Thank you. I recently bought a phone with the type c, it seems superior. I was thinking about it as a long term reliable piece. Maybe there is a way to convert micro USB to type c down the road.
My opinion is that the micro usb option is the way to go since it’s almost certainly cheaper and also doesn’t require those of us not using type C at the moment to have to purchase new cables.
On the type of plug, type C is becoming the standard for a lot of devices already, and as it does, the availability and commonality of the plug will have products that only use usb for charging also migrate. A flashlight is an item that will last us for a long time, so I’d rather have it use the plug that is becoming standard in the near future than the one that is slowly but surely being phased out, even if it ads a little to the price. But at this point in the transition, micro USB oriented arguments still have a very strong foothold, just not my personal preference, specially since for charging purposes cheap adapters can be used instead of renewing one’s entire cable collection.
I second that. Most of my items use Micro USB. But my all most-used items use type C already and for my buying Micro USB ones is just going backwards. I do not see the choice of Micro USB as wrong and I recognise that for some users it can be a better short-term solution. And medium-term probably as well.
At the same time I strongly prefer Type C - it is a standard now and will become the standard soon.
I agree and although at the present time I need both if I leave the house, I feel sure that ‘c’ will become the standard.
I recently got a Note 8 phone which uses the type C and I have to admit the C is much easier to use if your eyesight is failing(or in a dark tent) completely eliminating the hassle of figuring out the plug orientation. It is so much easier for me. For those that have reservations about having to buy a type C cable……If you dont have anything that uses C now, you soon will and I cant see the small (if any)additional cost of the C plug being a issue.
Congratulations on the progress! I’m already on the list at position 535 for 1 lantern. Can I get added for another 2 lanterns please. Also is there a rough idea of price yet?
- Ok, I have the new lantern head for the V2 Q8-based prototype completed! I reflowed two 3000K XP-L emitters to the original modified Q8 copper star, (i only had two of these bare LEDs so i could not use all four pads on the star.)
Like the V1 design, i have used a full flat/matte white upper & lower plate light reflector, which works far better at increasing the output through 90 degrees of the lantern globe, while reducing the glare found in most other factory built LED lanterns on the market. Most lights you find on the market commercially make the mistake of using a chrome or shiny “reflector” causing an increase in glare, hard shadows, and does not really work to put it in simple terms. I have tested every possible surface type form gloss, eggshell, matte, chrome polished, and the full matte/flat white is the only one that emits the most lumens, reduces the most glare, and smooths out the hard-shadowing the best.
So… right now I am stuck at the driver, and how to safely lower to the maximum amps to the LEDs…
Below, is the new V2 Prototype head ready for driver modification & first testing, (take notice of the center post bolt design, Much stronger & simpler than the V1, and there is a “sleeve tube” over the center bolt that hides the LED star wire leads, ( the tube is also painted flat-white to aid in reflecting light 90 degrees out the sides”
Below showing the solid aluminum head, with the modified Q8 copper star with the two 3000K XP-L 7A LEDs mounted in place using screws & thermal paste, and the surrounding surface painted flat white on the head, along with the base painted the same flat white. This feature seems to create an increase in gathered light, as the light itself is reflected back & forth against each other, increasing the efficiency of the 360 degree output, and smoothing out the hard shadows in the process while still eliminating the eye glare found in most lanterns:
The lower photo is of the driver, whee I am currently bogged-down on how to lower the total amps while preserving all the Q8 modes for the tests, ( to roughly the equivalent of two or three 7135 chips, but not sure of how to do that yet… ( Hinting for the masters of the Q8 driver design & build to chime in here, ( along with ToyKeeper as right now with all other team members MIA ToyKeeper is the only knowledgeable member we have helping with the BLF Lantern build for the driver & firmware part…
