I’m hoping that this will be the best selection for my application (save a much higher number NEMA scale beam angle) a 28’ pole situated close to the house on the other gabled end. The light will try to illuminate what the other gable light does not (side yard) and the other end of the house
The whole interchangeable lens concept took me by surprise as I was certainly hung up on the previous NEMA beam angle numbers mentioned and probably never getting what I was after. This one came in at $236 (I didn’t shop around).
We’ll see what happens…
I finally managed to hook the 15,500 lumen Westgate up using an extension cord on the second story porch so that I could judge where I wanted it to point on the 28’ pole. The Type 2 beam pattern is pretty much as advertised (oblongish). The coverage is hard to judge at 13’ with a deck below your feet yet I’m pretty impressed. The tint seems even better than the Morris and seemingly more natural. The overall brightness seems less (as advertised) yet the other one is 30’ up so I have no idea. The beam patterns will probably overlap a bit so we’ll see.
Light years different (better) than any other yard light that I’ve ever owned or installed. i like the idea of the remote operated motion sensor with dimmer yet I’ve not been quoted it and I’m not sure that I want to part with the coin. Might just go dawn to dusk at only 150 watts yet even a cheap timed motion control has its advantages.
Again, I was just as skeptical this time around regarding any 3000K claim as I was with the Morris. It sure beats the halogens, sodiums and halides.
Thanks my friend. I follow your adventures as well and learned in the process. Too many projects this spring so I decided to bust my finger all up and put them all on hold. It will get up on that pole laying in the driveway (still) soon enough as I’m eager to see what it looks like. Cutting the cable and going back to the antenna/simpler days of old right above this new light is a motivator in and of itself.
We’ll see…
…in the meantime, I went to Home Depot and picked up 2 small socket extensions. I had previously purchased a 100,000 L corncob at Menards on a whim (sale price was $52 if remember). Screwed all 3 in to a standard two bulb floodlight style motion light (had to support it a bit at the fixture deflector’s edge) This should get me by until I’m all healed up and the Westgate can (finally) shine.
…I would say that a 100,000 lumen corncob might not be the most efficient way to light up an area but that it does the job in a pinch. Directional shielding or just plain shieldng your view of it is obviously needed. It throws light a lot farther than expected and some nice shadows in terms of any movement through the coverage area.
Lost all sense of reason/frugality/(not to mention) pledges made and purchased the following today:
(1) PN# SK618-601X outdoor rated control which senses motion (turns on/off and has an adjustable timer), is remotely dimmable and which can be manually controlled (off/on) through PN# SK618RC. The remote is evidently RF controlled and should go through walls.
The above was what I was told these two part numbers would do for the Westgate light above.
…amazing that we’ve gotten to the point of swapping these higher lumen bulbs in while forgetting about replacing them anytime soon. The rub seems to be these bulbs at $20 some odd each versus the 10,000 lumen corncobs at around $50 (on sale).
These were reasonably priced, free!
My brothers son is doing a retrofit of stadium lights at a ball field. He is replacing these 1500 Watt - BT56 - Metal Halide fixtures with LED’s.
There were 13 available to me but I only took 3.
It took me awhile to determine that they ran on 240VAC. Here they are on the floor of a commercial building
that has 120VAC 3 phase. To get the full 240VAC I had to connect a booster to up the voltage across 2 legs of the 3 phase from 208V to the full 240V. These things are bright! About 75,000 lumen each and 4000K.
The bulbs, transformers and capacitors are huge.
Believe it or not, those 1500W bulbs are only about $23 each.
Now the hard part, figure out why I need these and use them to fill that need :laughing:
I like free.
What a treat to get an inside look at how these operate. Hard to imagine that the bulbs are anywhere near that price! (I pay at least $18 for just my 175 watt version that I can’t fit a LED bulb in to).
If you don’t ask your wife that question….it will never require an answer….
Thanks for sharing.
Are there any adaptors out there squatty enough or could you pick up one of those larger socketed LEDs (corncobs; yet the larger socketed ones seem pricey for some reason) and fit one underneath the glass? (bypassing the ballast). 100 or 150 watts versus 1500 ‘if’ they last (the big question). My $52 FIET (?) 10,000 L cheapy from Menards is still plugging along every night on a motion that switches on a lot (so far)…
Against my better judgment and all sense of both reason and “if-it’s-too-good-to-be-true-it-isn’t” I (justifiably) blamed pennzy (above) and went with the 100 watt/warm version of who-knows-what (pennzy, my wife would like to talk to you…).
There comes a point (at these prices) where there is not much else to do but have faith in your fellow man and hope that you are supporting his or her efforts to feed his family too. I’ll try to report back if nobody else was/is as gullible as I apparently am.
Keep in mind that the “only 1 left” sucker-you-in warning immediately changed to “In Stock” after my order so your mileage may vary (I want to say that the delivery was June 20th?). I’m also concerned that I didn’t receive an Amazon confirmation right away so that might be telling this story in and of itself (never had that happen yet not familiar with the ins/outs of their process).
