Yes. Banggood is out of stock until April 5th. Rofis MR70 XHP70.2 CW+XP-G2 NW 3500LM Dual Light Multifunction Rechargeable LED Flashlight +26650 https://banggood.app.link/5wI5a6x7vL
Don’t look to me, I don’t know anything about this light.
In theory, they are probably using a common 20mm DTP copper star. We need to get confirmation on that. Maybe someone has looked?
If so, then it should be pretty easy to swap it. Just undo the bezel and take out the reflector. Unsolder the 2 wires and undo any anti rotation screws. It will pop out.
I dont know any places near Africa that sells emitters mounted to stars so you’ll probably need to order a new one from China. Maybe Kaidomain. We also need to figure out if it is 6 Volt or 12 volt.
This is just basic emitter swapping stuff and is not specific to this light.
Getting the emitter and star is not an issue, MTN ships to SA, tried and trusted. I’m planning on buying a few items in the not too distant future, so now I’m bargaining on someone who owns one to open it and tests it.
Do you perhaps know of someone in the forums who owns one?
I see you already own a MR70! Are you perhaps willing to open the bezel of your light and perhaps test the voltage across the emitter and maybe post a picture of the star? :question:
I got 70 seconds on Turbo but it wasn’t hot so I knocked it back up.
Sometimes turbo stepping down early can be a good safety thing. In red hot conditions sometimes a timed turbo can outlast a turbo set to 50c stepdown etc.
Being a boost driver, it pulls a lot of current from the battery. I’m told the stock battery has a protection circuit added on and those typically cause extra voltage sag.
For the longest usage of turbo you need a good high drain unprotected battery. A Liitokala 5000 or Shockli 5500 for instance.
I totally agree. I have a Wuben T102 Pro and it came with a protected cell. I inserted my unprotected Shockli 5500 mah cell and it was an instant performance increase. Not sure if the Rofis cell is protected because I’m still waiting for mine. The South African postal service is on strike AGAIN so further delays. Fuuuuuu*#!
The bundled cell of MR70 is actually an unrpotected PLB INR26650-55A (yes, a simple re-wrap), which is, the same cell core used in Shockli 5500mAh. I’m a bit surprised that no one ever pointed this out…
Funnily enough, that’s what brought me back to the thread, just noticed mine is stepping down after only a couple of seconds and I don’t remember it doing that before…
