diameter of the steel bezel is about 18mm, and you lose another 1-1.5mm to the lip. It still had quite a nice beam profile imo, though, for what it’s worth.
I managed to hose up the driver trying to install a bleeder resistor for a lighted tailcap because, you know, I never learned to leave “well enough” alone, but I will post pictures as soon as I have it replaced!
Carpe Cuprum
I’m not great at estimating, but it was considerably brighter and more “floody” than my BLF X5. I would SWAG it around 2-2.5k. It’s WAY brighter than the stock emitter, and the tint is comparable to my eyes. I know color rendition is supposedly worse, but I’m not sure I’m learned enough to really tell a difference….
