#GB44 ASTROLUX MF01 18xCREE XP-G3/ NICHIA 219C (12klm) Flashlight Group Buy //// ACTIVE!
2671 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 18 sec ago
Th558 wrote:
About 6 days ago I told them that I can’t solder the leds. I received an email saying I will receive a reply in 48 hours. 6 days later..nothing. Then I told them that I’ll write a very bad review on a popular forum if the issue doesn’t get resolved immediately. Received an email in 13 hours saying they have shipped the new head.
See, you just needed to wait one more day. #nopatience #Chinesetime
Lol. Just kidding
patmurris
patmurris's picture
Last seen: 1 month 6 days ago
ZozzV6 wrote:
I got my Nichia MF01 today. Overall happy with it but I measured the levels outputs with freshly charged HG2 batteries and all outputy were lower than specs. I don’t care most because the difference is not much in the lower 3 level but on high it is huge. It doesn’t steps down after 12 minutes from high but I think it uses high that level what need to be after stepdown.
Nichia leds are known for the trade-off between nice high CRI neutral white and high output.
I measured about the same numbers on my Nichia MF-01 V2 end of last year. I wouldn’t have noticed since it’s bright as hell anyway… but was a bit disappointed of course. Since then i sent it to Lexel in Germany for a driver swap. Now Texas Ace driver with Narsil ramping – like the Q8. Last time i measured it was over 13K lumens of pure Nichia white – with added GITD tape under the optic. That was extra cost of course… but now it really shines as it should/could have. Wink
Wieselflinkpro
Last seen: 2 hours 15 min ago
td1042k wrote:
Has anyone modded this light with XPL-HI or XPL-HD emitters? I think with some VCT6 cells and XPL emitters this light would be a monster (if the driver would allow it).
I dont know. But I think you have to use a unregulated driver to tet extra output with this configuration.
FlashIight
FlashIight's picture
Can the MF01 be run on two cells?
JasonWW
JasonWW's picture
Yes, but power would be limited of course. You may not get turbo.
The battery carrier is 2S2P so it can use 2 or 4 cells.
puccio1969
Last seen: 4 weeks 1 day ago
mmmhhh….interesting! In the meanwhile I wait to receive new Samsugn 30Q cells, can I put 2x LG HG2 flat top to try more testing? If yes, in which configuration? Innocent
JasonWW
JasonWW's picture
Yes, you will have to try different combos. You have a 50/50 chance, so if your first try doesn’t work, move one of the batteries to the other slot. The batteries need to face opposite directions to put out 8v.
Wieselflinkpro
There is the risk of overheating / melting the springs with too hight current.
You will double the current which have to go over one springs compared to 4 batteries.
td1042k
Last seen: 4 months 1 day ago
Ordered mine in XP-G3!
Ultrafire C12 XHP70 2S 18650 Mtn Elec 6V Zener mod driver (super donut beam!)
Ultrafire C12 XPL-HI BLF-A6 FET driver
Convoy L6 Mtn Elec D4 UI driver, XHP70.2
Utorch UT02 NW
BLF Q8
BLF A6 NW
BLF GT XHP35
BLF GT (GT70 CONVERSION CW(SOON))
Skilhunt H03 NW
Astrolux MF02 NW
Astrolux MF01 XP-G3
Sofirn SF14
Sofirn SP32A
Emisar D4 XP-L HI CW
SK68 knockoff
Mini Mag Lite 2X AAA
Convoy M1 build (4X XPL 3V MCPCB, Mnt Elec FET driver)
rizky_p
rizky_p's picture
Last seen: 22 hours 24 min ago
i have my mf01 driver replaced with narsilM from Lexel several weeks ago and i just did springs bypass and now it is making as much lumens (ceiling bounce) as my Haikelite MT09R which is at least a 14.5K lumens flashlight. just wondering Is it safe at this level for the Nichias?
SKV89
Last seen: 4 hours 36 min ago
I just received my modded MF01 219c with buck driver and spring bypasses on driver and battery carrier from Lexel. Ceiling bounced at immediate startup measured 1615 lux vs 1244 lux stock. For comparison, stock MT09R 4000k 80CRI measures 1640 lux and stock MT09R 5000k 70CRI measures 2170 lux. However, the MF01 lumens drop rapidly the moment you turn it on similar to the Emisar D4 whereas the MT09R can maintain lumens much steadier. I guess that is to be expected from the small size of the MF01 so temperature regulation kicks in right away. The beam on the MF01 is a large focused hotspot with very dim mild diffused spill whereas the MT09R has a slightly smaller hotspot but much larger spill for a much more practical beam pattern that I like more.
The tint on this one, which I ordered in February 20 is much rosier than the stock one I ordered in February 03 of this year. I like the rosy tint much better than greenish tint. Compared to Cree 3A tint, this is still not as rosy.
Overall I like this modded light much more than the stock MF01 and it is the only 10k+ lumen 90+ CRI light on the market. Lexel did a good job. I recommend his services.
scantron
scantron's picture
Last seen: 1 month 1 week ago
Interested, 2nd batch
NotSoBrightGuy
Last seen: 2 weeks 5 days ago
Promo code please Smile
BLF A6 / Astrolux A01 / Emistar D4 v2 Nichia 219C / Emisar D1s 5000K / Astrolux MF01 / BLF FWA3 (soon-ish)
andrew124C41
Last seen: 3 months 4 weeks ago
I just ordered one of these with the 219s. I am a semi-retired physician and have done some Forensic work in the past. The relatively good color rendition is important. I have had some problems with Bangood previously but they ultimately took care of the problem. At this point, I have not found any problems with it. After reading about the mods combined with having also just receive the D4 with its unusual UI, I will either try and do the mod myself or send it to Lexel which might be a good idea with respect to time. I have some experience doing modificatons and building electronics…but not reflow. Anway….I like this light.
