Looking forward for the results. Maukka =)
Although they’re just engineering samples but should give us more than just a ballpark figure.
Jos, thanks for passing through those LED to Maukka.
- Clemence
- Clemence
We did a blend board with 3,4 and 5k Optisolis and managed to get 99.4 CRI, very nice leds, we used our 10mm Square MCPCB
Cheers
Mark
djozz, As always, very nice! Thank you for doing this….
Something like this is begging for an aspheric.
Pure flood…
Where can I buy some of the 5000k?
Try Cutter.com.au. Mine sold out already, only sm305 (3000K, 5 steps) Rfg00 left.
- Clemence
I have around 3000 pcs left in stock, email me for details
Cheers
Mark
Count me in!!!
Is the footprint for this emitter the same as some pre-exsisting led?
The footprint as far as I know is pretty standard for 3030 midpower leds. But those are never before used in flashlights so for us it is very uncommon. (in the picture are for example Osram Duris leds).
The footprint is the standard Nichia 757 or 3030 led footprint that is industry standard
Cheers
Hey Jos, you just mentioned this LED in another topic, stating 400 lumen for a quad, so i HAD to go look up this topic, which i hadn’t seen yet.
That’s all pretty amazing!
Low Vf for a purple / UV pump chip too !
Amazing overdrive capabilities !
Who would have thought these could do 100 lumen ?
They’re rated 0.2 Watts, aren’t they? lol
I’ll have a look in the Virence webshop, see what he’s got in stock.
By the way, may be interesting to look for “Laird” thermal pads, to electrically insulate the LED boards from the pill / shelf.
Not cheap, but probably one of the best pads.
Various thicknesses available, from 0.125 to 2 mm.
I bet Clemence knows what the best brand thermal pads are though…
Various thicknesses available, from 0.125 to 2 mm.I bet Clemence knows what the best brand thermal pads are though…
I have a little sample thermal pad (0,5mm version) of this: http://www.tglobalthermal.com/tg-x-ultra-soft-thermal-conductive-pad.php
I will include some if you’re interested. It’s very soft and easily torn. I bet you plan to insulate an XML copper board for those Optisolis, right? The easier way is to just use whatever thermal paste you have with several points of super thin support. It’s to keep the MCPCB from tilting and breaking the paste (and touched the base). In my case I use SiC powder or very thin sellotape (only at four outer points and the center).
- Clemence
As I remember, if you decide to use them, Virence boards are non-DTP (but with extreme thin dielectric layer, so performance is as a DTP board) so no electrical insulation of the boards are needed.
As I remember, these Virence boards are non-DTP (but with extreme thin dielectric layer, so performance is as a DTP board) so so electrical insulation of the boards are needed.
I guess Jerommel is trying to solder it on an XML board like you did.
- Clemence
I didn’t know you also have Quad 3030 boards in your store, Clemence.
I browsed it recently for Quad E21 boards, but i must have missed them.
I’ll have a look what you have.
As for the thermal pad you mention, i already have some 0.2mm “Laird” ones.
Recently ordered some 0.125 mm ones too.
Off topic here, but basically your new LED boards are anodized aluminium with copper traces on top, right?
Smart idea!
Wonder how they put the copper traces on there though. Vapor deposition?
Yes, i did see those Quad Optisolis boards earlier.
But that would need a quad optic too…
I’ll have a look what you have.As for the thermal pad you mention, i already have some 0.2mm “Laird” ones.
Recently ordered some 0.125 mm ones too.Off topic here, but basically your new LED boards are anodized aluminium with copper traces on top, right?
Smart idea!
Its the finer version of anodizing but with very fine almost closed cells. As for the copper it uses a Special “adhesive” I guess. There’s a better version with twice the thermal transfer but six times the cost. Can’t afford it at the moment.
- Clemence
I can’t afford those either, probably…
The ones you have aren’t exactly cheap already.
But i wonder if it’s worth it at all.
I mean, it’s probably like when you have 0.0006 Ohm unwanted resistance in a circuit, and then you improve it to 0.0001 Ohm.
You’re not gonna notice it unless you push some really big fat currents.
