What did you mod today?
9511 posts / 0 new
djozz
djozz's picture
Last seen: 8 hours 41 min ago
ZozzV6 wrote:
I did not had time for any flaslight modding for 10 days now. I was modded my house. 75% finished of complete roof replacing rebuilding.
Pics or it didn’t happen.
Agro
Agro's picture
Last seen: 1 min 20 sec ago
CRX, is it glow paint on the centring ring? Or is it made from glow plastic?
MRsDNF
MRsDNF's picture
Last seen: 1 hour 4 min ago
I have a video here. Big Smile
https://www.youtube.com/watch?v=Gi0QexM5eKM
CRX
CRX's picture
Last seen: 6 hours 24 min ago
Glow tape cut out with a scalpel
DB Custom
DB Custom's picture
Last seen: 2 hours 1 min ago
You’re too funny Steve!
Liked the Love at the end from the neighbor, lol, sent him running didn’t it! hahahahaha
ZozzV6
ZozzV6's picture
Last seen: 3 weeks 6 days ago
It did happened. My wife’s dad has this job for 20 years so he done most of the work because he know how to make a roof so I just helped and did what he told me. I thenk him a lot for his help!
Still have a lot work with it but I think the hardest part is complete.
DB Custom
DB Custom's picture
Y’all must get a lot of snow huh? What is that, a 10/12 pitch? Pretty steep! Glad I’m not the one doing that! Big Smile Second thought, looks like it may even be a 12/12! (We don’t get snow, our roof is 4/12…)
Bet you’re gonna enjoy having a new roof over your head! Kudo’s to F-I-L for all the hard work! Thumbs Up
ZozzV6
ZozzV6's picture
Sometimes we have almost no snow in a whole winter but sometimes we have 10-12 inch in one day. 3-5 inch is normal. Most of the houses built like tis roof pitch here. The old roof was full of wasps so we needed to be careful and exterminate most of them a few days earlier than the work.
DB Custom
DB Custom's picture
Yikes! So you also modified a bunch of wasps into ant food. Big Smile
ToyKeeper
ToyKeeper's picture
Last seen: 44 min 54 sec ago
Has been a while since I did any roofing… did two of them with my father, and one was 11/12 pitch. That was a PITA because we couldn’t stand on it without causing damage. At least it only took us one windy morning to discover the importance of tying the top of the ladder to something… I had to climb down a rope. Silly
DB Custom
DB Custom's picture
I suppose your father had to get you to put the skylights in, huh TK? You know, so the moonbeams could illuminate the rooms? Wink The work of a goddess never ends…
MRsDNF
MRsDNF's picture
Its nice to hear about the family helping out Zozz. It sure was/is a big job. Is the rest of the roof ok?
ZozzV6
ZozzV6's picture
We will change the rest also but it has different angle so it needs a separate frame. We want to finish this section completely and then make the rest.
djozz
djozz's picture
Thumbs Up for the pics! That looks like a major job, and a nice house. No wonder the hobby had to be left alone for a while.
ToyKeeper
ToyKeeper's picture
He didn’t like heights, so on his house I actually did have to put the sky beams in. I was the only one willing to go up that high to guide the core load-bearing parts into place. They originally planned to build a log cabin to retire in, but I guess things looked smaller on paper and it turned into more of a log mansion. First world problems.
In any case, good luck with the construction, Zozz. May your new roof be wasp-free.
DB Custom
DB Custom's picture
Don’t know about y’all, but I think his family should work through the night and let Zozz furnish the lighting. Big Smile
Bob_McBob
Last seen: 2 hours 54 min ago
I received some 90 CRI Samsung LH351Ds from AEDe and decided to swap out the 219C in my Tiara for testing. Aside from feeling a little dirty about de-Nichiaing a light, it seems to be a success. With the same optic, the LH351D has a significantly higher output. This is partially due to the bezel not being pressed in, as well as the emitter dome sitting inside the optic aperture better. The output is even higher with a Yajiamei optic.
The LH351D is physically much more similar to an XP-L than a 219C is, which means it behaves a little better as a drop-in replacement, especially with TIR optics. For the most part the light quality subjectively seems similar, and I didn’t notice a huge amount of green shift at lower levels.
