ORCATORCH D611 Diving LED Flashlight CREE XHP70
https://www.gearbest.com/led-flashlights/pp_1548208.html?wid=1433363
The ORCATORCH D611 Diving LED Flashlight is a primary canister dive light specially designed for underwater adventures such as scuba diving and cave diving. The light head is connected by a cable to the battery canister containing two 26650 batteries, this allows you to fix the battery canister to your body so you just need to hold the small light head when using it.
Main Features:
β’ CREE XHP70 LED, max output of 2400 lumens and max beam distance of 251m
β’ Water pressure resistant construction, depth rated to underwater 150 meters
β’ Alloy aluminum reflector with the professional optical analysis provides a further beam distance
β’ Toughened glass lens with two-side coating with 99 percent lights transmission
β’ Uses 2 26650 Li-ion batteries ( included ), long runtime up to 22h