SKV89
I recommend you have a professional handle it. I had it shipped to Lexel from Banggood and he worked his magic. Saves you alot of time and trouble figuring out how to do it and it’s guaranteed done right. The MF01 is glued tight so most people will not be able to open it without the proper tools. Also Lexel’s prices are very reasonable.
andrew124C41
SKV89 Thanks. I did not know about the mods before ordering or I would have saved some time and money by doing what you did. However, if there was a problem with the light…well you know where I am going with that.
He told me that there are two different mods.
Is one of them like the D4?
What mods did you have done?
SKV89
I did the buck driver mod with spring bypass. Brightness increased from 1244 lux to 1615 lux tested with ceiling bounce. But the most important improvement is the UI. The stock Astrolux driver/ui just plain sucks. If you go with his FET driver, it should bump the lumens alot higher but I wanted longer usable output as the batteries drain. Both should have the same UI similar to the D4.
andrew124C41
As you are, I am not so much interested in crazy brightness that is not really consistant with the power available. Run time is more important along with a better UI. So, I am asking him for the Buck Driver mod with spring bypass. I assume the UI is already firmware that has been programmed?
I am curious….relatively new to this site. I have an LPM for laser measurements… what do you use to measure lux?
SKV89
Yes it does. You can ask Lexel for more info and if you want to tweak anything.
Right now I’m using my cellphone to measure lux from ceiling bounce and convert it to lumens using flashlights with known lumen measurements which is far from ideal. But I will soon own a real lumen “sphere” that our well known TA is producing. A bunch of other guys on this forum will be buying it too so it will become the standard lumen testing aparatus in the flashlight community going forward. Killer deal for only $100 for the 3.5” version.
http://budgetlightforum.com/node/60100
JasonWW
JasonWW's picture
It does sound like the Buck driver will suit you better. Lexel will convert the carrier to 4S for 12v then rewire the leds to 3S6P for 9v. Then the buck driver will regulate the voltage down and provide a steady amperage.
The e-switch User Interface Lexel uses on his drivers is NarsilM v1.2. It’s more advanced than the RampingIOS used on the D4, but the ramping part is super similar. Narsil can also be switched to mode sets to give you low, med, high, etc… RampingIOS is ramping only.
If you want to get a little more serious about measuring lux, to measure throw for instance, you can get a cheap lux meter. The HS1010A and LX1330B are very popular around this forum. They are $15 to $30 typically.
Ps, there is no reflowing in Lexels mods for the MF01.
andrew124C41
I make lasers….so I can solder and work with electronics….question is how complicated is this.
JasonWW
JasonWW's picture
Well the carrier and mcpcb involves cutting traces (a dremel tool is good here) and soldering jumper wires. There are some pictures of how Lexel mods the mcpcb for 6v here. He said modding it for 9v is a bit less work.
http://budgetlightforum.com/comment/1298632#comment-1298632
The driver is pretty straight forward. Physically swap it out and resold the wires to the switch and mcpcb.
The hardest part is taking the light apart now that they started gluing them together. You would probably need a vice with some padding on the jaws and maybe some rubber strap wrenches. I think Lexel has some wooden clamps that are cut to fit around the bezel and some threaded rods to clamp around it nice and tight in order to break it loose. Since you already have your light you can try and see if you can get it apart and if so, you could probably do the rest of the work yourself.
Ps, spring bypasses are not that hard. You just want to add a short length of wire to the base and the very top of the spring so that it’s still capable of compressing down.
scantron
scantron's picture
Order placed!
freeme
freeme's picture
Last seen: 2 hours 57 min ago
Awesome!
scantron wrote:
Order placed!
mortuus
mortuus's picture
Last seen: 7 sec ago
Hi freeme can i get code please for Nichia 219C version ?
Edit: ok thanks order placed!
...where Frugal meets with Flashlight!
flangefrog
Last seen: 7 months 23 hours ago
Hi, can I please have a promo code for the 219C model
Azza
Last seen: 5 months 1 day ago
Please send to me too for the 219C model. Thanks.
JLAu
Last seen: 17 hours 50 min ago
Please send me the nichia code i need 1more Smile
Gofer
Gofer's picture
Last seen: 23 hours 45 min ago
Ordered Evil
MF01 Nichia,MF02, MF02S NW, MF04 CW, L6 OP XHP70 N2 3A @ 7A+ & de dome, Thorfire S70S, Sofirn Q8, Sofirn SP33, C8 XM-L2 @ 3,15A & de dome, S2+ XPL HI V2 1A standard, , S41 Nichia, S43 Nichia Christmas Red Edition, Folomov 18650S, H03 NW, Cometa 2016, Zanflare T1, Workshop Lamp, U'King AAA, SingFire AAA, cheap chinese zoom
ST1300 2k5 @ LED+Xenon
sorry for my poor english - Uncle Google helping me ...
freeme
freeme's picture
Thank you!
Gofer wrote:
Ordered })