Henk4U2
Henk4U2's picture
Last seen: 2 hours 22 min ago
Decribed how a vacant C8 host was set-up to be a UV thrower , but left out the beamshot(s). Because White Walls Won’t Work With UV. Then I remembered that djozz showed us we can use the illumination of the UV light on white paper. Of course I did not have a large enough piece of white paper. But I had a piece of shelf paper that was white enough to do the trick.
On the left you see the hotspot of the C8 at 1.8m (6ft). On the right you see the result of the latest model UV Convoy S2+ at 1.8m.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
BlueSwordM
BlueSwordM's picture
Last seen: 1 week 5 days ago
@Bob, how is the light output compared to the stock XPL?
Would like to know.
Bob_McBob
Would like to know.
I don’t have access to a stock XP-L Tiara right now, but from past measurements, with the best case Yajiamei optic, the LH351D output is about the same (~870 lumens). Adding the bezel and glass lowers output something like 5-10%, so it will end up somewhat lower than stock. Don’t take any of these numbers as absolute since they come from a calibrated shoebox and ceilingbounce, but they should be reasonably comparable in relative terms. The LH351D is a nice option to have for this kind of mod.
BlueSwordM
Ahhh, so that means the LH351D R9070 is about as efficient as an XPL R7000.
Very nice indeed. I wish for them to come so I can finally use them in my BLF Q8 like djozz, and send some 351Ds/Bs to a special member.
CRX
CRX's picture
Eventually received my Seoul Viosys emitters so some DQG UV mini goodness today Smile
Upgraded my DQG Hobi Ti+ UV keyring light
Seoul Viosys Z5 series, 365nm UV LED, CUN66A1B
10mm sinkpad soldered to brass pill
Ground down 11mm ZWB2 filter
Direct drive, single mode
10180 cell
2 x 6mm x 1.5mm green tritium vials
Magnetic detachable tail unit
USB rechargeable
DQG petrol lighter
Max current 600mASeoul Viosys UV on some currency. Shows up all the UV fluorescing bits nicely Thumbs Up Some UV light comparisonsdjozz UV Emitter Tests
DQG Slim AA UV - Stainless Steel
Noctigon MCPCB
Hand made copper pill
Ground down 15mm ZWB2 filter
3x7135 driver, single mode
Reflectored
14250 Cell
Lighted reverse clicky switch
Max current 1000mA
DQG Hobi Ti UV
10mm SinkPad MCPCB soldered to
Hand made brass pill
10180 cell
Twisty Switch
Max current 600mA
ToyKeeper
ToyKeeper's picture
CRX wrote:
What did you do? That doesn’t even look real. If I zoom in a bit it looks better, but the texture at both ends seems like something which shouldn’t actually exist.
CRX
CRX's picture
I’m not sure what you mean?
ToyKeeper
ToyKeeper's picture
Just saying your work is so unreal it’s out of this world.
Don’t worry, it’s a good thing. Smile
DB Custom
DB Custom's picture
Is there a textured wall or coarse paper that is reflecting in the lens? This may be what she is seeing…
CRX
CRX's picture
Oh this, yeah that’s a textured white mat, the only glowy thing I had to hand for a picture.
I can see how that would be confusing now Big Smile
e1000
Last seen: 14 hours 50 min ago
Not technically a mod but built my first S2 today:
Convoy S2
Nichia 219C
Smooth reflector
DrJones H17Fx Driver
Samsung 30Q 18650
Tail spring bypass
Happy to have this thing fire up on my first try. There’s a few small tweaks I still want to make but happy with my first day progress. I’ll save the pics since everyone here’s seen a S2 and my soldering skills are HORRENDOUS.
MRsDNF
MRsDNF's picture
Sounds like a nice mod e1000. As for the soldering a hot iron and good flux makes a big difference.
g_damian
g_damian's picture
Last seen: 10 hours 35 min ago
Convoy S2
Nichia 219C
Smooth reflector
Samsung 30Q 18650
Tail spring bypass
Isn’t that too much current for 219c?
