I prefer L => => => H no matter how many levels there are. But, if there are more than 3 levels, I hope for quick access to BOTH the lowest level AND the highest level from off. The Ramping UI used in many of our latest BLF firmwares, with press-and-hold from Off to Moonlight and/or double-click from Off to Turbo is about perfect.
Depends on where I’m going. If it’s a night out to dinner, movies, other situations where I may use the light inside I carry an Olight S15R and use moonlight or low a lot so that’s where I leave the memory set. However, my current EDC is a TG06S with 14500 because I want high first time every time. I live in a rural area and when I come home at night there is a possibility of skunks or coyotes being around so I want plenty of light if I see movement while walking to the front door.
I prefer the interfaces that let you get to either quickly with just a few one-handed button presses. HDS and Surefire really nailed that over 20 years ago.
I really do not like memory because I may be using the light intermittently and I never know what it may be starting on.
Definitely no!
Mode memory means that every time I turn off the light I have to go through the sequence of modes all the way to where I want it (which is, in general, L).
I frequently fail to do the sequence and end up blasting myself with H (which is what I actually use the most).
My only use for mode memory is when I put the light in my pocket for a while and resume later. In all other cases it’s just a problem.
I strongly prefer lights w/out mode memory at all, though I guess a time-limited memory would serve me best.
As to direction….I agree with what has been said already, having a shortcuts to moonlight and turbo is great for me.
Actually Emisar UI also starts M (unless memory messes it up). And I like it a lot.
I like both , depending on the situation . Where I get in trouble , is having many different UIs , some not so intuitive . The Q8 with the ramping is easy to figure out . Double , triple , short , long , gets to be a pain sometimes. Life is hard enough without my light giving me stress .
What? Mode memory means that if you last had it on L and turned it off, the next time you turn it on it will be on L again. You don’t have to go through any sequence.
I nearly always want to start L. Or ML, when L is very low.
But in actual use I tend to go to H most of the time. Or MH when H is very high.
So yes, I do need to perform elaborate shutdown sequences on all my lights with memory.
And also elaborate startup sequences on all lights that don’t have good shortcuts.
With ramping lights, you can ramp up from off to whatever level you want without blinding yourself, or resume at the last used value. Turbo is a doubleclick. Makes it easy to get to lowest and highest.
I always use the shortcuts to get to either Moonlight or Turbo. If I need a low amount of light, I use the shortcut to Moonlight, then ramp up from there to my desired output. In this case, Mode Memory wouldn’t be useful to me at all.
I always know what the torch is going to do, and starting on High is my preference. That’s what it is for (a bright torch).
If wanting to be subtle, I hold my hand in front, click it down to the desired lower level, then expose.
Ramping UIs are all very well, and I like the Q8 because I can set ultra-low, preset level, or turbo, with a few different clicks of the button, but I couldn’t hand it to an uneducated user and expect them to get it.
Sometimes less is more. And torches should be simple and intuitive, except for techies.
Flashy modes, by all means, but keep them hidden behind a double or triple fast click.
Likewise “Turbo”, a rather useless mode except for short-lived headline figures.
This has been discussed time and time again. But, for some people, Turbo is anything but useless. Just because you don’t use it does not mean it’s useless.
Most people don’t have more trouble remembering LMH vs HML; and most people can use a bright light without needing to start off in the brightest mode every single time. They like to avoid needing to :
which sometimes doesn’t work, because the highest mode after going through your hand can be much brighter than a proper ultra low mode.
Not all of them, but some ramping lights and any ramping lights with newer firmware will often come with a simplified UI mode (“muggle mode”) which lobotomizes the light so that people feel better about it. The emisar firmware seems simple enough already; a non-techie just has to know that you hold to change brightness and click to turn on and off.
Useless? I don’t know if you realize this, but there’s plenty of lights that used to and are unable to run at full brightness indefinitely, but they never called that turbo. Without thermal protection, you couldn’t use them for long without checking how hot they were manually and maybe stepping the brightness down if it was too hot. The modern lights with a turbo mode can actually manage that all on their own, and in the q8 for instance, if you put an up to date version of anduril on, you can even put it in turbo mode and have it regulate itself to put out the max brightness that it can without overheating, rather than just stepping down and never stepping back up. And it’ll run for a fair while on turbo with the mass that it’s got. The d4 is a well known example of a light that can go way beyond what’s sustainable, but you might not realize that even ~700 lumens might be too much to sustain, depending. And the fw3a might only make it to 3-400 lumens if you have to have it be able to run like that indefinitely. Personally though, I don’t think many of us only buy lights that are not able to go to a higher brightness than their steady state thermal limit. Almost all lights can get pretty toasty if you let them.
